Did Rotella Ever Have JASO MA Certification?
by BBDartCA - 01/22/20 12:49 AM
Old Tundra Headlamp Upgrade
by JeffKeryk - 01/21/20 09:41 PM
MOVIE: Dr. Dolittle
by Kira - 01/21/20 09:34 PM
Oil weight and Oil Grade
by Snagglefoot - 01/21/20 07:11 PM
Which air filter for RAV 4 Hybrid
by NH73 - 01/21/20 06:44 PM
Finding a good "cold weather" vehicle?
by Vern_in_IL - 01/21/20 06:15 PM
Bough NGK Ruthenium sparkplugs
by cronk - 01/21/20 06:07 PM
HF 30% Off $10 and Under
by TheLawnRanger - 01/21/20 06:02 PM
Stolen Battery-New one on Me
by bunnspecial - 01/21/20 05:29 PM
2006 Acura TSX Buying Advice
by maverickfhs - 01/21/20 04:35 PM
Castrol GTX Diesel 15W-40, CK4
by HDoilDude - 01/21/20 04:30 PM
Combo of P0068 and P307A
by Alfred_B - 01/21/20 04:30 PM
Are the plastic battery trays necessary?
by littlehulkster - 01/21/20 03:18 PM
Amsoil ATV/UTV Powertrain Fluid
by IowaFord - 01/21/20 02:13 PM
Motorcraft FL500s 3,630 miles.
by mpgo4th - 01/21/20 01:36 PM
Xcel Class Action Suit
by John_K - 01/21/20 12:33 PM
RV Freightliner Cummins ISB 6.7 oil question
by 1978elcamino - 01/21/20 11:48 AM
IowaFord, Origami99, reylafo, PastPresMike, RedBeard83
70497 Registered Users
28 registered members (aleneros, Aerojoe, Bailes1992, ArrestMeRedZ, 14Accent, 4 invisible), 1,264 guests, and 28 spiders.
Topics300,415
Posts5,175,281
Members70,497
Day 2 the "right" trans-filter doesn't fit either #4107413 05/26/16 04:37 PM
69GTX Offline OP
Day 2
I had hopes today, but some trepidation. When the filter arrived it had the right WIX part number 58822, and the "right" orange seal. But, this new seal was only half the length of the green one....and half the length of the orange one in Sir Tanon's photo in yesterday's thread. Hadn't seen anything like that one before. This is getting stranger by the hour. And it fit no better than the green seal one from yesterday. Simple_gifts was kind enough to wait until I tried the filter fit. It took way to much force and it was going nowhere again.
Called the nearest Ford parts dealership and got hold of them before they left for the day. They had a OEM filter for $39 that could be picked up first thing in the morning. I mentioned to the guy that I had tried twice with the WIX filters/hard plastic-metal mesh seals. He said the Ford seal is just plain old orange rubber. That's what come out off my car, pieces of soft rubber that were quite resilient, and no internal metal rings. If the Ford filter doesn't work out, I will probably have it towed to a local shop. I'll have $85 in filters come tomorrow morning. Thanks to Simple_gifts yet again who is going to pick up the Ford filter on his way to work in the morning.
Day 3 to come.
Day 1 recap
2001 Lincoln Cont 4.6L DOHC/ 50K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Day 2 the "right" trans-filter doesn't fit either [Re: 69GTX] #4107469 05/26/16 06:02 PM
A
abycat Offline
A
I was wondering how you made out. keep us posted and good luck smile
2017 dodge caravan gt
2011 nissan versa hb
Re: Day 2 the "right" trans-filter doesn't fit either [Re: 69GTX] #4107485 05/26/16 06:13 PM
T
Trav Offline
T
There is another filter that is not listed in the transmission parts breakdown found online, that is the .420" red one which is probably just rubber.
Like I said yesterday I have a feeling (seeing as you could lift the car with a jack trying to get a .490" in) that is might be one of these .420".
