F1 - 2018 Russian Grand Prix
by gofast182. 09/26/18 06:11 AM
Pets Puking in Middle of the Night :~/
by LoneRanger. 09/26/18 05:16 AM
Is there a new (2018) list of GM Dexron VI licensees?
by garageman402. 09/26/18 01:20 AM
Thoughts on new AMAZON branded oil...?
by PantherFan88. 09/25/18 10:47 PM
Clutch kit?
by andrewp1998. 09/25/18 10:34 PM
Galaxy S8+ weird app when clearing storage
by KrisZ. 09/25/18 10:18 PM
Brake bleeder - cfm ?
by hallstevenson. 09/25/18 09:43 PM
18' Corolla vs 18' Elantra
by wolf_06. 09/25/18 09:41 PM
Using Tc-w3 bad for my car?
by Floydian. 09/25/18 09:25 PM
I'm going to start using type F in my gm autos
by turtlevette. 09/25/18 09:17 PM
Cleaning deceased MIL condo and found $15K cash
by Mr Nice. 09/25/18 09:12 PM
Gluten
by StevieC. 09/25/18 07:55 PM
Amazon Prime delivering inside your house
by StevieC. 09/25/18 07:49 PM
2018 MB C300 M1 0W-40 3,475 Miles
by 2015_PSD. 09/25/18 06:44 PM
02-05 Silverado frame rot
by Oildudeny. 09/25/18 06:38 PM
Aftermarket Back Up Camera
by lancerplayer. 09/25/18 06:20 PM
Service champ filter CUT OPEN
by 53' Stude. 09/25/18 05:05 PM
Pressure washer pump life just 23 hours?
by HawkeyeScott. 09/25/18 05:01 PM
Pat_Roberts, Peppz, Jfa02, ibsfusion, Fearcat707
66070 Registered Users
57 registered members (Boomer, Astro14, Bailes1992, alarmguy, 77GrandPrix, 7 invisible), 611 guests, and 45 spiders.
Topics291,028
Posts4,854,732
Members66,070
Most Online3,590
Jan 24th, 2017
need some methods of burping ait out #4107562
05/26/16 08:54 PM
05/26/16 08:54 PM
long island ny
snake123 Offline OP
snake123  Offline OP
long island ny
Dexcool . they say it lasts 5 years , or 150000 , I have 43,000 only on the car. now the Dexcool in the reservoir overflow has very tiny flakes in it , but not big chunks, so I figure Ill do a complete drain and refill with fresh new Dexcool and distilled water. my question is how do I get the air out the old conventional way with out disturbing that bleeder screw , because my luck it will break off or leak so I would rather just rain it fill it with water run it drain it do it again , now when I'm ready to put the dexcool in and the rest with distilled water , how do I get all the air out , squeeze the radiator hoses , with the cap off cold.. and the fill it run it check it and redo that again .will this method work?
Re: need some methods of burping ait out [Re: snake123] #4107592
05/26/16 09:24 PM
05/26/16 09:24 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
You should loosen the bleeder, use a small wrench on it and give the wrench a couple of light taps with a hammer to break it free if need be,
Re: need some methods of burping ait out [Re: snake123] #4107615
05/26/16 09:46 PM
05/26/16 09:46 PM
Ontario Niagara region
Drosselmier Offline
Drosselmier  Offline
When draining the coolant repeatedly, do you collect the coolant each time for recycle ? You would need a lot of gallon jugs to do the right thing.
Re: need some methods of burping ait out [Re: snake123] #4107650
05/26/16 10:26 PM
05/26/16 10:26 PM
Northern Kentucky
901Memphis Offline
901Memphis  Offline
Northern Kentucky
I am not sure about your particular model but in my experience you WILL need the bleeder if you want your heat to work.
I wouldn't worry about it, those things usually come loose as long as you don't do something dumb
2012 Chevy Cruze LT 1.4T - 50k
2002 Buick Century 130k - Built 4T65e(Maxlife) - Edge 0w40 + Fram XG3980
Re: need some methods of burping ait out [Re: Drosselmier] #4109437
05/29/16 03:37 AM
05/29/16 03:37 AM
CA
CharlieBauer Offline
CA
I solved that problem by using distilled water.
It ain't what you don't know that gets you into trouble. It's what you know for sure that ain't so.
