US Miltary News - F22
by ZeeOSix - 01/19/20 03:09 AM
OEM to Ravenol
by graphine - 01/19/20 02:38 AM
D905 Brake Pads: Bosch vs. Centric vs. Akebono
by The Critic - 01/19/20 01:55 AM
Dodge dart running issues after filling up fuel
by ram_man - 01/19/20 12:58 AM
Akebono ProAct brake pads now include hardware
by The Critic - 01/19/20 12:43 AM
16 Audi S3 G13 Coolant - 40,500 miles
by agpatel - 01/19/20 12:43 AM
BMW “G3” Axle Alternatives?
by E365 - 01/19/20 12:20 AM
Scan Tool recommendation
by zmelli - 01/18/20 11:57 PM
Keyless Entry Help Needed
by DeafBrad - 01/18/20 11:55 PM
75/140 owners manual vs 75/90 tag
by BigGee - 01/18/20 11:36 PM
toro super recycler with b&s engine HomeDepot
by passgas55 - 01/18/20 06:43 PM
75w140?
by mpack88 - 01/18/20 06:00 PM
Are all 9012 bulbs HIR2?
by dvancleve - 01/18/20 03:30 PM
Ariens L-3 Synthetic Severe-Duty Gear Lube
by Astro_Guy - 01/18/20 02:04 PM
LSx Crank lock
by P10crew - 01/18/20 02:03 PM
ST9688 gasket
by Farnsworth - 01/18/20 01:26 PM
From my stash
by Fattylocks - 01/18/20 12:48 PM
Toyota to Mexico
by kstanf150 - 01/18/20 12:37 PM
Final Sludge Cleanup, HDEO - Diesel ??
by jssaab - 01/18/20 12:31 PM
Katdaddy, graphine, Bebo77, 2EHA, jonnyb433
70467 Registered Users
26 registered members (blufeb95, carviewsonic, Char Baby, DaHen, 750IX, 2 invisible), 827 guests, and 18 spiders.
Topics300,303
Posts5,172,818
Members70,467
Most Online3,728
Jan 11th, 2020
What trans fluid for a modded 700R4? #4105059 05/24/16 08:10 AM
R
redhat Offline OP
R
The Regal build continues, this time, transmission.
I picked up a healthy 700R4 a month ago and am putting in a combination of the 700-2&3 and SK 700 JR TransGo kits. Looking for recommendations on what fluid to run in this. It will be going behind an LM7 LS truck motor. Looking for a decent 325hp. I have heard a lot about using Type F, but then see listings for Type FA. Would prefer to use an over-the-counter fluid.
Thanks.
19 F150 2.7 - M1EP 5W-30, FL2062, 11k
17 Taurus Limited AWD - M1EP 5W-20, FL500S, 30k
84 JD 316 Repowered w/Vanguard 18
Re: What trans fluid for a modded 700R4? [Re: redhat] #4105075 05/24/16 08:30 AM
J
Jimzz Offline
J
I would think most good Syn Dex3 spec fluid like Valvoline maxlife would work fine.
But also make sure to have a trans cooler as even the best fluid can't help if the trans gets to hot.
yup
Re: What trans fluid for a modded 700R4? [Re: redhat] #4105177 05/24/16 10:25 AM
crazyoildude Offline
Did you ever think to ask the rebuilder for his or her opinion
Check To See That The Oil Jugs You Buy Have The Exact Amount Of Oil In Them And Have An Inner Seal Under The Cap. I Use Mobil 1 And Fram Ultra Filters
Re: What trans fluid for a modded 700R4? [Re: redhat] #4105186 05/24/16 10:31 AM
P
Prune_Juice Offline
P
What kind of transmission fluid did the 700R4 spec?
Re: What trans fluid for a modded 700R4? [Re: redhat] #4105194 05/24/16 10:39 AM
Y
yvon_la Offline
Y
Truck driver
Nissan versa note s 2014 total classic 5w30(qc.ca) drivework oil filter
Re: What trans fluid for a modded 700R4? [Re: redhat] #4105213 05/24/16 10:59 AM
R
redhat Offline OP
R
I am the rebuilder. Putting these kits in myself.
Re: What trans fluid for a modded 700R4? [Re: redhat] #4105216 05/24/16 11:00 AM
R
Ramblejam Offline
R
What kind of fluid did your Blazer's spec?
700R4 = 4L60/65/70
Valvoline MaxLife ATF is entirely appropriate, and widely available at under $18/gallon.
Re: What trans fluid for a modded 700R4? [Re: Prune_Juice] #4105220 05/24/16 11:02 AM
R
redhat Offline OP
R
Spec'd Dex III back in the day.
Re: What trans fluid for a modded 700R4? [Re: redhat] #4105237 05/24/16 11:16 AM
M
Miller88 Offline
M
I'd go with Dex III or Dex VI
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: What trans fluid for a modded 700R4? [Re: redhat] #4105239 05/24/16 11:18 AM
MolaKule Offline
Global Moderator
Global Moderator
How are you going to be using this Blazer? Tracking, off-roading, towing, daily driver, what?
The 700R4 speced Dexron III/Mercon.
I have rebuilt many of these for my former Suburbans.
I would use either Amsoil TorqueDrive or Redline D4 if you are not going to be Tracking, off-roading, or towing.
If you will be towing or off-roading or tracking I would use the Redline High-Temp ATF.
The 700R4 is NOT a racing tranny and under no circumstances would I use a type "F" ATF.
Charlie Eppes: "What do you think we should do now?"
Don Eppes: "The same thing when I was in school and I didn't know the answer – fake it." From NUMB3RS
Re: What trans fluid for a modded 700R4? [Re: redhat] #4105251 05/24/16 11:29 AM
R
redhat Offline OP
R
Where did Blazer come from? This is a THM700R4 going behind a 5.3 LM7 truck motor in a G-Body Regal.
It's going in it for heaters, some fun runs, and general enjoyment. If it lasts a season or two, I'll be happy. I figure it should be a good combo with a N/A or sprayed LM7 before I bite the bullet, go 4L80 and LQ4 with turbos.
Re: What trans fluid for a modded 700R4? [Re: redhat] #4105325 05/24/16 12:49 PM
R
Ramblejam Offline
R
I'd much rather spend my money on a good cooler vs. boutique oils.
A standalone Tru-Cool 4590 (11 x 11 x 1 1/2) would be excellent for your car.
Re: What trans fluid for a modded 700R4? [Re: redhat] #4105344 05/24/16 01:09 PM
R
redhat Offline OP
R
Oh most definitely will be going with a good trans-cooler.
Re: What trans fluid for a modded 700R4? [Re: redhat] #4117933 06/07/16 06:00 PM
P
pjc360 Offline
P
Maxlife gets my vote, impressive stuff. My built
Transmission loves it and shifts great with it and runs cool