The dealer will have the correct one for this based on VIN. For some reason some cars end up with parts in there that don't fit when a regular aftermarket parts program is used.
Some aftermarket filters for a Subaru fit fine but will suck air and possibly blow the transmission, sometimes its best just to go OE.
Clean up any nicks and burrs with a piece of 600 wet and dry (use a little ATF) to prevent seal damage, wipe it out after sanding with a lint free cloth and lube the seal with ATF. If the bore is really buggered and cant make a good seal you may need to sleeve it, easy 10 min job that doesn't require a different seal.
Wish you were close I would come over and give you a hand. PM and I will give you my number if I can help help with any questions if you get in a bind.
Re: Day 2 the "right" trans-filter doesn't fit either [Re: Trav] #4107506 05/26/16 06:40 PM
69GTX Offline OP
Originally Posted By: Trav
...Clean up any nicks and burrs with a piece of 600 wet and dry (use a little ATF) to prevent seal damage, wipe it out after sanding with a lint free cloth and lube the seal with ATF.
Thanks Trav. I actually ran a rounded metal "pencil" file lightly around the bore yesterday (followed by wire brush) to get 99% of the traces of the previous orange rubber gasket out. Hopefully, I didn't bugger up the bore either by that or slamming in the oversize seals.
What do I sleeve the bore with if it needs to get bigger? A certain grade of rubber sheet to cut and wrap around the existing seal? Or just wrap with teflon tape?
I researched this job several times over the past 6 months just to prevent "gotcha's." In none of the videos or procedures I viewed did anyone say they ran into a problem with filter seals. Based on my experiences it's probably pretty darn common. None of the videos I've seen show a rubber gasket being used, just hard plastic with metal strips. I don't know how these people got their seals in. ???? If I could do it over I'd have left that old/OEM seal in place and just tried to reuse it. It was quite pliable and fully intact. Every video I saw said you must remove the old seal. If the new filter fits back into it snug, why bother replacing. I would suggest to anyone to try that first before removing an old rubber seal that appears to be in good condition.
Sure got my head handed to me on this one. I just hope I can get the car done by late Friday for a trip out of state. If not, I'll have to get a 3 day rental.
1969 Ply GTX/RRs
Re: Day 2 the "right" trans-filter doesn't fit either [Re: 69GTX] #4107523 05/26/16 06:55 PM
T
Trav Offline
T
There are commercially available stainless steel sleeves in different sizes, but you sound okay if like you say there are no gouges.
These sleeves are extremely thin and can be used on worn or damaged bores and shafts.
It sounds to me just from reading your problem this is an oddball, they are getting their seals in because they are sized right for the transmission they are putting them in that's all.
When you have the correct on your will go right in.
Re: Day 2 the "right" trans-filter doesn't fit either [Re: 69GTX] #4107538 05/26/16 07:26 PM
P
Panzerman Offline
P
Guess I got lucky with the 5 filters I changed. I never heard of red, orange and green. Mine were all orange. What difference would it make if the flange is scratched inside. It's all bathed in fluid anyway. As long as some of it goes thru the filter. It's really not that snug in there. Sometime the filter just comes out with the pan. It's sorta loose on there. When the pan is on, it is the only thing holding it in place. Also just wanted to tell you make sure you re-use the factory gasket and use a torque wrench to put the bolts in. They don't take much torque. 108 inch pounds or about 7-8 foot pounds and they will strip easy. Although they are easy to re- thread. Hope you have better luck tomorrow.
2006 Dodge Ram 2500 Hemi 4x4
2016 Dodge Challenger Scat Pack
Re: Day 2 the "right" trans-filter doesn't fit either [Re: Panzerman] #4107579 05/26/16 08:12 PM
T
Trav Offline
T
Some transmissions could suck air under certain conditions if the seal is bad. Always replace the seal or filter gasket, no exceptions.
