Oil weight and Oil Grade
by Snagglefoot - 01/21/20 07:11 PM
Which air filter for RAV 4 Hybrid
by NH73 - 01/21/20 06:44 PM
Finding a good "cold weather" vehicle?
by Vern_in_IL - 01/21/20 06:15 PM
Bough NGK Ruthenium sparkplugs
by cronk - 01/21/20 06:07 PM
HF 30% Off $10 and Under
by TheLawnRanger - 01/21/20 06:02 PM
Stolen Battery-New one on Me
by bunnspecial - 01/21/20 05:29 PM
2006 Acura TSX Buying Advice
by maverickfhs - 01/21/20 04:35 PM
Castrol GTX Diesel 15W-40, CK4
by HDoilDude - 01/21/20 04:30 PM
Combo of P0068 and P307A
by Alfred_B - 01/21/20 04:30 PM
Are the plastic battery trays necessary?
by littlehulkster - 01/21/20 03:18 PM
Amsoil ATV/UTV Powertrain Fluid
by IowaFord - 01/21/20 02:13 PM
Motorcraft FL500s 3,630 miles.
by mpgo4th - 01/21/20 01:36 PM
Xcel Class Action Suit
by John_K - 01/21/20 12:33 PM
RV Freightliner Cummins ISB 6.7 oil question
by 1978elcamino - 01/21/20 11:48 AM
Why I became a pilot and not a doctor...
by jetman - 01/21/20 10:52 AM
Wrong oil or not ?
by M119 - 01/21/20 10:48 AM
30 monograde
by mpack88 - 01/21/20 10:15 AM
Extended life destroys copper?
by mpack88 - 01/21/20 09:49 AM
IowaFord, Origami99, reylafo, PastPresMike, RedBeard83
70497 Registered Users
132 registered members (77GrandPrix, 4WD, 2010Civic, 53' Stude, 15 invisible), 2,617 guests, and 29 spiders.
Topics300,411
Posts5,175,197
Members70,497
Recent discovery of SatbiliTrack failure Mode #4105290 05/24/16 12:11 PM
MolaKule Offline OP
Global Moderator
Global Moderator
This past winter we had numerous intermittent StabiliTrack codes. Sometimes the steering wheel position sensor or wheel speed sensors and connectors can get flaky and throw these codes, but no fault was found with these.
GM had issued a TSB for this problem and reprogramming, but none of these codes made any sense.
The wife came hone Saturday after her trip to her mom's and said the '08 TrailBlazer had no AC, no PWR Windows, no guages, no radio.
I checked all of the pertinent fuses in both the Engine Compartment and those underneath the back seat and no blown fuses.
I hooked up my OBD-II scanner and no talky to the PCM, no codes.
I was fearing an Instrument Cluster and or CAN bus problem.
I unhooked the various Control Modules one-by-one.
It turned out that the OnStar module was partially shorting the CAN bus and pulling down voltages from the PCM.
Disconnected the OnStar module and wolla, everything worked again. Since we don't use it and never did, I did not replace it with a new $600.00 unit.
The CAN bus is great when you have various control modules scattered around the vehicle, but it only takes one module with a flaky CAN transceiver or cable fault to bring it down. When this happens, the PCM goes into its Default/Open-Loop mode so one can still drive the vehicle home or to the repair shop.
Charlie Eppes: "What do you think we should do now?"
Don Eppes: "The same thing when I was in school and I didn't know the answer – fake it." From NUMB3RS
Re: Recent discovery of SatbiliTrack failure Mode [Re: MolaKule] #4105297 05/24/16 12:16 PM
N
NateDN10 Offline
N
Voila.
2016 Mazda3 - 20,000 mi.
2011 Toyota Sienna - 100,000 mi.
Re: Recent discovery of SatbiliTrack failure Mode [Re: MolaKule] #4105316 05/24/16 12:39 PM
4
4wheeldog Offline
4
The NSA will be around to patch it back up. After all.....How will they monitor you, with the OnStar nonop?
