Chicken Marsala Recipe Help
by 97prizm - 04/03/20 02:02 PM
Oil Filter Removal
by Kansas_Ron - 04/03/20 01:24 PM
Pressure regulator made in USA
by rainman49 - 04/03/20 01:08 PM
mitsubishi outlander
by ernied - 04/03/20 12:43 PM
WM - Pennzoil Platinum $18.68
by The Critic - 04/03/20 12:13 PM
Going from a PAO to a Ester base MT oil
by Bill_W - 04/03/20 11:54 AM
Spring Cleaning
by Mad_Hatter - 04/03/20 11:40 AM
Starting Over - 2013 Prius
by Greg L - 04/03/20 11:15 AM
Glue for dovetail joints
by spasm3 - 04/03/20 11:08 AM
In my face "wake up" call
by Kira - 04/03/20 10:58 AM
repairing old stereo equipment
by Donald - 04/03/20 10:44 AM
Valvoline Syn. Grease 14oz tube
by zfasts03 - 04/03/20 10:39 AM
WIX XP oil filter leaking....
by dkryan - 04/03/20 10:36 AM
K&N PS 1017 VIRGIN FILTER CUT OPEN
by 53' Stude - 04/03/20 09:56 AM
Got bored so I fired up the smoker
by BeerCan - 04/03/20 09:43 AM
VIRGIN M1-209A CUT OPEN
by 53' Stude - 04/03/20 09:39 AM
Roasts: what kind do you folks buy?
by 53' Stude - 04/03/20 09:12 AM
FRAM TG 3600 VIRGIN FILTER CUT OPEN
by 53' Stude - 04/03/20 08:09 AM
TJim, Andreeas1978, lawmanracing14, ebarker, Knop
71082 Registered Users
110 registered members (007, 97prizm, 928, 16HC, 53' Stude, 12 invisible), 2,037 guests, and 19 spiders.
Topics303,525
Posts5,236,913
Members71,082
Hypothetical Question On Incorrect Filters #4105848 05/25/16 12:18 AM
T
Triton_330 Offline OP
T
I've heard alot of stories about quick lubes and what-have-you's that will just throw on any filter that has the same threads and gasket size as needed, even if the filter isn't the correctly specified filter. This incorrect filter could then be seen by the owners, whom may not know any better, and say they cross compare it one day if they decide to change their own oil, put on a filter of the same size (fits, but not the correct filter).
An example could be someone who puts a Fram XG10575 or XG10060 on a Ford modular (4.6L/5.4L) instead of an XG2.
Could using either of those filters, which would indeed fit on a modular, cause any issues?
In my mind, I have two conflicting views about it. GM's newer pickups use the PF48 or PF63 (which cross ref to the XG10060 and XG10575), so obviously a small filter can be utilized on a V8 without issue. But on the other hand, Ford 4.6L and 5.4L engines use a much larger filter.
Could using the smaller filters on a Ford modular actually cause any issues?
~ Triton
2001 Ford F-150 XLT 4x4 5.4L V8 ~132k miles
-> PPHM 5w-20 w/Fram Ultra
1989 Chevrolet Camaro RS 5.0L TBI V8 ~48k miles
-> Milesyn SB 5w-30 w/Puro Boss
Re: Hypothetical Question On Incorrect Filters [Re: Triton_330] #4105849 05/25/16 12:22 AM
2015_PSD Offline
Probably nothing would happen. Case in point is Ford uses a "one size fits many" Champion made filter from the factory. I had the same size filter on my 2010 FX4 that I had on my 2014 Explorer and one takes an XG2 and the other an XG10575.
2019 o)|||||(o Rubicon Wrangler Unlimited 3.6L V6 [Castrol Edge + Hastings]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum + Mann filter]
Re: Hypothetical Question On Incorrect Filters [Re: 2015_PSD] #4105880 05/25/16 02:14 AM
Superflop Offline
I doubt it. The oil filter on later crown vics (4.6l) is tiny the one on an f150 is larger xg2 OR xg8a. Xg3614 is stock on my wagon but I run an XG8A.
2002 saab 9-5 2.3t wagon
2014 dodge grand caravan
Re: Hypothetical Question On Incorrect Filters [Re: Triton_330] #4105962 05/25/16 07:23 AM
K
Kruse Offline
K
Most likely wouldn't hurt a thing.
There is one scenario that could happen that could financially affect the owner. If the filter would fail and cause an engine failure, the filter manufacturer would deny any claims because they could say that an incorrect filter was installed. Howver, this instance would be rare.
Re: Hypothetical Question On Incorrect Filters [Re: Kruse] #4105988 05/25/16 07:52 AM
K
Kira Online Content
Online Content
K
This condition may or may not apply to your situation.
"Matching" oil filters can have different bypass pressures. Without going into part numbers, my friend's '08 Nissan Frontier 4.0l V-6 has, among others, 2 Hastings listings. Maybe the difference comes from a roundabout way like a diesel made from the same block or change in oil spec.
The difference, as stated above, is bypass pressure. We all know this can and does kick in at startup/relevant to temperature/relevant to oil thickness.
It can also come into play as the filter nears "dirt full" condition during hard acceleration.
I also encountered this whilst researching my sister's Skyaktiv Mazda engine filters. The older filters fit just fine but the Skyaktiv, with their redesigned engine and 0W-20 synth. oil has a different bypass pressure.
Cheaper filter companies crossed the old style to the new engines immediately.
Hastings and WIX needed 6 months to create a listing so that's what I'll buy FOREVER.
No monkey business for me.
Re: Hypothetical Question On Incorrect Filters [Re: Triton_330] #4106066 05/25/16 09:56 AM
R
RF Overlord Offline
R
I don't think the filter's physical size is especially important. Decades ago, Ford used the FL1A on just about everything, and it was huge. Now they use the much smaller FL820S and FL500S and modular motors last a very long time.
Having said this, I would never install a filter that the engine manufacturer didn't bless. I would hope anyone changing their own oil would use what is recommended in the owner's manual (or proper equivalent) and not simply trust that the filter on the car was correct.
Supercharged '03 Mercury Marauder - Trilogy Motorsports #61
PP 5W-30 / MC FL820S
'04 Grand Marquis LS Limited Edition - MC 5W-20 / FL820S
'00 Grand Marquis GS - being resurrected. Slowly.
