Castrol edge 0w40
by VQLT - 02/18/20 08:32 AM
Scrap value of this catalytic converter
by atikovi - 02/18/20 06:10 AM
How drunk do you have to be to do this?
by dishdude - 02/17/20 11:09 PM
At least they show you
by Jake777 - 02/17/20 10:04 PM
Ryan Newman update
by P10crew - 02/17/20 09:17 PM
Thoughts on 2015+ Kia Sedona?
by 92saturnsl2 - 02/17/20 09:16 PM
Quiet riding tire
by wolf_06 - 02/17/20 08:27 PM
Where did the Ryan Newman thread go??
by P10crew - 02/17/20 08:02 PM
2013 FX4 repair.
by marine65 - 02/17/20 07:36 PM
New gaming build shutting down on Metro 2033
by Cujet - 02/17/20 07:09 PM
Snapon
by P10crew - 02/17/20 06:51 PM
Conventional or Synthetic
by charmer37 - 02/17/20 06:49 PM
Jeep Wrangler 3.0L Diesel
by HighbrowHillbill - 02/17/20 06:36 PM
94 B4000 overheat Eureka
by HyundaiAbuser - 02/17/20 05:48 PM
PP Euro 5w40 SN Plus formulation VOA
by BurntMusic - 02/17/20 04:35 PM
Bicycle Shops
by CourierDriver - 02/17/20 04:26 PM
EBC Brakes
by hatt - 02/17/20 04:17 PM
Dream Car
by MrQuackers - 02/17/20 04:06 PM
What are people using now for outdoor antennas?
by BAJA_05 - 02/17/20 02:49 PM
tpap, ratt, jeffreytmann, boureesub, Bayrim
70737 Registered Users
88 registered members (BeerCan, Blkstanger, Astro14, Alfred_B, ARB1977, 8 invisible), 1,877 guests, and 20 spiders.
Topics301,600
Posts5,198,891
Members70,737
REVIVE a 3 YEAR stored/maltreated battery? #4105077 05/24/16 08:35 AM
SumpChump Offline OP
Getting my father's 2005 dodge ram 5.7L 4wd 1500. It has a 4 year old Farm & Fleet (Johnson Controls) battery that was poorly kept over the past 3 years after he became parapalegic. It was run for about 30 minutes once a month appx. so it has been maltreated and never taken out in winter time over this period of minimal use. It currently somehow still starts the truck, not robustly but starts it indeed.
I don't want to ruin a $300 alternator for a $80 battery.
It is appx. 700 -800 CCA top post. Any genuine way to top it off with charge to make it whole again or is it likely a sad excuse for what it once chemically was?
Any charging regemine you recommend to top it up? A formula?....A certain amps over certain hours per hundred CCA?
Re: REVIVE a 3 YEAR stored/maltreated battery? [Re: SumpChump] #4105081 05/24/16 08:38 AM
R
Rand Offline
R
take it to an autoparts store if you dont have a charger
they will charge and test it
examples
autozone
AAP
Re: REVIVE a 3 YEAR stored/maltreated battery? [Re: SumpChump] #4105082 05/24/16 08:39 AM
H
HerrStig Offline
H
Buy a new 80 dollar battery.
Re: REVIVE a 3 YEAR stored/maltreated battery? [Re: SumpChump] #4105094 05/24/16 08:49 AM
4
4wheeldog Offline
4
If you have an automatic charger and a voltmeter, charge the battery until fully charged.
(This is the part that some people will not agree with). With the charger off, turn on the headlights and monitor the battery voltage until it drops to 11 volts. Repeat this cycle 4 to 6 times.
If the time it takes to drop to 11 volts increases with each cycle, that is about as good as it gets. If the time it takes to loose voltages gets shorter......Get a new battery.
Re: REVIVE a 3 YEAR stored/maltreated battery? [Re: SumpChump] #4105097 05/24/16 08:51 AM
4
440Magnum Offline
4
The only thing I would consider other than a new battery is buying one of these and putting the battery on it for a couple of weeks to let it run its full 7-stage cycle a few times:
http://www.cloreautomotive.com/sku.php?id=502
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 XJ 4x4 4.0/AX15, '14 WK2 4x4 3.6/8HP
Re: REVIVE a 3 YEAR stored/maltreated battery? [Re: SumpChump] #4105114 05/24/16 09:09 AM
H
HangFire Offline
H
I have a decade-old shoe-box sized Vector (now Black & Decker) 25A charger with a recondition mode. I can put a battery on it and it alternately charges and discharges the battery until it declares it reconditioned (or errors-out).
