Essex Engine Plant (Canada)
by BlueOvalFitter - 01/26/20 03:18 AM
Mopar oil bottles
by Franz - 01/26/20 12:47 AM
Ultra-rare barn find!
by Toy4x4 - 01/26/20 12:11 AM
2015 Hyundai Genesis 5.0L Review
by Nick1994 - 01/25/20 11:56 PM
My doggie had a rough week
by Chris142 - 01/25/20 11:26 PM
Delivery meal kit review - Dinnerly vs HelloFresh
by pezzy669 - 01/25/20 10:32 PM
Eotech Vudu scopes
by OVERKILL - 01/25/20 10:10 PM
'12 Civic burning oil after switch to M1
by sr20detfwd - 01/25/20 09:33 PM
Wix/NAPA Gold and M+H
by Uphill_Both_Ways - 01/25/20 09:06 PM
New seafoam oil stabilizer at AZ
by Chesterr - 01/25/20 08:13 PM
In 3 hours - 730 days and counting
by OVERKILL - 01/25/20 08:12 PM
Pig Parker!
by dishdude - 01/25/20 07:58 PM
NGK Conventional vs. Ruthenium Plugs
by doitmyself - 01/25/20 07:58 PM
Container or funnel?
by Philthy_Phil - 01/25/20 07:24 PM
AC Delco filters at Amazon as little as $1.07
by jayjr1105 - 01/25/20 06:22 PM
Excessive moisture in oil
by mb32 - 01/25/20 05:47 PM
Cover for Jeep + Trailer
by kehyler - 01/25/20 05:34 PM
Low VI gear oils
by dparm - 01/25/20 05:28 PM
kwashabcp, ronster, BackToReality, Scopeman, M635_Guy
70527 Registered Users
30 registered members (Bookmaker, bachman, blufeb95, brages, bbhero, BlakeB, 4 invisible), 984 guests, and 24 spiders.
Topics300,571
Posts5,178,490
Members70,527
Help - transmission filter does not fit the slot! #4106532 05/25/16 05:06 PM
69GTX Offline OP
Doing my trans filter for the first time on this car (actually my first ever) and I can't get the filter seal to seat into the slot.
The new WIX 58822 is the the right filter for my 2002 (AX4N). The old filter that come out was pretty grimy as was the bottom of the pan. I expected the old seal to remain in the bore and I wasn't disappointed. I had a pick and needle nose pliers to pry it out as the procedure suggested. But there were no metal rings in the seal. It looked like plain old soft orange rubber. Maybe the plastic aged and it softened up. Normally, these seals should pop out or come out in one piece. I spent an hour picking rubber pieces off the bore, then cleaning it up with wire brush and round file.
According to the procedure the filter should just pop up easily into its seat. It wasn't moving into it at all for me. Not even enough for the filter to hang in position on its own. I then tried some force with a rubber mallet and piece of wood. Nope. Then I tried the same thing with a small jack and no luck. In fact the car started to lift and that seal wouldn't slip into the bore.
Measuring the old and new filter dimensions the filter necks are identical. But this new seal looks wider to me. It's made of green plastic.
I did not expect the filter to screw me up. My other car is now blocked in the garage so I can't move the cars to go get another one. I could probably push the car off the ramps into the road and then push back off to the side. But would need to seal the transmission again to drive the car back onto the ramps.
Suggestions on the seal? I can just not put the filter on for now and do that in 1-2 days when I figure out what's up with the seal. Or I can cut the new seal off and use teflon tape or something to seal the neck for now? What's the risk for seal particles to start degrading and floating around the transmission? The width of that seal on the filter neck is approx 1/32", so that's a lot of taping.
I spent a lot of time making sure I knew the ins and outs of this filter change and flush....to no avail.
Lincoln filter and flush procedure
2001 Lincoln Cont 4.6L DOHC/ 50K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Help - transmission filter does not fit the slot! [Re: 69GTX] #4106533 05/25/16 05:13 PM
P
Panzerman Offline
P
As long as you got the old ring and seal out. Sometimes you really have to pry it out with a screwdriver. The new one should just snuggly in with very little force. Lube up the filter seal. You could try inserting the seal by itself then pushing the filter into it. I've done that before. It shouldn't take alot of pressure.
