Fury -Wilder 3?
by pbm - 02/23/20 06:41 AM
toro super recycler
by passgas55 - 02/23/20 06:05 AM
Chain style for ag tires
by puma4440 - 02/23/20 04:25 AM
2014 GMC Terrain 2.4L AWD
by Char Baby - 02/23/20 02:06 AM
Conventional VS Synthetic In The Winter Months
by BlueOvalFitter - 02/23/20 01:36 AM
Paint Splatter
by rrretiree7 - 02/23/20 12:54 AM
The Jeep Made it to 150k Miles - Storytime
by Nick1994 - 02/23/20 12:54 AM
Supertech vs Dexcool
by WA1DH - 02/22/20 11:44 PM
Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
Markovchain, o_s, naterbomb, Jimiii, jb5150
70784 Registered Users
82 registered members (Bighorn2500, BAJA_05, BigCahuna, atikovi, AdditiveOCD, Astro_Guy, 9 invisible), 1,424 guests, and 17 spiders.
Topics301,818
Posts5,203,252
Members70,784
Steak-House Burgers #4106749 05/25/16 08:53 PM
sleddriver Offline OP
Steak-House Grilled Hamburgers
Given the recent discussions on food prices and meat, I thought I'd post this recipe adapted from the May/June 2011 issue of Cook's Illustrated.
Randall's usually always has a sale on meat. Recently picked up a 4# chuck roast for $3/#, when their 80% gnd meat is $7/#. That makes no sense to me when you can easily grind your own in a Cuisinart. I also find nice sirloins marked down as well.
So I first sharpen my knife, then pull apart the roast and trim off all HARD fat. This doesn't add any flavor. Next I cube it into 2" x 2" pieces, spread it out single layer on a metal pan, then slide it in the freezer for about 25min. until the edges are beginning to harden. This prevents it from turning into MUSH/pulp when ground.
Gather all the HARD fat & scraps into a plastic bag.
Grind the meat in batches about 25% at a time. Don't overfill or crowd. Pulse about 15-20 times until the meat pieces are about the size of a small pebble, maybe 1/8" or so. Spread the ground meat onto the ice cold metal pan and repeat until you're done.
Spread the meat out evenly and look for blobs of white hard fat, sinew, silver skin, etc. Pick it out and dump into the plastic bag. When done, squeeze all the air out and stick it in the freezer until the trash goes out. This will keep it from stinking up your kitchen or trash can! (Just don't forget to remove it....)
So we've got pretty lean meat now and it's time to add some flavorful fat back in. You can use either bacon grease or butter, carefully warmed in the uWave. I pour a steady stream from one end to the other, then go down another row until evenly spread. Top off with fresh ground pepper & kosher salt. You can also add a little worchestire and skip the salt.
With the meat evenly spread out like this on an ice-cold metal pan, anything you add to it will already be evenly mixed in. You see pre-ground beef is already sticky, having been forced through a SS metal plate under HIGH PRESSURE. You get home, dump the mound into a bowl, add whatever-you-like to it, then begin squishing it to "mix" in the seasonings. This just makes it even tougher and results in domed hockey pucks with uneven seasoning: Hard, tough, thick burgers.
I use a burger form with an ID ~ 4" and about 1" thick. I gently scoop up the seasoned meat with a metal spatula, slide it into the form, then gently press it in with my fingers until even across the top. The finishing touch is to put a knuckle right in the center. (This is VERY important with pre-ground beef to prevent football-shaped patties from forming as everything shrinks).
Repeat and carefully slide the patties onto the same cold metal pan. These then go into the frig while I light the charcoal. (If you haven't used true charcoal chunks in awhile, give it a try. "Briquettes (sp?) aren't the same as us old guys remember: Less BTU's now and more junk!)
My Hasty-Bake keeps the meat grill fixed, while the charcoal grate moves up and down. For these, I set it about 5" below the meat, let the grill tines get really hot before putting on the patties.
These patties will be very, very delicate even when seared on both sides, so be careful. Remember: The goal is a tender, juicy burger...NOT hockey pucks.
I go about 4min/side, then carefully flip. Add a wire rack to your used metal pan and lay the finished burgers on top. Tent with foil.
I use the softest buns I can find (fresh, soft ciabatta rolls, kaiser rolls, etc.) and brown on the grill....about 45s for light brown grille marks. Flip them over to warm the other side for about 20s, then slide under the foil.
That's my version. CI's has you sear these in a hot skillet for two minutes then slide them into a pre-heated 300F oven on a wire rack set over a metal pan, until done to your liking.
This time around I was making green chili cheeseburgers, so I grilled several serano and one pablano pepper along with the meat until charred. I then sliced these up, made a pile in the center of the meat, then topped with blue cheese. Geniune Swiss also works well. You can then either fire up the broiler to melt the cheese or return to the grille, away from the fire, close the lid and wait for 5 minutes.
One very important thing: I like to buy a pound or two of thick-sliced meaty bacon along with the chuck. No sense letting a good fire go to waste!
