PH10060 oversized?
by bullwinkle - 02/18/20 11:36 AM
Toyota Sienna
by cb_13 - 02/18/20 10:05 AM
Larger fuel filter on Riding mower?
by dedonderosa - 02/18/20 10:03 AM
Castrol edge 0w40
by VQLT - 02/18/20 08:32 AM
Scrap value of this catalytic converter
by atikovi - 02/18/20 06:10 AM
How drunk do you have to be to do this?
by dishdude - 02/17/20 11:09 PM
At least they show you
by Jake777 - 02/17/20 10:04 PM
Ryan Newman update
by P10crew - 02/17/20 09:17 PM
Thoughts on 2015+ Kia Sedona?
by 92saturnsl2 - 02/17/20 09:16 PM
Quiet riding tire
by wolf_06 - 02/17/20 08:27 PM
Where did the Ryan Newman thread go??
by P10crew - 02/17/20 08:02 PM
2013 FX4 repair.
by marine65 - 02/17/20 07:36 PM
New gaming build shutting down on Metro 2033
by Cujet - 02/17/20 07:09 PM
Snapon
by P10crew - 02/17/20 06:51 PM
Conventional or Synthetic
by charmer37 - 02/17/20 06:49 PM
Jeep Wrangler 3.0L Diesel
by HighbrowHillbill - 02/17/20 06:36 PM
94 B4000 overheat Eureka
by HyundaiAbuser - 02/17/20 05:48 PM
PP Euro 5w40 SN Plus formulation VOA
by BurntMusic - 02/17/20 04:35 PM
TimN3QE, musclecarscott, tpap, ratt, jeffreytmann
70739 Registered Users
118 registered members (allepunta, 01VFR, 53' Stude, 750IX, 2K2AcuraTL, 9 invisible), 2,123 guests, and 28 spiders.
Topics301,605
Posts5,198,999
Members70,737
Mobil Delvac 1 ESP 5w-40 for 2011 TDI? #4107104 05/26/16 09:49 AM
R
ruleof72 Offline OP
R
Hi,
I have a 2011 Jetta TDI that has been showing increased Iron levels over the last few oil changes. The car is 5yr old with 44k on the odometer and out of warranty. Up until now I have been using the 5w-30 Mobil 1 ESP as it is the VW "approved" oil. But with the increasing Iron levels several people have suggested I use the Mobil 5w-40 TD as it might provide better protection. In my research I found the Mobil Delvac 1 ESP 5w-40 which seems to be more "DPF Friendly" than the regular Mobil 5w-40.
Does anyone have any feedback/experience on using this oil in a newer TDI, specifically as it relates to reduced metals levels?
'07 Mazda 3 Hatchback 2.3, 69,000 miles-Castrol GTX 5w20
'11 VW Jetta SportWagen TDI, 44,000 miles Mobil 1 5w30 ESP
Re: Mobil Delvac 1 ESP 5w-40 for 2011 TDI? [Re: ruleof72] #4107107 05/26/16 09:54 AM
E
edyvw Offline
E
Originally Posted By: ruleof72
Hi,
Iron in VW is nothing new. Does it show more then usual compare to other UOA?
I just purchased in NAPA like 25qt of Valvoline 5W40 MST. Sulfated Ash is at 0.76 compare to 0.6 in M1 5W30 ESP.
Actually Valvoline is pretty transparent what is in:
Valvoline PDS
11' BMW 328i xDrive 6MT (BMW TPT 5W30+OE filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
Re: Mobil Delvac 1 ESP 5w-40 for 2011 TDI? [Re: edyvw] #4107142 05/26/16 10:35 AM
R
ruleof72 Offline OP
R
Hi,
Valvoline PDS
The Iron has been going up. This last test showed 115ppm, the previous one (May '15) showed 92ppm and the one prior to that (May '14) showed 86ppm. The most recent OCI was 7k miles while the prior two were 10k and 9k. So it looks like the Iron is increasing even with fewer miles.
I'll check out the Valvoline as another option.
Re: Mobil Delvac 1 ESP 5w-40 for 2011 TDI? [Re: ruleof72] #4107438 05/26/16 05:20 PM
E
edyvw Offline
E
Be careful about that M1 Delvac ESP and VW TDI DPF.
Sulfated Ash is at 1. That is pretty high. It is DPF "friendly" but that is truck oil, and I am not sure whether there are different requirements when it comes to DPF. Truck have more space, so DPF can be engineered differently to allow more SA.
I would stay with 5W40 oils that are made for cars. Valvoline 5W40, Motul X-Clean 5W40, Pentosin 5W40.
