US Miltary News - F22
by ZeeOSix - 01/19/20 03:09 AM
OEM to Ravenol
by graphine - 01/19/20 02:38 AM
D905 Brake Pads: Bosch vs. Centric vs. Akebono
by The Critic - 01/19/20 01:55 AM
Dodge dart running issues after filling up fuel
by ram_man - 01/19/20 12:58 AM
Akebono ProAct brake pads now include hardware
by The Critic - 01/19/20 12:43 AM
16 Audi S3 G13 Coolant - 40,500 miles
by agpatel - 01/19/20 12:43 AM
BMW “G3” Axle Alternatives?
by E365 - 01/19/20 12:20 AM
Scan Tool recommendation
by zmelli - 01/18/20 11:57 PM
Keyless Entry Help Needed
by DeafBrad - 01/18/20 11:55 PM
75/140 owners manual vs 75/90 tag
by BigGee - 01/18/20 11:36 PM
toro super recycler with b&s engine HomeDepot
by passgas55 - 01/18/20 06:43 PM
75w140?
by mpack88 - 01/18/20 06:00 PM
Are all 9012 bulbs HIR2?
by dvancleve - 01/18/20 03:30 PM
Ariens L-3 Synthetic Severe-Duty Gear Lube
by Astro_Guy - 01/18/20 02:04 PM
LSx Crank lock
by P10crew - 01/18/20 02:03 PM
ST9688 gasket
by Farnsworth - 01/18/20 01:26 PM
From my stash
by Fattylocks - 01/18/20 12:48 PM
Toyota to Mexico
by kstanf150 - 01/18/20 12:37 PM
Final Sludge Cleanup, HDEO - Diesel ??
by jssaab - 01/18/20 12:31 PM
Katdaddy, graphine, Bebo77, 2EHA, jonnyb433
70467 Registered Users
26 registered members (blufeb95, carviewsonic, Char Baby, DaHen, 750IX, 2 invisible), 827 guests, and 18 spiders.
Topics300,303
Posts5,172,818
Members70,467
Most Online3,728
Jan 11th, 2020
Trying to prevent high mileage leaks #4104870 05/24/16 01:04 AM
T
twincam00 Offline OP
T
I recently purchased a 1999 Toyota 4Runner with over 200,000 miles, I'm in the process of changing all the fluids. I an wondering if I should stick with conventional differential oil or switch to a group V ester-based oil like Redline to keep it leak-free. I have read that ester-based oils swell seals more than other types of oils. Money is not a factor, main concern is hopefully preventing leaks. The transfer case and front diff take 75W-90, the rear diff takes 80W-90.
Re: Trying to prevent high mileage leaks [Re: twincam00] #4104872 05/24/16 01:21 AM
U
userfriendly Offline
U
Whatever has worked for the last 17 years and 200k, is obviously compatible with the seals.
Getting creative, may be inviting trouble this late in the game.
Oh!! And welcome to BITOG, 14 years old and still a young dog.
Re: Trying to prevent high mileage leaks [Re: twincam00] #4104882 05/24/16 02:55 AM
L
Lubener Offline
L
Stick w/ conventional. If it isn't leaking, why experiment? I think it would be overkill for an old, high mileage vehicle.
The "thinking" man's friend.
Re: Trying to prevent high mileage leaks [Re: twincam00] #4105192 05/24/16 10:38 AM
SavagePatch Offline
I'm not sure about helping to prevent leaks but the Tacoma/4Runner crowd love Redline. Use their 75w90 in the front and rear differentials and their MT-90 in the manual transmission and transfer case. Hit the drain and fill bolts with some PB Blaster a few days before and make sure that you can get the fill bolts off before removing the drain bolts. Torque is 27lb for each.
Re: Trying to prevent high mileage leaks [Re: twincam00] #4105324 05/24/16 12:47 PM
T
T
I like Redline products, but I have mixed feelings on MT-90. I've used it in 2 different transmissions with the same results: excellent smooth shifting once the fluid is warmed up, but very notchy shifting when cold. I believe MT-90 is more of a racing oil and MTL is more of a street/daily driver oil. I have since switched to Motorcraft Full Synthetic Manual Transmission Fluid (XT-M5-QS) which is very smooth shifting whether the fluid is hot or cold, but it's very expensive.
Do I need to use GL-4 in the transfer case?
Re: Trying to prevent high mileage leaks [Re: twincam00] #4105332 05/24/16 12:57 PM
K
kschachn Offline
K
Your owner's manual should say. The one for my ECHO says I can use GL-4 or GL-5 in the gearbox. I would go by what the manual specifies.
And I have had mixed results with MT-90 as well, I used Amsoil the last time (sold at my local NAPA). It works great for me.
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 430K
2000 Toyota ECHO, 284K
Re: Trying to prevent high mileage leaks [Re: twincam00] #4105446 05/24/16 03:08 PM
SavagePatch Offline
I beleive that the owners manual recommends GL-4 or GL-5 but the people over at Tacoma World recommend GL-4 so they use the MT-90.
I hear what you're saying about the MT-90 feeling notchy. It was a huge upgrade over the old factory fill in my 98 Tacoma but I still think that it can be better so I'll be trying the MT-85 next change.
No, you don't need the MT-90 in the transfer case you can use 75w90 but it was recommended to me because if they leak some they'll end up sharing fluid so it's best to run the same thing in both the manual transmission and transfer case.
Re: Trying to prevent high mileage leaks [Re: twincam00] #4105614 05/24/16 06:31 PM
N
NH73 Offline
N
75W90 are usually a synthetic fluid. I say buy the 75w90 for both where 75w90 and 80w90 are called for. That way you buy one fluid instead of two.
2017 Toyota RAV4 Hybrid
2004 Ford Explorer Sport Trac
2012 Gravely ZT XL 48 w/ Kawasaki FR730
Re: Trying to prevent high mileage leaks [Re: twincam00] #4106172 05/25/16 10:46 AM
N
nobb Offline
N
I'm using 75W90 on my 4runner all around because I can get it in bulk cheap. I don't know why they spec'ed 80W90 only on the rear diff... maybe to save costs? There's no reason why 75W90 can't be used in place and it's even an improvement.
Re: Trying to prevent high mileage leaks [Re: twincam00] #4106182 05/25/16 10:55 AM
supton Offline
There is a big viscosity difference between MT90 and MTL. I tried MT90 and likewise found it great in summer, and unusable in winter. MTL is a decent tradeoff--but I'm (somewhat) tempted to use MT90 in summer, MTL in winter.
2011 Toyota Camry, base, 2.5L/6MT, 200k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 157k, ours
1999 Toyota Camry LE, 2.2L/4AT, 220k, his
