Did Rotella Ever Have JASO MA Certification?
by BBDartCA - 01/22/20 12:49 AM
Old Tundra Headlamp Upgrade
by JeffKeryk - 01/21/20 09:41 PM
MOVIE: Dr. Dolittle
by Kira - 01/21/20 09:34 PM
Oil weight and Oil Grade
by Snagglefoot - 01/21/20 07:11 PM
Which air filter for RAV 4 Hybrid
by NH73 - 01/21/20 06:44 PM
Finding a good "cold weather" vehicle?
by Vern_in_IL - 01/21/20 06:15 PM
Bough NGK Ruthenium sparkplugs
by cronk - 01/21/20 06:07 PM
HF 30% Off $10 and Under
by TheLawnRanger - 01/21/20 06:02 PM
Stolen Battery-New one on Me
by bunnspecial - 01/21/20 05:29 PM
2006 Acura TSX Buying Advice
by maverickfhs - 01/21/20 04:35 PM
Castrol GTX Diesel 15W-40, CK4
by HDoilDude - 01/21/20 04:30 PM
Combo of P0068 and P307A
by Alfred_B - 01/21/20 04:30 PM
Are the plastic battery trays necessary?
by littlehulkster - 01/21/20 03:18 PM
Amsoil ATV/UTV Powertrain Fluid
by IowaFord - 01/21/20 02:13 PM
Motorcraft FL500s 3,630 miles.
by mpgo4th - 01/21/20 01:36 PM
Xcel Class Action Suit
by John_K - 01/21/20 12:33 PM
RV Freightliner Cummins ISB 6.7 oil question
by 1978elcamino - 01/21/20 11:48 AM
IowaFord, Origami99, reylafo, PastPresMike, RedBeard83
70497 Registered Users
27 registered members (bbhero, Bailes1992, Black_Thunder, CB22, 1WildPig, 4 invisible), 1,327 guests, and 25 spiders.
Topics300,415
Posts5,175,286
Members70,497
5.0 Mustang & Napa Synthetic #4105067 05/24/16 08:24 AM
Camprunner Offline OP
In my 2013 5.0 Mustang GT V8 I currently use either M1 5w30 or I have had several free oil changes that the dealer gave me and they use Motorcraft simi synthetic 5w20 and both oils seem to run fine without issue. In the wifes Toyota Camery and my Nissan Pathfinder as well as my company Ford Focus I use Napa synthetic 5w30 that I buy on sale and frankly I would like to use this oil in my Mustang. For one reason I am cheep and the Mustang takes 8 quarts and another thing I could only stock one oil and that makes it easy. My Mustang is not a Track Pack car and it is not driven hard.
Will Napa synthetic meet the 5.0 Ford V8 engine requirements? Is this oil good enough quality or should I just bite the bullet and stick with the M1 oil? what you think?
Re: 5.0 Mustang & Napa Synthetic [Re: Camprunner] #4105083 05/24/16 08:40 AM
H
HemiHawk Offline
H
If the car isnt pushed, you're probably fine with any synthetic. Probably wont hurt anything, but any reason you're using 5w30 instead of the 5w20?
I would think the NAPA full syn would be at least equal to what the motorcraft semi could take. What are you oil change intervals like?
2015 Mustang GT
2017 VW GTI sport
2001 Grand Cherokee
1995 Mustang GTS
Re: 5.0 Mustang & Napa Synthetic [Re: HemiHawk] #4105095 05/24/16 08:50 AM
I change the Mustang oil every 5K as for the 5w30 over 5w20 there seems to be a great deal of talk on many of the Mustang forums that 5w20 is not the best choice for the Coyote V8? I dont want to start a 5w20 vs 5w30 oil debate but many 5.0 Ford V8 owners feel better running 5w30 frankly I have no idea if its any better?
Re: 5.0 Mustang & Napa Synthetic [Re: Camprunner] #4105100 05/24/16 08:57 AM
F
FordCapriDriver Offline
F
i'd say if you really beat on it and drive it hard ( why wold you want a V8 Mustang if you didn't ) just keep using the 5w30 in any name brand synthetic..
The 5w20 will be just fine too but the only reason modern manufacturers are speccing Xw20 oils is C.A.F.E standards, all the Ford dealers here in Spain use 5w30 in basically everything from the Diesel 4 pot Focuses and Fiestas to 5.0 Mustangs.
You don't need to change the oil every 5k miles, that is overkill, you can easily do 10k
1975 Ford Capri II Ghia 3000 V6 - Repsol Elite Super 20W-50
1988 Ford Escort XR3i Cabrio - Repsol Elite Super 20W-50
Re: 5.0 Mustang & Napa Synthetic [Re: Camprunner] #4105101 05/24/16 08:59 AM
H
HemiHawk Offline
H
Yea, I have the older 4.6 3V and the debate rages for that as well, between 5w20 and 5w30. Honestly I think either will work fine.