Re: Mobil Delvac 1 ESP 5w-40 for 2011 TDI? [Re: edyvw] #4107830 05/27/16 06:55 AM
R
ruleof72 Offline OP
R
I went ahead and ordered some of the Valvoline Synpower MST 5w-40 from NAPA. With their "Reserve Online" sale I was able to get it for $4.99/quart instead of the $9.00 normal price. We'll see how it performs and adjust again if needed next year.
Re: Mobil Delvac 1 ESP 5w-40 for 2011 TDI? [Re: ruleof72] #4107949 05/27/16 09:31 AM
E
edyvw Offline
E
I will put Valvoline in my BMW 35d very soon. I have 2K before I take out ESP.
Probably will do UOA.
Re: Mobil Delvac 1 ESP 5w-40 for 2011 TDI? [Re: ruleof72] #4109593 05/29/16 08:19 AM
M
Moutainman31282 Offline
M
Just a thought. A lot of the newer oils have nearly 0 zinc and Diesel engine need zinc. Maybe think of adding a zinc additive to the oil if your gonna go with valvoline to help the internals of the engine
2003 F150 5.4l 201,000 miles
1999 Toyota Corolla 245,00 miles
2001 F150 335,000 miles
Re: Mobil Delvac 1 ESP 5w-40 for 2011 TDI? [Re: Moutainman31282] #4109611 05/29/16 08:34 AM
O
OVERKILL Online Content
Online Content
O
What? No they don't. Oils still have plenty of Zinc/Phos in them (ZDDP), particularly HDEO's. While the level has been reduced a bit, other additives have been used to make up for that reduction.
Re: Mobil Delvac 1 ESP 5w-40 for 2011 TDI? [Re: ruleof72] #4109705 05/29/16 10:39 AM
M
m37charlie Offline
M
High Fe/Al isn't uncommon in modern "clean diesels", my last 2 changes on my X5 35d showed Al 12/15, Cr 4 and Fe 76/89. In the middle of the current OCI I deleted emissions including EGR. I am currently using Delvac 1 LE 5W30. When that runs out I'll switch to M1 0W40 or D1 SHC 5W40.
I hope/suspect that absence of EGR will lower wear metal levels.
Charlie
05 Unimog U500/Unicat camper/Delvac 1 SHC ACEA E4/E5
09 BMW X5 35d/Delvac1 LE 5W30
88 Toyota OJ50LV OM314 motor D1 SHC
52 Dodge M37/Hercules diesel
Re: Mobil Delvac 1 ESP 5w-40 for 2011 TDI? [Re: m37charlie] #4110015 05/29/16 06:54 PM
E
edyvw Offline
E
Charlie
Who did your EGR/DPF/SCR removal?
Re: Mobil Delvac 1 ESP 5w-40 for 2011 TDI? [Re: ruleof72] #4114130 06/03/16 09:58 AM
M
messerchmidt Offline
M
had issues with sludge using mobil1 esp 5w30 in my parents ml350 bluetec. switched to liqui moly 5w30 (I think the 4600 series), no issues.
Re: Mobil Delvac 1 ESP 5w-40 for 2011 TDI? [Re: messerchmidt] #4114598 06/03/16 09:32 PM
E
edyvw Offline
E
Sludge????
What was OCI?
Re: Mobil Delvac 1 ESP 5w-40 for 2011 TDI? [Re: edyvw] #4114639 06/03/16 11:01 PM
M
m37charlie Offline
M
Charlie
Malone tuning sold me the parts. A BMW shop in Wasilla did the work.
Re: Mobil Delvac 1 ESP 5w-40 for 2011 TDI? [Re: m37charlie] #4115690 06/05/16 09:27 AM
E
edyvw Offline
E
Thanx man.
Re: Mobil Delvac 1 ESP 5w-40 for 2011 TDI? [Re: ruleof72] #4116955 06/06/16 02:12 PM
Z
Zambee500 Offline
Z
I know OP already bought the Valvoline SynPower MST, so this may be a moot point now. But isn't the Mobil 1 ESP "Formula M" more DPF-friendly and in 5w40? Or is it no longer easy to find at retail? I thought it had similar ash as the 5w30 Mobil 1 ESP, but came in 5w40 to meet the Mercedes ("Formula M") spec. Rumor at one time was the Dodge dealers sold it at a reasonable price for the Dodge Sprinter diesels with the Mercedes oil spec.
2005 Volkswagen Passat GLS TDI
2009 Volkswagen Routan SEL (Chrysler 4.0L V6)