Read this from ATRA about cavitation in this article.
http://www.atraonline.com/gears/1997/1997-09/gsep97p30.htm
Re: Day 2 the "right" trans-filter doesn't fit either [Re: 69GTX] #4107983 05/27/16 10:10 AM
P
Panzerman Offline
P
Interesting article. I like how the Dodges actually bolt the filter on. Fords the pan just keeps them from falling out. They fit snug, but it doesn't take much to pull them free or press them in. More than once I dropped a pan and the filter was in it with a Ford.
Re: Day 2 the "right" trans-filter doesn't fit either [Re: Panzerman] #4108121 05/27/16 12:04 PM
69GTX Offline OP
Got the Ford 3rd filter, red seal that is very nearly identical to the WIX green one in width, length, and material. And it's identical in lettering and mfg to what came out of my car...perfect match in all respects. So that's the OEM filter. Didn't go up into position any better though. Runs into resistance after 1/3 insertion (flange lip). Trav suggested using hot air on seal to soften it, vaseline on the bore seal threads, and then inserting. Another video suggested using a perfectly sized socket to contact the seal OD and tap it in. Great ideas. Didn't help me though. It's beginning to feel like I screwed up.
It's finally hitting me that 3 filters can't be all wrong on the fit. Looked at the bore again and thinking what before looked like a perfect sleeved/machined bore in there might be the wire wound metal core of the old seal. Sent a photo to Trav to get his thoughts. Yup, metal seal core must still be in there. The traces of orange I see at top and bottom of the bore is seal material oozing out from the outside bore. Still doesn't explain how hard plastic turned to soft rubber.
Going out now to apply more force with a screw driver to that inner seal in order to deform it. It looked so perfect I thought it was part of the machined/cast surfaces. Put my reading glasses on and could see a couple "phonographic" rings on the lower part of the sleeve/seal. Rather than a machined finished surface, it's probably the tightly wrapped metal core still stuck in there.
Finished breakfast as I typed this up.....heading out with hammer and screwdriver for a 3rd time. First attempts Wed/Thursday were only moderate force. Experience on this job matters. Trav indicated that there are lots of places to go wrong with these filters/seals/bore, etc. It's not quite like an oil or air filter change. I also didn't realize that seal is ultra critical to the transmission life as a poor seal fit will shorten the trans life or kill it in short order. So taking Trav's advice, I'll stick with the OEM filter at twice the cost to ensure an ideal OEM-designed fit.
1969 Ply GTX/RRs
Re: Day 2 the "right" trans-filter doesn't fit either [Re: 69GTX] #4108123 05/27/16 12:04 PM
69GTX Offline OP
Seal came out within about 10 min of prying it into a scalloped shape. I just didn't pound it hard enough with a metal hammer the first time around. I knew about the caution of not damaging the upper seating surface, but ended up doing it anyways by driving the screwdriver tip too far on 2 occasions (2 dings). And the screwdriver left some "tracks" along the vertical bore. Smoothed that up with a round file and some sandpaper. Lubed up with vasoline and it popped in with almost no effort.
Next time be extra careful only drive the screwdriver up about 1/2 to 2/3 the length of the seal to avoid that upper flange. Now to complete the flushing of the upper end of the transmission.
Kudo's to Trav for walking me through this, and to Simple_gifts for running 2 filters for me. I have 2 new WIX filters going back to the parts store. That 2nd "correct" WIX filter with the red seal and right part number was just wrong. That half length "shorty" red seal was not going to be as good as what Ford intended. For trans filters, stick with the OEM. Oddly, the first filter with the full length green seal (and wrong part number) would have worked perfectly fine imo. Funny how that it is.
I got off course 2 days ago because the leftover orange seal material in the bore was soft rubberized stuff. Had it remained like stiffer plastic I'd have continued to working on the seal. Got confused on the soft rubber. Ford may have used a different seal material back then. Don't know. At least I have a fresh filter in place now for the rest of the time I own this car. It either had 50K or 70K miles on it.
