Fury -Wilder 3?
by pbm - 02/23/20 06:41 AM
toro super recycler
by passgas55 - 02/23/20 06:05 AM
Chain style for ag tires
by puma4440 - 02/23/20 04:25 AM
2014 GMC Terrain 2.4L AWD
by Char Baby - 02/23/20 02:06 AM
Conventional VS Synthetic In The Winter Months
by BlueOvalFitter - 02/23/20 01:36 AM
Paint Splatter
by rrretiree7 - 02/23/20 12:54 AM
The Jeep Made it to 150k Miles - Storytime
by Nick1994 - 02/23/20 12:54 AM
Supertech vs Dexcool
by WA1DH - 02/22/20 11:44 PM
Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
Chaucha, UofA, Jeffrey78, Markovchain, o_s
70787 Registered Users
87 registered members (53' Stude, 4WD, 55hambone, Aero540T, aba4430, 8 invisible), 1,793 guests, and 17 spiders.
Topics301,818
Posts5,203,284
Members70,787
2009 Honda Civic Cooling fan running continuously #4105679 05/24/16 07:31 PM
Doog Offline OP
Radiator fan runs continuously AC blows warm...cool maybe. Where do I look?
I know nothing about AC systems. shocked
Re: 2009 Honda Civic Cooling fan running continuously [Re: Doog] #4105696 05/24/16 07:43 PM
R
Rand Offline
R
?? if your ac is on the fan will be on.. what are you asking?
Better description of problem?
Re: 2009 Honda Civic Cooling fan running continuously [Re: Doog] #4105698 05/24/16 07:43 PM
CT8 Offline
For what it costs find a good AC shop to diagnose the problem due to the AC being warm.
2015 F150 2.7
2018 F350 6.2
Re: 2009 Honda Civic Cooling fan running continuously [Re: Doog] #4105699 05/24/16 07:44 PM
X
xxch4osxx Offline
X
Low refrigerant possibly.
2015 RAM SXT Crew Cab 5.7 with 6 speed tranny.
2008 Mazda 3 GS Sport Hatchback 5sp MT (Girlfriend's car)
Re: 2009 Honda Civic Cooling fan running continuously [Re: Doog] #4105702 05/24/16 07:46 PM
Mr Nice Offline
Your condenser fan always runs if your A/C is on.
Radiator fan cycles off and on.
Maybe a small shot of refrigerant from DIY can ?
Re: 2009 Honda Civic Cooling fan running continuously [Re: xxch4osxx] #4105742 05/24/16 08:31 PM
Bud_One Offline
+1 - that would be my best guess as well
20 Pilot LX - Factory Fill
14 Civic LX Sedan- Castrol Mag 0W-20,XG7317
05 Chevy Crew Cab 2500HD- QSUD 10W-30,PF61E
97 Accord EX Wagon- Napa PPSB 5W-30,Napa 21334
Re: 2009 Honda Civic Cooling fan running continuously [Re: Mr Nice] #4105863 05/25/16 12:01 AM
L
Lolvoguy Offline
L
Did that once to my 97 Escort. Provided A/C that was far colder and efficient than any Cadillac/ Volvo we rented.
When the A/C turns warm on the Focus, I'll probably do the same with it
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: 2009 Honda Civic Cooling fan running continuously [Re: Doog] #4105960 05/25/16 06:20 AM
M
madRiver Offline
M
Not sure if corrected by 2009, however Honda/Acura had ac relay problems (made in USA part smile ) in my 2007 mdx and had similar symptoms. It was a $9 fix to buy a new ac relay from dealer. Same issue wife's Subaru that mechanic did not diagnose testing everything. Spent $6 on aftermarket relay fine.
Just saying a cheap try before you take it in. Don't blindly add freon.
Re: 2009 Honda Civic Cooling fan running continuously [Re: Mr Nice] #4106040 05/25/16 08:08 AM
M
MarkM66 Offline
M
Little cars usually have just one fan.
Re: 2009 Honda Civic Cooling fan running continuously [Re: Doog] #4106043 05/25/16 08:10 AM
J
JMJNet Offline
J
If the AC relay is bad, the clutch will not engange.
So, check that first.
Next, you need to get what we call the AC Gauge Manifold.
This is used to measure the low pressure and high pressure of the AC system. They have to be correct depending on the ambient temperature. If not, then there is something wrong.
You need add some refrigerant to top it off and see if the pressure can go steady. If not, then there is a leak somewhere. You need to identify the leak and fix it.
Make sure the clutch can engange and not seizing after there are enough pressure of refrigerant.
If it seized, then you have to change the compressor or just the clutch depending if it is just the clutch.
Now, price of clutch is sometimes more than the whole compressor difference is you have to open the whole system when changing the compressor and you have to do the proper flush and vacuum and replace the dryer.
Then you have to decide if you want to change the condenser.
A lot of the newer design condenser is not flushable.
  • 2017 Toyota Sienna
Re: 2009 Honda Civic Cooling fan running continuously [Re: MarkM66] #4106065 05/25/16 08:54 AM
gathermewool Offline
This car has two fans.
14 Forester XT Touring FA20DIT (Cobb Stage 1)
Castrol Magnatec 5W-30 D1G2 + FU filter (72,320mi, 8/24/19)
15 Legacy Premium FB25
Magnatec 5W-20 + FU filter (47,300mi, 5/11/19)
Re: 2009 Honda Civic Cooling fan running continuously [Re: Doog] #4106188 05/25/16 10:59 AM
Doog Offline OP
My local shop has a "free AC performance check up" coupon on their website...going in tomorrow.
Re: 2009 Honda Civic Cooling fan running continuously [Re: madRiver] #4106387 05/25/16 02:22 PM
Doog Offline OP
where is the relay located?
Re: 2009 Honda Civic Cooling fan running continuously [Re: madRiver] #4106600 05/25/16 06:28 PM
Doog Offline OP
UPDATE Ok so I searched the internet on YouTube and found several videos about the dreaded relay.....so I figured WTH? Got one at AAP for $5.99 and VOILA!! The compressor came on and it started blowing cool...then colder...took it for a 5 mile ride...blowing cold...Thank You VERY Much!! thumbsup thumbsup
Re: 2009 Honda Civic Cooling fan running continuously [Re: Doog] #4107191 05/26/16 11:33 AM
2
2010Civic Offline
2
Nice!
2010 Honda Civic LX
Valvoline SynPower 5w-20 - Napa Gold oil filter
59,992 miles