- mistakenly attributed to Mark Twain
Re: need some methods of burping ait out [Re: snake123] #4134402
06/25/16 10:18 AM
06/25/16 10:18 AM
Virginia
kala_azar Offline
kala_azar  Offline
Virginia
I used the AirLift II for the first time recently, and I'll NEVER do a coolant fill again without it. 3 minute process, no burping, no mess, and it got the deep recesses of the heater core which is a royal [censored] to purge given its waaay higher than the rest of the coolant system.
https://youtu.be/YaRIxqAW3zk
I'll never do it again without it, worth every penny. This is the model I bought, I preferred the solid brass over the plastic economy version
UView 550000 Airlift Cooling System Leak Checker and Airlock Purge Tool Kit https://www.amazon.com/dp/B0002SRH5G/ref=cm_sw_r_cp_api_afQBxbM03HRBG
Re: need some methods of burping ait out [Re: kala_azar] #4142708
07/04/16 10:21 AM
07/04/16 10:21 AM
Ontario Canada
Canadastang Offline
Canadastang  Offline
Ontario Canada
That air purge tool is pretty slick, but a little spendy.
My .02 - if you can open the bleeder screw, do so. If it's seized, inaccessible, non-existent or whatever, here's what I do:
1. Raise the front end (or rear if it's a mid/rear engine vehicle) of the car. Remember, the air will always want to rise to the highest point.
2. Remove the upper rad hose at the rad and fill through the hose until full.
3. Replace hose, and squeeze all accessible rad hoses repeatedly until you have 'pumped' coolant into the rad, reservoir, block, etc. Repeat this a few more times, until the hoses all feel full. Fill with coolant again as necessary.
4. Leave the rad cap off, start the engine and turn the heat on to max. If there is no hot air at the vents within a minute or two, shut the engine off - you have air trapped in the system. Repeat step 3 a few more times, then go back to step 4.
Eventually you'll get all of the air out of the system. It may take one attempt, it may take 5.
Be careful to avoid burning yourself - coolant can be hot. lol.
I've done this numerous times on various vehicles that had bleeder screws that were seized and have always been successful. Sometimes it takes a few tries, but it always works.
Re: need some methods of burping ait out [Re: Canadastang] #4155642
07/19/16 10:58 PM
07/19/16 10:58 PM
long island ny
snake123 Offline OP
snake123  Offline OP
long island ny
thanks about squeezing the hoses
Re: need some methods of burping ait out [Re: snake123] #4181538
08/19/16 03:18 PM
08/19/16 03:18 PM
Caribbean
Nissan101 Offline
Nissan101  Offline
Caribbean
Keep the radiator cover off....rev the engine for about 2000rpm until the cooling fans turn on(i.e. meaning the thermostat opened).
YOU will get a mess but it will remove the air
Nissan N16 -10w30
Nissan S13 -20w50
Royal Purple HPS smile
Re: need some methods of burping ait out [Re: snake123] #4208226
09/21/16 01:12 PM
09/21/16 01:12 PM
The land of USA-made Subies!
SubieRubyRoo Offline
This is all you need... Spill-free funnel
You stick the o-ringed tube through the cap attachment, then stick the funnel on top. You fill antifreeze until you maintain a fluid level above the top of the radiator. Start the engine and turn the heater on high, let it run for a couple minutes. It will burp into the funnel and eliminate bubbles in the system. Once bubbling has stopped, turn the engine off. Stick the plug into the funnel. Disconnect funnel from filler tube. Place funnel over coolant jug. Remove plug and have a spill-free top off!
Re: need some methods of burping ait out [Re: snake123] #4208241
09/21/16 01:41 PM
09/21/16 01:41 PM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
Turning on the heat just makes it take longer to get fully hot.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: need some methods of burping ait out [Re: snake123] #4223716
10/12/16 04:01 AM
10/12/16 04:01 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
I drill a small hole(1/16) in the thermostat so I never had to worry about it.
The "thinking" man's friend.
Re: need some methods of burping ait out [Re: snake123] #4226022
10/15/16 11:48 AM
10/15/16 11:48 AM
Massachusetts
QuinZ Offline
QuinZ  Offline
Massachusetts
When the cap is off.
Lisle 24680
Boston is a city of hope and joy, strength, resilience and champions. - Mayor Martin J. Walsh
Re: need some methods of burping ait out [Re: kala_azar] #4283396
12/23/16 04:46 PM
12/23/16 04:46 PM
Oklahoma
slomo Offline
slomo  Offline
Oklahoma
That Airlift kit gets "most" of the air out, not all. Youtube had a clear hose and PVC pipe cooling system mock up. You can see at the end of the vacuum there was air still in the tubes. No sale.
Here's the video on it that shows air STILL in the system. youtube
slomo
Re: need some methods of burping ait out [Re: Lubener] #4283402
12/23/16 04:53 PM
12/23/16 04:53 PM
Oklahoma
slomo Offline
slomo  Offline
Oklahoma
Just as he said. Self burping easy as pie. I drilled two holes in my Jeep CJ7 thermo. Without while refilling coolant, radiator was full. Temp gauge hit the moon. I was like what??? Did the two small hole trick in the thermostat. Problem solved, perfect heat for a Jeep anyway.
slomo