It's never fixed anything. The batteries I've tried the recon mode on, were all near end of life, and continued their downward slide.
On another note, the charger has a 75A jump-start mode that does absolutely nothing. Not one Amp.
After B&D took over, they re-introduced the same charger, only they made it 5 times larger. The Vector I have is a good, intelligent charger, with AGM, Gel and Wet modes as well as 2A/10a/25A charge modes. I found a wheeled charger/jump-starter at a yard sale and repaired it, so together they take care of all my 12V charging needs.
Various musings: http://hangfire.net
Re: REVIVE a 3 YEAR stored/maltreated battery? [Re: SumpChump] #4105129 05/24/16 09:21 AM
cptbarkey Offline
Does it work? Great. Does it not? Replace it. Why does it have to be more complicated then that?
If the truck starts like butt its probably not your battery.
Re: REVIVE a 3 YEAR stored/maltreated battery? [Re: SumpChump] #4105139 05/24/16 09:32 AM
Donald Online Content
Online Content
You could put it on a BatteryMinder with a desulfation mode and it would take a week or two, but the battery will get desulfated and be a better battery.
2015 Ford F-250 w/Powerstroke
Re: REVIVE a 3 YEAR stored/maltreated battery? [Re: SumpChump] #4105146 05/24/16 09:36 AM
T
totegoat Offline
T
Why would a low battery ruin the alternator? For new I put two Motorcraft MAX batteries in my Ram. Good price and warranty.
Re: REVIVE a 3 YEAR stored/maltreated battery? [Re: totegoat] #4105191 05/24/16 10:36 AM
B
bradepb Offline
B
With all the modules and not to mention the alternator it is unwise to mess around with weak battery's. I replace my battery's every 4-5 years regardless of how they perform.
A weak battery forces the alternator to overwork, it is also hard on computers which need the correct voltage and current.
Re: REVIVE a 3 YEAR stored/maltreated battery? [Re: SumpChump] #4105244 05/24/16 11:21 AM
Z
zzyzzx Offline
Z
Re: REVIVE a 3 YEAR stored/maltreated battery? [Re: SumpChump] #4105245 05/24/16 11:22 AM
SrDriver Offline
Wal-Mart here sells a new battery for $49.00 - nation wide warranty.
Re: REVIVE a 3 YEAR stored/maltreated battery? [Re: SumpChump] #4105261 05/24/16 11:39 AM
L
LeakySeals Offline
L
I know for my golf cart I tried the magic juice they sell like this a charge and it worked!
http://www.amazon.com/Liquid-Solution-Refurbish-Batteries-Battery/dp/B00BTH4S4C
I'm not sure exactly what the differences are between a golf cart battery and an automotive battery but I would think you could do something similar.
06 Escalade 6.0L LQ9 AWD 170k M1 5w30
03 Maxima 3.5L 170k Maxlife HM 10w30
05 Malibu Classic 2.2 111k M1 5w30
06 Altima 2.5L 167k unk
Re: REVIVE a 3 YEAR stored/maltreated battery? [Re: SumpChump] #4105294 05/24/16 12:14 PM
N
nwjones18 Offline
N
If it was me I'd put it on a slow 2amp charge till it was topped off and use it.
2016 Ram 1500 5.7 Hemi 30k QSUD 5w-20 and Mopar filter
1988 F-150. 4.9 I6 251k. 10w-40 QSHM Motorcraft FL1A
2007 Mazda 3 2.3 130k 5w-30 syn-blend and Denso filter
Re: REVIVE a 3 YEAR stored/maltreated battery? [Re: SumpChump] #4105337 05/24/16 01:04 PM
B
bullwinkle Offline
B
Run a Battery Minder in delsulfation mode (as mentioned above), get a cheap solar battery charger from HF or Northern Tool to keep it fully charged, both have saved me mucho dinero on batteries.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
