Amazon 5qt PUP 5w-20 $16.24
by Matt1980 - 01/19/20 03:42 AM
US Miltary News - F22
by ZeeOSix - 01/19/20 03:09 AM
OEM to Ravenol
by graphine - 01/19/20 02:38 AM
D905 Brake Pads: Bosch vs. Centric vs. Akebono
by The Critic - 01/19/20 01:55 AM
Dodge dart running issues after filling up fuel
by ram_man - 01/19/20 12:58 AM
Akebono ProAct brake pads now include hardware
by The Critic - 01/19/20 12:43 AM
16 Audi S3 G13 Coolant - 40,500 miles
by agpatel - 01/19/20 12:43 AM
BMW “G3” Axle Alternatives?
by E365 - 01/19/20 12:20 AM
Scan Tool recommendation
by zmelli - 01/18/20 11:57 PM
Keyless Entry Help Needed
by DeafBrad - 01/18/20 11:55 PM
75/140 owners manual vs 75/90 tag
by BigGee - 01/18/20 11:36 PM
toro super recycler with b&s engine HomeDepot
by passgas55 - 01/18/20 06:43 PM
75w140?
by mpack88 - 01/18/20 06:00 PM
Are all 9012 bulbs HIR2?
by dvancleve - 01/18/20 03:30 PM
Ariens L-3 Synthetic Severe-Duty Gear Lube
by Astro_Guy - 01/18/20 02:04 PM
LSx Crank lock
by P10crew - 01/18/20 02:03 PM
ST9688 gasket
by Farnsworth - 01/18/20 01:26 PM
From my stash
by Fattylocks - 01/18/20 12:48 PM
Toyota to Mexico
by kstanf150 - 01/18/20 12:37 PM
Katdaddy, graphine, Bebo77, 2EHA, jonnyb433
70467 Registered Users
25 registered members (BlakeB, blufeb95, carviewsonic, Char Baby, DaHen, 2 invisible), 744 guests, and 19 spiders.
Topics300,304
Posts5,172,820
Members70,467
Most Online3,728
Jan 11th, 2020
Poulan Pro 5020AV carburetor adjustment #4105000 05/24/16 06:57 AM
jstutz Offline OP
Guys, I just bought a new saw and it will be delivered by this weekend. I have read many times that they come very lean from the factory and should be adjusted slightly, especially for break in. I have read three , what look to be educated, posts that go thru the procedure but they differ slightly. Here is a summary of what i read. I wish i could just find the service manual that goes thru the procedure.
1) turn both H/L until bottomed out. Back out 1 turn each as a starting point. Adjust out for richer mixture
2) turn both H/L until bottomed out. Back out 1 1/4 turn each as a starting point. Adjust out for richer mixture
3) turn both H/L until bottomed out. Back out 1 turn each as a starting point. Adjust in for richer mixture
So the real question is this: Do you turn them in our out for a richer mixture?
Re: Poulan Pro 5020AV carburetor adjustment [Re: jstutz] #4105011 05/24/16 07:15 AM
old1 Offline
I think #3 is wrong. Every carb I adjust has to be turned out for richer- in for leaner.
2017 Nissan Frontier 4.0 5w30
1965 Mustang 200 c/4 10w30 QS defy
1964 Ford Ranchero 302 c/4 15/40 Delo
Re: Poulan Pro 5020AV carburetor adjustment [Re: jstutz] #4105040 05/24/16 07:44 AM
P
Panzerman Offline
P
If it's a new saw. I seriously would not dick with it. The only saws I had to adjust and actually fiddle with are the saws that people "Thought" they were making better. Poulan put numerous anti tamper devices on there for a reason. I bought a Poulan chainsaw new when I moved to Florida in 2002. I have used the heck out of that thing. Four hurricanes and a tree in my pool. I have replaced the chain three times cleaned the oiler, replaced the primer bulb and fuel lines with tygon lines. I never touched the adjustments on that carb. It still runs Great. Just my two cents, if it isn't broke, don't fix it.
2006 Dodge Ram 2500 Hemi 4x4
2016 Dodge Challenger Scat Pack
Re: Poulan Pro 5020AV carburetor adjustment [Re: jstutz] #4105048 05/24/16 07:50 AM
P
Panzerman Offline
P
I also run my oil in pre mix richer, which will have some people, by therory, claiming that is terriable, it makes them run leaner yet, less gas. This is bull. It's fuel to air, regardless make it liquid to air. I have yet to lose a two stroke engine- ever. I also get the longest life from my two strokes. My weed trimmer is 23 years old, original internals, never carb adjusted always on a rich mixture of 32:1. Regardless of oil type. Yes, it smokes.
Re: Poulan Pro 5020AV carburetor adjustment [Re: jstutz] #4105054 05/24/16 08:03 AM
P
punisher Offline
P
I was going to suggest running the oil mix slightly "rich" for the first few hours. The oil has very little effect on the actual fuel ratio when you crunch the numbers. After you get it broken in, then it might be of benefit to adjust the "H" screw till the RPMs top out, and then a little extra for safety. I hesitate to go too rich on newer stuff because of the cat converter carbon/clogging problems on OPE that actually gets used. Your saw...your call.
Re: Poulan Pro 5020AV carburetor adjustment [Re: jstutz] #4105121 05/24/16 09:13 AM
R
RedOakRanch Offline
R
I've been tuning 2 stroke chainsaws for years. I have always set my own tune for power and clean running. Never had an engine failure and I've never been happy with the factory settings.
1994 Ford Crown Vic 207k-Frankenbrew 0w20,30,40!
2005 Chevy 1500 Crewcab 4X4 180k-BC 0w30 $2/qt
2016 Outback 2.5 Limited 60k-shop brand?
Re: Poulan Pro 5020AV carburetor adjustment [Re: jstutz] #4105527 05/24/16 04:43 PM
M
Merkava_4 Offline
M
The number of turns is just to get the saw started; the final adjustment is done by ear.
On the low speed mixture needle, you turn the L needle to both extreme lean and extreme rich; the highest idle speed between full lean and full rich is your best mixture setting. Repeat these steps for the H needle, but with your finger on the trigger at full throttle.
Re: Poulan Pro 5020AV carburetor adjustment [Re: jstutz] #4107809 05/27/16 06:20 AM
jstutz Offline OP
Thank you guys very much. Got my saw in yesterday and will use it this weekend.