2006 Dodge Ram 2500 Hemi 4x4
2016 Dodge Challenger Scat Pack
Re: Help - transmission filter does not fit the slot! [Re: 69GTX] #4106534 05/25/16 05:14 PM
SirTanon Offline
Does your new filter look like this:
I had the same transmission in my 2003 Mercury Sable, and that's the filter I used when I did the change. Should go in without too much hassle if that's what you're using. If it looks different, then if I were you, I'd find an Autozone nearby and go buy a kit.
2013 Nissan Altima SV - 2.5 liter/CVT - 125,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 68,000mi
2010 Ford Fusion - 274k mi - SOLD
Re: Help - transmission filter does not fit the slot! [Re: 69GTX] #4106536 05/25/16 05:16 PM
P
Panzerman Offline
P
After reading your post again. I think the ring is still in there. It's in the hole. Run a screwdriver around and a hook driver if you have one. They get pretty stuck up there and will not come out easily.
Re: Help - transmission filter does not fit the slot! [Re: Panzerman] #4106542 05/25/16 05:27 PM
69GTX Offline OP
Sir Tanon, that's the filter. It's identical in all respects to what came out. The only difference is the new one has a seal left, and the old seal came off in the bore. The filter came out very easily, minus the orange seal. Like I said, it's like soft rubber. I worked that bore for an hour to remove all traces of orange rubber. It's smooth metal now. The old filter w/o a seal wobbles easily in that bore and will not stay up. So I'm pretty sure all the old seal is out.
Tried to swivel the seal off the new filter but it didn't budge at all. I can wrap with cloth and apply vice grips and see if it pops out.
1969 Ply GTX/RRs
Re: Help - transmission filter does not fit the slot! [Re: 69GTX] #4106554 05/25/16 05:41 PM
doitmyself Offline
That is very odd. There are tons of google hits and even You tube videos showing a medal ring as part of the rubber seal. I.E. http://www.taurusclub.com/forum/98-solut...hange-ax4n.html Excellent before and after pics of the seal and hole. The Youtube video shows the new filter fitting up into the hole with very little pressure.
Any indication that someone inserted the wrong filter into the box??
Good luck.
Picture from my link:
It seems that many just scrape out the inside rubber part of the metal/rubber seal:
quote:
"F that green seal! Here's a little note: it's a rubber coated metal piece. I thought the green piece had compressed and melted to the trans housing. I scraped endlessly trying to clear all the green off and cleaning the area. I was really [censored] it didn't come out in one piece. The new filter would not fit! It was too big to go in the hole in the trans. I was really [censored]. We tried using petroleum jelly to slide it in, but that didn't help. So out came the BFH.
I was beating on the new filter trying to get the new filter in and cursing NAPA for designing a poor part and cursing the write-up for making it look so easy. So the filter went back to NAPA and got my money back after explaining to them it wouldn't fit. Then went to AutoZone and got a generic trans filter kit (made by Champion Labs in Taiwan). Tried to install that and beat on it still and it still wouldn't go on. At this point, my dad gave me the ol' "I told you so" speech and how I should have taken it to a shop. I'm kind of starting to regret it too since if I can't get this thing back together, I'd have to get it towed to a shop and then lose a day at work.
Then looking at the new filter I see some metal shining where the green had broken at the top from the beating. Well, I felt like a retard. I took a small screwdriver, jammed it at the top of the "trans housing" in the hole and the stupid sleeve popped out. God I felt stupid. The write-up made it sound like it was a large rubber piece that would come by prying from the bottom! Anyways, got that piece out, stuck the filter in (and kicking myself for getting rid of the NAPA filter which seemed like better quality), and popped the pan back on."
With seal removed:
Re: Help - transmission filter does not fit the slot! [Re: 69GTX] #4106559 05/25/16 05:50 PM
69GTX Offline OP
Got the seal off and tried it into the bore by itself. While it goes in to the first flange seat, there's half of it sticking out. When I try to put filter on it, it can't support that weight and the filter falls. Tried that seal on the old filter, same result. So it's the seal. Even tried hammering it up with a board across it. Seems like it's only 1/2 way up into position. I would think that seal should fully disappear once fully into position.