Afternoon update:
I thought I put those last 2 posts in this morning but instead they went to Trav's PM's. So I just put them in a few hours after the fact.
To keep the fun alive I forget the jack stands under the car and ran them down when coming off the ramps. It never ends once you get behind the 8 ball. Jacked the car back up, removed the stands and no damage underneath. They were 1/4" under the frame as secondary support.
Now trying to get a level in "hot" operating band without much luck. Had 17 quarts of fluid to flush/fill and I'm all out. I kept a visible level on the stick cold when flushing so I'm surprised that when fully hot it got a little lower. Have to run to WM or the parts store 12 miles away for more quarts of Mercon V. I'll take the Camaro since it's been boxed in for 3 days.
1969 Ply GTX/RRs
Re: Day 2 the "right" trans-filter doesn't fit either [Re: 69GTX] #4108200 05/27/16 01:28 PM
J
JustinH Offline
J
Rockauto sent me a Wix Transmission filter for a RAV4, it was totally the wrong thing.
I left the original filter in there and didn't want to mess with it.
'16 Ford Escape
'11 Scion XB
Re: Day 2 the "right" trans-filter doesn't fit either [Re: 69GTX] #4108279 05/27/16 03:08 PM
simple_gifts Offline
No way..... That's crazy; I was there..... Glad you got it sorted out.
-T
2004 Prius; 126K; ALM
2007 Yaris 103K ATM
2006 B2300;137K;ALM
Was driving an ox cart; Now on the USS Enterprise
Re: Day 2 the "right" trans-filter doesn't fit either [Re: 69GTX] #4108303 05/27/16 03:38 PM
SirTanon Offline
Glad to hear you got this all fixed.
I never had the kind of filter problems you had with your AX4N. Not sure why - maybe I lucked out. Hopefully, your next replacement will go much more smoothly.
2013 Nissan Altima SV - 2.5 liter/CVT - 125,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 68,000mi
2010 Ford Fusion - 274k mi - SOLD
Re: Day 2 the "right" trans-filter doesn't fit either [Re: SirTanon] #4108362 05/27/16 05:06 PM
69GTX Offline OP
Because you were smart/intuitive enough to get the old seal out right away. It's a 15 min job. I took 3 days (18 hrs) because I thought I knew something. Doitmyself cautioned me 2 days ago on the troubles they had with figuring out their seal was still in there. No, that couldn't happen to me...lol. I'd seen the photos before I started and knew what to look for....NOT! It was in front of my face all the time. And 2 "bad" filters wasn't enough....I needed to get my count up to 3!
Needed 2 extra quarts to get the level at nearly hot-full. And the final ironic insult was "proudly" walking over to the car for the last task, putting on the steel clamp tie for the 2 cooler lines where they pass close together. I guess this is to prevent rubbing and movement. As I slid my hand into the slot with jubilant anticipation, my hand got bumped and the clamp fell into "Hades." I heard the tinkling sound of metal. It didn't make it to the ground. Ended up wrapping with wire for now.
Was able to return both other filters for $48. So at least I didn't have to eat those. Total amount of quarts used was 19 - the trans holds 13.7 qts.
There will be no next replacement as the car will have to go another 8-10 years to rack up that mileage again It would be 22-24 years old by then...and hopefully doing Taxi service overseas for someone else.
1969 Ply GTX/RRs
Re: Day 2 the "right" trans-filter doesn't fit either [Re: 69GTX] #4108469 05/27/16 07:39 PM
69GTX Offline OP
I read Doitmyself's post from 2 days ago along with the seal bore photo. And darn if that's EXACTLY what I did. Like most people, I scraped away the inner rubber leaving essentially a metal sleeve behind, thinking that was the inside bore exposed.
Why that didn't hit me like a 2x4 across the face I don't know. You can't always lead the thirsty horse to water....though you should be able to.
Procedure posted earlier by Doitmyself
1969 Ply GTX/RRs