Changing the oil in that 5.0 every 5k, I would go with the NAPA synthetic for sure (and save some $$) . I think ford recommends 10k intervals using the semi syn, so you're cutting that in half. Also the 8 quart capacity gives you a good bit extra protection.
Out of curiosity what filter are you going with?
2015 Mustang GT
2017 VW GTI sport
2001 Grand Cherokee
1995 Mustang GTS
Re: 5.0 Mustang & Napa Synthetic [Re: Camprunner] #4105107 05/24/16 09:03 AM
A
AirgunSavant Offline
A
What price are you paying out the door for Napa?
Re: 5.0 Mustang & Napa Synthetic [Re: Camprunner] #4105132 05/24/16 09:27 AM
J
Justin251 Offline
J
With an 8 quart sump you can definitely go over 5k. I know I would and did with my 2012 5.0.
Owners manual said 10k with motorcraft oil.
2014 Ram 5.7 PUPPP 5w20 ultra
2015 Tuscon 2.4 PP 5w20 wix
1996 Ranger 4.0 SuperS 5w30 wix
1989 formula 5.0
Re: 5.0 Mustang & Napa Synthetic [Re: Camprunner] #4105162 05/24/16 10:01 AM
B
buck91 Offline
B
I run 5w20 in my 5.0, but after doing a lot of reading it seems nobody has experienced any problems going thicker. With a good quality oil, especially a full synthetic, I am comfortable running 5w20 out to the IOLM shows around 10%. No reason to throw money away.
I didn't find any info on actual internal changes with the track pack so I can't see any reason why a heavier oil would cause problems... I also don't see any benefit of you don't experience elevated oil temps.
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: 5.0 Mustang & Napa Synthetic [Re: Camprunner] #4105167 05/24/16 10:07 AM
W
wtd Offline
W
I'm sure the Napa synthetic meets the requirements for this engine and may be better than the Motorcraft blend. What does the back of the bottle say?
I use 5W-20 Motorcraft blend in my 14 Mustang GT and go by the OLM for oil changes or one year of service.
As far as 5W-20 vs 5W-30, I tend to keep my vehicles a long time so unless my car turns into a un-reliable money pit and I get rid of it, I may find out if using 5W-20 lowered it's engine life.
Wayne
2014 Mustang GT
1998 Chevy K3500
1998 Chevy K1500
(2) 1992 Cavaliers
1970 Monte Carlo
Re: 5.0 Mustang & Napa Synthetic [Re: Camprunner] #4105189 05/24/16 10:33 AM
A
ARCOgraphite Offline
A
That synthetic terminology doesn't matter, since they aren't.
5qt sump should go further than 5K. What ford say? OLM? Early changes = MORE engine wear not less. Super clean doesn't = longer engine life.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: 5.0 Mustang & Napa Synthetic [Re: Camprunner] #4105340 05/24/16 01:07 PM
slacktide_bitog Offline
Doesn't your Mustang have the IOLM? If so, you can confidently follow its suggested OCI suggestions with Napa Synthetic smile
No reason to pay extra for M1 in your case.
Re: 5.0 Mustang & Napa Synthetic [Re: Camprunner] #4105350 05/24/16 01:13 PM
B
Blkstanger Offline
B
Your Mustang will never know the difference. wink
99 Jeep WJ 4.7 200,000mi. Maxlife 10w30, Fram Ultra.
15 Ford Escape S 2.5 Castrol Edge EP 5w30 Fram Ultra.
Re: 5.0 Mustang & Napa Synthetic [Re: Camprunner] #4105357 05/24/16 01:21 PM
dave1251 Offline
Napa Synthetic will be good beyond the iOLM if everything is mechanically sound. You will be fine to use it.
don't use.
Re: 5.0 Mustang & Napa Synthetic [Re: HemiHawk] #4105369 05/24/16 01:43 PM
G
gallydif Offline
G
+1. NAPA synthetic is just fine. 8 qts gives you more wiggle room for extended intervals. Try going 7.5k and getting a UOA.
09 Pontiac G8 GT 130k- Castrol + PP, ST 10060
96 Buick Roadmaster 103k- PP, ST filter
95 Roadmaster 53k- PP, ST filter
84 Caprice Landau 16k- MS5K 5w30, AC Delco
Re: 5.0 Mustang & Napa Synthetic [Re: FordCapriDriver] #4105370 05/24/16 01:44 PM
M
mr_boring Offline
M
Till my son destroyed my 2013 (not mad, at least he walked away from it) I found that I didn't have to beat on it to make it giddy up and go. And mine was a 6er. Those 5.0's with the right gears got plenty for the average thrill seeker, and you don't need to get it near redline to feel it! That car was the reason I showed up here to begin with. I cringed when I saw 5-20 in the owner's manual. It only got to 30k, but it ran fine on that 5-20 and I would probably have never changed a thing. My IOLM had plenty left @ about 8K at every time, but I figured +/- 8K was good enough for the Motorcraft blend, cause I did beat on it, but jus a lil'!
