Oil weight and Oil Grade
by Snagglefoot - 01/21/20 07:11 PM
Which air filter for RAV 4 Hybrid
by NH73 - 01/21/20 06:44 PM
Finding a good "cold weather" vehicle?
by Vern_in_IL - 01/21/20 06:15 PM
Bough NGK Ruthenium sparkplugs
by cronk - 01/21/20 06:07 PM
HF 30% Off $10 and Under
by TheLawnRanger - 01/21/20 06:02 PM
Stolen Battery-New one on Me
by bunnspecial - 01/21/20 05:29 PM
2006 Acura TSX Buying Advice
by maverickfhs - 01/21/20 04:35 PM
Castrol GTX Diesel 15W-40, CK4
by HDoilDude - 01/21/20 04:30 PM
Combo of P0068 and P307A
by Alfred_B - 01/21/20 04:30 PM
Are the plastic battery trays necessary?
by littlehulkster - 01/21/20 03:18 PM
Amsoil ATV/UTV Powertrain Fluid
by IowaFord - 01/21/20 02:13 PM
Motorcraft FL500s 3,630 miles.
by mpgo4th - 01/21/20 01:36 PM
Xcel Class Action Suit
by John_K - 01/21/20 12:33 PM
RV Freightliner Cummins ISB 6.7 oil question
by 1978elcamino - 01/21/20 11:48 AM
Why I became a pilot and not a doctor...
by jetman - 01/21/20 10:52 AM
Wrong oil or not ?
by M119 - 01/21/20 10:48 AM
30 monograde
by mpack88 - 01/21/20 10:15 AM
Extended life destroys copper?
by mpack88 - 01/21/20 09:49 AM
IowaFord, Origami99, reylafo, PastPresMike, RedBeard83
70497 Registered Users
134 registered members (4WD, 2010Civic, 53' Stude, 87sammy, AC1DD, 11 invisible), 2,428 guests, and 29 spiders.
Topics300,411
Posts5,175,178
Members70,497
Toyota Red long Life vs Pink Super Long Life? #4106117 05/25/16 09:50 AM
Drew99GT Offline OP
I've read mixed reviews of whether these 2 coolants are fully compatible. Reason I ask is, I'm getting the timing belt and water pump done on my Corolla this week and the tech that's doing it said he has the Pink Super Long Life in stock but not the older Red. I don't really want to fuss with doing a super duper coolant flush procedure to get the pink out and refill with red. Will the 2 mix OK, or should I flush it? The car has only used the older red formula it's entire life.
Thanks!
Re: Toyota Red long Life vs Pink Super Long Life? [Re: Drew99GT] #4106135 05/25/16 10:04 AM
M
mikered30 Offline
M
Per a Toyota TSB they are compatible. Just be careful with your ratios.
Re: Toyota Red long Life vs Pink Super Long Life? [Re: Drew99GT] #4106142 05/25/16 10:12 AM
V
Vladiator Offline
V
Pink fluid makes water pump seals leak. Many toyota shops switch even newer cars to the older Red toyota fluid. I did too in all my toyotas.
Re: Toyota Red long Life vs Pink Super Long Life? [Re: Vladiator] #4106174 05/25/16 10:49 AM
N
nobb Offline
N
Source?
Re: Toyota Red long Life vs Pink Super Long Life? [Re: Vladiator] #4106185 05/25/16 10:57 AM
Drew99GT Offline OP
THAT is exactly what I have read on Toyota Nation and why I'm hesitant to use the pink stuff.
Re: Toyota Red long Life vs Pink Super Long Life? [Re: Drew99GT] #4106207 05/25/16 11:31 AM
J
JMJNet Offline
J
I used Zerex Coolant for Asian vehicle. So far no issues.
I know that is not the question but a good alternative for the one sold at Toyota.
  • 2017 Toyota Sienna
Re: Toyota Red long Life vs Pink Super Long Life? [Re: Drew99GT] #4106216 05/25/16 11:40 AM
Chewie Offline
I also just picked up a jug of Zerex Asian from Walmart for $12+tax.
2002 Lexus GS300 | 2JZ-GE | M1 HM 10W-40 | XG3600
Re: Toyota Red long Life vs Pink Super Long Life? [Re: nobb] #4106221 05/25/16 11:44 AM
V
Vladiator Offline
V
Source?
Google "toyota super long life coolant leaks" and start reading. Camry, Rav4, Tacoma, Sienna, and every other model.
Re: Toyota Red long Life vs Pink Super Long Life? [Re: Vladiator] #4106280 05/25/16 12:32 PM
drtyler Offline
My '04 Tundra was delivered new with the pink stuff. 167,000 miles and the water pump isn't leaking.
Replaced the timing belt at 90,000 miles, and drained & replaced the coolant then. But the pink stuff went back in.
Source?