I tried the seal in both orientations and it only stays with the thicker side in first. The other end has a notched ring. I'm not sure which of those should be the seal point. The notched thinner end was oriented down when the filter was received.
I thought this might be the first time the trans filter came out but didn't see the factory dip stick plug floating around in there.
1969 Ply GTX/RRs
Re: Help - transmission filter does not fit the slot! [Re: 69GTX] #4106563 05/25/16 05:52 PM
T
Trav Offline
T
The .490" green seal does not replace the orange seal, it wont fit.
Some seals are .420" it sounds like yours uses the smaller diameter. Take a trip to the parts store, don't try and force it in.
Re: Help - transmission filter does not fit the slot! [Re: 69GTX] #4106568 05/25/16 05:57 PM
69GTX Offline OP
Thanks for that link Doitmyself. I'll look again but I was poking and prying with a tiny screw driver and metal mouth pick and I never saw metal as part of the seal. I have the same new green plastic seal as that video shows and it looks 100% hard but pliable plastic. The procedure I original posted shows the same issue with the metal ring of the seal separating. Never saw that. The bore interior shows the double stepped flanges.
I'll go out and look at it all again. The fact that the seal moves easily to new and old filter says it's not the filter. It's either the wrong seal, or me screwing up somehow.
1969 Ply GTX/RRs
Re: Help - transmission filter does not fit the slot! [Re: Trav] #4106571 05/25/16 05:59 PM
69GTX Offline OP
I lifted the front of the car off that green seal with my jack. That was plenty of force....lol. So that might be it. So the green one might be for different AX4N's? What came out my car was orange. If I didn't know better I'd have swore it was just orange putty.
1969 Ply GTX/RRs
Re: Help - transmission filter does not fit the slot! [Re: Trav] #4106573 05/25/16 06:00 PM
doitmyself Offline
Grrrr. I hate when this happens! The difference of a DIYer and a mechanic with many hours under the belt! LOL. Good of you to pop in TRAV and set things straight. I lucked out when I did my daughter's car...green seal out, green seal in.
Page 3 of this link has the two Ford part numbers: http://www.shinseiauto.com/japanese/transtar/usfordax4n04.pdf
86010E Orange/ 86010H Green
Re: Help - transmission filter does not fit the slot! [Re: 69GTX] #4106578 05/25/16 06:05 PM
simple_gifts Offline
Check your PM.
2004 Prius; 126K; ALM
2007 Yaris 103K ATM
2006 B2300;137K;ALM
Was driving an ox cart; Now on the USS Enterprise
Re: Help - transmission filter does not fit the slot! [Re: 69GTX] #4106583 05/25/16 06:12 PM
T
Trav Offline
T
There are a few different ones, They make a .490" green and orange but one in thicker than the other, there are also the .420" ones.
Orange out orange in, green out green, in don't mix them. the correct seal will fit snug but go right in with a little pressure.
AFAIK there is none that uses a metal lip seal that gets installed in the case first in that unit.
Re: Help - transmission filter does not fit the slot! [Re: simple_gifts] #4106585 05/25/16 06:17 PM
69GTX Offline OP
The dimensions on the green seal are approx 1-1/8" OD. The thickness is nearly 1/8th inch. Under a magnifying glass I see the alternating metal strips in there. It's possible I removed every bid of old orange plastic and left just the shiny metal part. The bore is pretty straight the way it is now. If something else still needs to come out, that would leave another lip or flange in that bore. I pried some more in there with the metal pick and there's nothing to grab on to. It feels like a smooth metal bore. With all the poking I did in there today I probably damaged some of the seating surfaces as it is.
I'll call West Springfield Auto Parts in the morning and have them check their inventory and this issue of green vs. orange.
1969 Ply GTX/RRs
Re: Help - transmission filter does not fit the slot! [Re: 69GTX] #4106601 05/25/16 06:29 PM
doitmyself Offline
The O'Reilly page shows your originally purchased WIX 58822 as an orange seal, as does the WIX site. So, maybe you got the wrong filter in the right box? If that's the case, they should supply a new one for free.
http://www.oreillyauto.com/site/c/search...8&make=Ford
Check your box before leaving the store. Good luck!!!! Relax tonight and chock it up to "the way it happens sometimes". I'll have a shot of scotch tonight on your behalf.
