Did Rotella Ever Have JASO MA Certification?
by BBDartCA - 01/22/20 12:49 AM
Old Tundra Headlamp Upgrade
by JeffKeryk - 01/21/20 09:41 PM
MOVIE: Dr. Dolittle
by Kira - 01/21/20 09:34 PM
Oil weight and Oil Grade
by Snagglefoot - 01/21/20 07:11 PM
Which air filter for RAV 4 Hybrid
by NH73 - 01/21/20 06:44 PM
Finding a good "cold weather" vehicle?
by Vern_in_IL - 01/21/20 06:15 PM
Bough NGK Ruthenium sparkplugs
by cronk - 01/21/20 06:07 PM
HF 30% Off $10 and Under
by TheLawnRanger - 01/21/20 06:02 PM
Stolen Battery-New one on Me
by bunnspecial - 01/21/20 05:29 PM
2006 Acura TSX Buying Advice
by maverickfhs - 01/21/20 04:35 PM
Castrol GTX Diesel 15W-40, CK4
by HDoilDude - 01/21/20 04:30 PM
Combo of P0068 and P307A
by Alfred_B - 01/21/20 04:30 PM
Are the plastic battery trays necessary?
by littlehulkster - 01/21/20 03:18 PM
Amsoil ATV/UTV Powertrain Fluid
by IowaFord - 01/21/20 02:13 PM
Motorcraft FL500s 3,630 miles.
by mpgo4th - 01/21/20 01:36 PM
Xcel Class Action Suit
by John_K - 01/21/20 12:33 PM
RV Freightliner Cummins ISB 6.7 oil question
by 1978elcamino - 01/21/20 11:48 AM
IowaFord, Origami99, reylafo, PastPresMike, RedBeard83
70497 Registered Users
32 registered members (1WildPig, Bailes1992, bbhero, aleneros, Aerojoe, 7 invisible), 1,295 guests, and 27 spiders.
Topics300,415
Posts5,175,283
Members70,497
04 C1500 1/2 Ton; P/S Fluid Disappearing #4107425 05/26/16 04:52 PM
T
TexasTea Offline OP
T
Hey guys,
I got an 2004 Chevy C1500 1/2 Ton. The power steering fluid keeps disappearing on me. No leak that i can discern. At least not one bad enough to drip, no stains on driveway, anything like that.
What i DO notice is that the power steering filler neck is dirty as [censored]...like grimey oily residue...almost like the fluid is being pushed up under/over the filler neck cap and leaving oil residue stains all over the cap and filler neck...i'll wipe it down good and clean and 2-4 weeks later its just as dirty again.
Really dont want to service the power steering, nothing wrong with it. fluid just seems to disappear....instead of topping off i may just use my fluid pump and get what i can out, then restore it.
Anyone had an issue like this before? Perhaps with this same GMT800 platform
ETA: I have recently replaced the waterpump and other accessories...intake manifold...etc. i have been all up in and around the front of the engine and would've dead-on noticed something like a leaky P/S pump gasket (if there even is one) or seals weeping or anything like that...the only thing on the front that is even slightly problematic is a very slight weep on the front timing chain cover...over the course of 150,000 miles... cleaned that up when i went to change the water pump and havent had any weeping since.
Re: 04 C1500 1/2 Ton; P/S Fluid Disappearing [Re: TexasTea] #4107451 05/26/16 05:32 PM
CT8 Offline
Is there a gasket on the cap? How does the color of the fluid look? how foamy [if it is] after driving the truck for a while?
2015 F150 2.7
2018 F350 6.2
Re: 04 C1500 1/2 Ton; P/S Fluid Disappearing [Re: TexasTea] #4107458 05/26/16 05:48 PM
clinebarger Offline
Are you sure your not overfilling it? White arrow is Full Cold, Red arrow is Full Hot.
I check mine (2500HD but has the same Saginaw PS Pump) in the mourning with the system Cold, It sits right at the Full Cold mark. I have over 300,000 on the original pump with no issues.
If you have never exchanged the PS Fluid.....You need to!! PS Fluid get really hot, Especially in our HOT climate, Yours is a little easier than mine on fluid, I have a HydroBoost & no Cooler.
Amsoil & Royal Purple have synthetic PS Fluid, I've used both, I cant tell the difference, Running Royal Purple right now, Got it off Amazon pretty cheap.
2001 Chevy Camaro L92/4L80E
Re: 04 C1500 1/2 Ton; P/S Fluid Disappearing [Re: clinebarger] #4107599 05/26/16 08:28 PM
R
Ramblejam Offline
R
Valvoline MaxLife PSF is widely available at a fraction of the cost ($5.99/quart); it replaces their old SynPower product, which was specifically recommended by GM to alleviate noise in these pumps.
I use it myself in Hydroboost units (complete fluid exchange), have found it to work well, and not suffer from degradation in these demanding applications.
Re: 04 C1500 1/2 Ton; P/S Fluid Disappearing [Re: TexasTea] #4108855 05/28/16 09:58 AM
A
artificialist Offline
A
Does your truck use rack and pinion steering? If it does, move the rack boots out of the way and look for PSF. Use zip ties to reseal the PS rack boots.
2010 Lancer Ralliart Sportback
Re: 04 C1500 1/2 Ton; P/S Fluid Disappearing [Re: Ramblejam] #4109309 05/28/16 08:58 PM
clinebarger Offline
Thanks, I may try it next time I exchange the PSF on my truck, The "With Stop Leak" is generally a Red Flag for me.
Re: 04 C1500 1/2 Ton; P/S Fluid Disappearing [Re: clinebarger] #4109737 05/29/16 11:38 AM
sleddriver Offline
I'd suggest a different type of "stop leak": ATP AT-205 Reseal. No petroleum distillates. It uses something completely different that doesn't harm old seals by swelling them.
I tried it in the very leaky sled PS rack. Haven't added fluid in a month. I'm still amazed.....
1998 Volvo V70 T5 228,880 mi. Original Owner.
M1 10W-30 HM
"It's never a mistake to buy tools, defined broadly. They're not a cost, they're an investment." - J.B. Peterson
Re: 04 C1500 1/2 Ton; P/S Fluid Disappearing [Re: sleddriver] #4109814 05/29/16 01:34 PM
R
Ramblejam Offline
R
"will not over-swell or breakdown seals"
http://atpautomotive.com/featured/re-seal
Notice the difference; they don't say it doesn't swell, just that it won't over-swell. As well, there's no secret as to the composition of this stuff: https://en.wikipedia.org/wiki/2-(2-Ethoxyethoxy)ethanol
If you want some fun reading on the subject, do a Google search on putting a small amount of glycol-based brake fluid in PSF to mitigate leaks.
I understand the knee-jerk reaction, and if this were one of the many additives on the market, I'd agree. However, it's a fully-formulated (complete) fluid from a well-known producer that's listed as meeting GM/Ford/Chrysler requirements, and states that it will not clog or foam (I've yet to encounter either).
Re: 04 C1500 1/2 Ton; P/S Fluid Disappearing [Re: Ramblejam] #4112776 06/01/16 07:08 PM
sleddriver Offline
You're nit-picking...again. I read all about it like 2-1/2 months ago. It's now been in my PS system for over a month. It doesn't ruin seals by overswelling them the way petroleum-based products do. Finally, I never claimed it was a secret. I just couldn't remember the name of the key ingredient.
Read about it: Been there. Done that. Works great. Moving on.....
M1 10W-30 HM