Re: Recent discovery of SatbiliTrack failure Mode [Re: MolaKule] #4105343 05/24/16 01:09 PM
O
Oro_O Offline
O
Interesting point and information; thank you.
My mother has a 2007 Equinox she's had since new, and it has unpredictably thrown StabiliTrak codes since it was a year or two old. I do not think hers has OnStar, but perhaps I can use the CAN bus clue to find something causing it.
Most recently, my father and I poked around to diagnose increased oil usage. We re-connected some loose vacuum hoses and changed the front spark plug wires. It immediately through a StabiliTrak code when re-started. This led me to realize the StabiliTrak system itself likely had nothing to do with it.
Re: Recent discovery of SatbiliTrack failure Mode [Re: MolaKule] #4105373 05/24/16 01:47 PM
W
Wheel Offline
W
I know that controller area networks are cheap and reasonably simple, but there are better, albeit more expensive network solutions that don't fail this way.
2009 Subaru Legacy (N/A)
Quaker State Ultimate Durability and NAPA filter
Re: Recent discovery of SatbiliTrack failure Mode [Re: MolaKule] #4105384 05/24/16 01:49 PM
M
mr_boring Offline
M
I used to have a can bus problem but then I got married and had a kid and had to get a real job, so no more can bus for me. When I retire though, I'm moving to Colorado and it's on!!!! You can have all the can bus you want there!!!
EDIT - I should have made the move to Colorada an off topic disclosure!!!
Re: Recent discovery of SatbiliTrack failure Mode [Re: Wheel] #4105465 05/24/16 03:41 PM
MolaKule Offline OP
Global Moderator
Global Moderator
True, but this is a Vehicle CAN Bus conforming to SAE J1939.
https://en.wikipedia.org/wiki/SAE_J1939
Not exactly a fault Tolerant bus.
Recall in this case the OnStar module was doing two things, pulling down the Voltage supply line AND shorting the CAN Bus.
Re: Recent discovery of SatbiliTrack failure Mode [Re: MolaKule] #4106083 05/25/16 09:13 AM
DriveHard Online Content
Online Content
Actually, J1939 is usually only used in the heavy truck and off highway markets. I believe GM is following ISO J1850.
Smile, it increases your face value
2013 Fiat 500 Abarth mod heavy (my DD)
2018 Alfa Romeo Stelvio TI Sport (wife's)
2011 Silverado Crew Cab LT 6.2L/6spd (tow pig)
2007 Nissan Xterra (trail toy)
Re: Recent discovery of SatbiliTrack failure Mode [Re: DriveHard] #4106085 05/25/16 09:18 AM
Online Content
Ok, actually I think GM is using J1850 for the standard OBDII diagnostic communications, but has their own GMLAN for internal CAN communications and systems controls.
http://www.acdelcotechconnect.com/pdf/imtn_V16I109.pdf
Re: Recent discovery of SatbiliTrack failure Mode [Re: MolaKule] #4106170 05/25/16 10:39 AM
W
Wheel Offline
W
That's what I was getting at, CAN isn't fault tolerant. It has no intelligence in it to prevent one device from halting good communication. These networks could be built in a fashion more like a good TCP/IP/packet switching computer network.
This could provide some fault tolerance and security that is lacking.
The downside would be somewhat more cost.
Re: Recent discovery of SatbiliTrack failure Mode [Re: DriveHard] #4107211 05/26/16 12:04 PM
MolaKule Offline OP
Global Moderator
Global Moderator
Thanks for the Additional Info.
Yep, Bosch originally developed the CAN but everyone has their own flavor of SAE J1939.
Re: Recent discovery of SatbiliTrack failure Mode [Re: Wheel] #4107215 05/26/16 12:08 PM
MolaKule Offline OP
Global Moderator
Global Moderator
Agreed, in the Aerospace industry we designed-in some very good high speed FT buses.
Maybe someone did an analysis and decided this was good enough based on times to fault occurrence.