Since the Hasty-Bake has the moveable fire grate, I drop it to the bottom, spread out the coals evenly, then lay down a pound of bacon to slowly cook/smoke with some pecan wood/nuts spread over the coals. I like to add a bit of freshly gnd black pepper to each piece. Set a timer to about 8min. then check. You'll have to adapt this to your style of grille, charcoal/gas, etc. Don't burn it though and move it around to ensure even cooking.
So by now you've chowed down on the first burger and eagerly awaiting #2. Add bacon to that one...and the next.
Be sure to fully support the back end of the bun & sides before biting down. These patties are so tender, they're likely to "squish out" sideways. But oh the taste!......tender, beefy, deep, rich...it's a shame to put too much on it, so try at least one "neat".
Finally, CI has an interesting "burger sauce" for these:
3/4 cup Mayo
2 Tbl soy sauce
1 Tbl dark brwn sugar
1 Tbl Wooosh (Worcestershire)
1 Tbl minced chives (or scallions or shallots)
1 medium garlic clove, minced
3/4 tsp fresh gnd blk pepper.
I was surprised how good this was. Nice, beefy, steak-y, deep flavor.
Both grilled mushrooms & grilled onions would go great along with either blue cheese or Emmentaller swiss. I enjoy a deep rich beer with these burgers like Shiner Bock.
Prosit!
Cheers1
1998 Volvo V70 T5 228,880 mi. Original Owner.
M1 10W-30 HM
"It's never a mistake to buy tools, defined broadly. They're not a cost, they're an investment." - J.B. Peterson
Re: Steak-House Burgers [Re: sleddriver] #4106766 05/25/16 09:06 PM
Chris142 Offline
Yummo!
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Steak-House Burgers [Re: sleddriver] #4106914 05/26/16 05:03 AM
K
Kestas Offline
Global Moderator
Global Moderator
K
In college, my roommates and I found it was cheaper for us to make our own ground beef than buying it. Still true. I still have a couple meat grinders.
Re: Steak-House Burgers [Re: sleddriver] #4106918 05/26/16 05:15 AM
P
Pop_Rivit Offline
P
Nicely done. I've added pork cutlets to the grind in order to add some extra flavor. It's always enjoyable to experiment and see what you can add to pump up the flavor profile a bit.
Far, far better than the premade burgers purchased in the store, or the ground beef that comes in a tube.
Re: Steak-House Burgers [Re: sleddriver] #4106940 05/26/16 05:52 AM
A
AirgunSavant Offline
A
Thanks for all the detail and pictures!!!!!!!!!!
Re: Steak-House Burgers [Re: sleddriver] #4106958 05/26/16 06:23 AM
E
Eosyn Offline
E
You need to post a video of this tutorial! I'm always looking for new ideas/ways to grill meat (using charcoal grill, of course).
02 Toyota Celica GT: 198k, VML 5W30/Denso filter
05 Toyota Corolla LE: 149k, VML 5W30/Denso filter
15 Chevy Malibu LT: 46k, VML 0W20/Denso filter
Re: Steak-House Burgers [Re: sleddriver] #4107095 05/26/16 09:30 AM
V
Virtus_Probi Offline
V
Those burgers sound great, but that is a lot of work for a lazy bum like me...I'd just be driving to 5 Guys, instead (too bad In N Out is not around here).
I'll bet your guests love them if you make them for gatherings!
2014 Forester XT, 111000 miles
Last Change;
M1 0W30 AFE
Tokyo Roki 15208AA170 filter
Re: Steak-House Burgers [Re: Virtus_Probi] #4107656 05/26/16 09:37 PM
H
HTSS_TR Offline
H
Looks great but too much works for me too. In&N&Out is less than 2 miles from home, 5 Guys is 6-7 miles.
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
"Throwing food away is like stealing it from the poor and hungry" Pope Francis
Re: Steak-House Burgers [Re: sleddriver] #4107819 05/27/16 06:36 AM
stockrex Offline
Good job, those burgers look tasty!
I used to go to my orthodox greek butcher and get a 30 lb loin which he would cut half in steaks and half I would have ground.
the only problem was, the darn ground beef was too lean.
cost me $5/lb
Ridgeline, Dmax, Ford 3.5
Oil Whisperer!*Fear the DINO*
Re: Steak-House Burgers [Re: HTSS_TR] #4107927 05/27/16 09:06 AM
G
Garak Offline
G
I agree, looks fantastic, though! A couple grocery stores do sell packages of nice plain fresh patties or seasoned patties, two or four, at a decent enough price that are easy to throw on the grill really quickly. Being by myself, I don't need to buy pounds of ground beef or boxes of patties, and nothing beats fresh.
Plain, simple Garak.
Re: Steak-House Burgers [Re: HTSS_TR] #4108916 05/28/16 11:56 AM
It doesn't take as long as you think, especially if you regularly cook for yourself.
FF fare isn't even close to these.
M1 10W-30 HM
