2019 Ram Battery Issue
by NYEngineer - 02/25/20 06:00 AM
belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
2019 VW Passat Trip Mileage
by Boomer - 02/24/20 01:13 PM
Changed my ATF, difference is crazy!
by cwilliamsws6 - 02/24/20 12:36 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
83 registered members (Arob, 1911CHAMPION, AurionX2, 1foxracing, Aero540T, Astro_Guy, 4 invisible), 1,717 guests, and 17 spiders.
Topics301,898
Posts5,204,937
Members70,798
This Radiator Looks Good to Me! #4105367 05/24/16 01:38 PM
M
Miller88 Offline OP
M
Weekend before last, had an off roading trip and my Jeep was on the warm side. I noticed the mechanical fan was pretty quiet, so I replaced it. That solved the temperature issues, but I noticed that the radiator was weeping a bit where it goes into the side tanks.
I'm going to be taking this to Rausch Creek off Road park - 220 miles south of here. Lots of hills on 81. I will be towing my popup camper. I always like having my vehicles in 100% operating condition.
On the suggestion of those here, I bought a 1800radiators.com radiator. When I went to remove the radiator from the bottom support and separate it from the AC condenser , I couldn't get it out.
After a while, I noticed that the little peg that goes into the lower support was bent. I bent it back straight and was able to get it out.
Once out, I noticed that it was really messed up! The AC condenser was also bent quite a bit. More than the Radiator in this picture, wish I had taken a picture. I left it alone, just fixed the mounts so I could put the new radiator in.
Backstory - this Jeep was in a head on collision when it was at 11000 miles and deemed a total loss. Significant frame damage and airbags deployed. There is some evidence of the frame being kinked back in to shape, but never had any problems. Doors on the left side and fender were OE replacements, paint matches, no odd panel gaps.
Apparently they forgot to check the radiator. But it's the original ... surprising that I never had problems.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: This Radiator Looks Good to Me! [Re: Miller88] #4105383 05/24/16 01:49 PM
Chris142 Offline
You can very easily straighten it by hand. We get new ones that are worse
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: This Radiator Looks Good to Me! [Re: Miller88] #4105389 05/24/16 01:53 PM
M
Miller88 Offline OP
M
I had to straighten this one a bit by hand and the support in order to get it out. I'm surprised it held for 13 years like this without having any problems!
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: This Radiator Looks Good to Me! [Re: Miller88] #4105400 05/24/16 02:07 PM
drtyler Offline
How does the radiator from 1800radiators.com compare?
Out of curiosity, does the new radiator have a country of origin label?
Re: This Radiator Looks Good to Me! [Re: Miller88] #4105411 05/24/16 02:20 PM
M
Miller88 Offline OP
M
Indonesia.
Jeep functions no different with the new radiator; I wasn't having any heat issues with the old radiator - I just noticed it started to weep and I wanted to change it before it failed. It still runs at 195F which is the temp of the thermostat I have.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: This Radiator Looks Good to Me! [Re: Miller88] #4105452 05/24/16 03:11 PM
4
440Magnum Offline
4
Aluminum cores will bend.... once. Or twice. Its repeated flexing that kills aluminum, since any movement at all causes a fatigue cycle. Steel won't fatigue unless it is flexed beyond its elastic limit, aluminum fatigues a little every time its bent no matter how small the bend (its not really elastic at all).
There's also a fair amount of compliance in the gaskets that hold the tanks to the core. I'm not surprised it held together, but it doesn't owe you a thing and I wouldn't feel bad about replacing it. :-)
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 XJ 4x4 4.0/AX15, '14 WK2 4x4 3.6/8HP
Re: This Radiator Looks Good to Me! [Re: Miller88] #4106016 05/25/16 07:29 AM
M
Miller88 Offline OP
M
I don't think anything on the vehicle owes me anything after what I have put it through ... and what it was put through before I bought it.
There's going to be some extended foot-to-floor time on 81 in PA while towing the popup. Have to make sure the cooling system is at 100%. Everything else in the cooling system has been replaced already.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: This Radiator Looks Good to Me! [Re: Miller88] #4106665 05/25/16 07:14 PM
DukeOfFrontenac Offline
Have fun at Rausch Creek! Rode dirt bikes up there for many years. Lots o rocks, but I guess that's what you're looking for....
Re: This Radiator Looks Good to Me! [Re: DukeOfFrontenac] #4107887 05/27/16 08:07 AM
M
Miller88 Offline OP
M
Yep. Not too many rock places around here.
Just need to replace the caliper and the shackles and Im' good to go!
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
