Shutting Down Threads Because of "Speculation"
by e55amgbenz007 - 02/18/20 10:10 AM
Toyota Sienna
by cb_13 - 02/18/20 10:05 AM
Larger fuel filter on Riding mower?
by dedonderosa - 02/18/20 10:03 AM
Castrol edge 0w40
by VQLT - 02/18/20 08:32 AM
Scrap value of this catalytic converter
by atikovi - 02/18/20 06:10 AM
How drunk do you have to be to do this?
by dishdude - 02/17/20 11:09 PM
At least they show you
by Jake777 - 02/17/20 10:04 PM
Ryan Newman update
by P10crew - 02/17/20 09:17 PM
Thoughts on 2015+ Kia Sedona?
by 92saturnsl2 - 02/17/20 09:16 PM
Quiet riding tire
by wolf_06 - 02/17/20 08:27 PM
Where did the Ryan Newman thread go??
by P10crew - 02/17/20 08:02 PM
2013 FX4 repair.
by marine65 - 02/17/20 07:36 PM
New gaming build shutting down on Metro 2033
by Cujet - 02/17/20 07:09 PM
Snapon
by P10crew - 02/17/20 06:51 PM
Conventional or Synthetic
by charmer37 - 02/17/20 06:49 PM
Jeep Wrangler 3.0L Diesel
by HighbrowHillbill - 02/17/20 06:36 PM
94 B4000 overheat Eureka
by HyundaiAbuser - 02/17/20 05:48 PM
PP Euro 5w40 SN Plus formulation VOA
by BurntMusic - 02/17/20 04:35 PM
tpap, ratt, jeffreytmann, boureesub, Bayrim
70737 Registered Users
104 registered members (Avery4, Astro14, aquariuscsm, ABerns, andreigbs, 10 invisible), 2,182 guests, and 24 spiders.
Topics301,604
Posts5,198,970
Members70,737
Mini Cooper OEM Purflux 5153 miles [cut open] #4104681 05/23/16 07:11 PM
N
nicrfe1370 Offline OP
N
This is a Purflux L358A cartridge filter, sold in a Mini branded box at American Mini dealers. It was in use for 5153 miles and about two and a half months. I used Castrol Edge 0W-30 European Formula for this whole interval. I sampled the oil at this change but I don't have the results back yet. As you can see the filter looks really great. No collapsing, no holes, no metal or grit in the media. The media was very strong, in fact it was difficult to cut with my utility knife.
I was curious how much of a size difference the zig zag pleats made, so I did a bit of measuring. The entire filter height, including the plastic end caps, is 2.75 inches. When I cut the filter media out and stretched out the zig zags, the filter media measured 3.75 inches. So that's 1 inch more media than the entire size of the filter, and if you subtracted another half an inch or so to account for the thickness of the end caps, then it's probably on the order of 1.5 inches more media (in that direction) than a non zig zag filter. The length of the media was 37 inches, which gives us 138.75 square inches of media. The same size filter without zig zag pleats would have a media surface area of 83.25 square inches.
Re: Mini Cooper OEM Purflux 5153 miles [cut open] [Re: nicrfe1370] #4104687 05/23/16 07:18 PM
MrQuackers Offline
I'd buy that for a dollar!
Master the 1000 yard stare
coffeeMobil 1 USA
Re: Mini Cooper OEM Purflux 5153 miles [cut open] [Re: nicrfe1370] #4104713 05/23/16 07:46 PM
A
abycat Offline
A
I think wavy media looks awesome!
2017 dodge caravan gt
2011 nissan versa hb
Re: Mini Cooper OEM Purflux 5153 miles [cut open] [Re: nicrfe1370] #4104716 05/23/16 07:47 PM
Z
ZeeOSix Offline
Z
It's a unique filter, but on a filter the same size with straight pleats, there will probably be quite a few more pleats. The 'zig-zag' doesn't allow as many pleats around the circumference.
Re: Mini Cooper OEM Purflux 5153 miles [cut open] [Re: nicrfe1370] #4104732 05/23/16 08:05 PM
Bud_One Offline
I like the zig zag grin
thanks for posting the pics
20 Pilot LX - Factory Fill
14 Civic LX Sedan- Castrol Mag 0W-20,XG7317
05 Chevy Crew Cab 2500HD- QSUD 10W-30,PF61E
97 Accord EX Wagon- Napa PPSB 5W-30,Napa 21334
Re: Mini Cooper OEM Purflux 5153 miles [cut open] [Re: ZeeOSix] #4104783 05/23/16 09:15 PM
K
KingCake Offline
K
Surface area is what matters. Not number of pleats. Zig zag wins.
Re: Mini Cooper OEM Purflux 5153 miles [cut open] [Re: nicrfe1370] #4104875 05/24/16 01:36 AM
K
Kibitoshin Offline
K
Would like to see something like that for import and domestic applications. Seems like the zigzags add robustness to the media since it's already "wavy".
Shin Gekiretsu Shin'ou'hou
Daily: 02 Chevy Silverado C1500 V8 5.3L
Worker: 19 Freightliner M2-106 26' Reefer Box ISL 8.9L Tandem Axle - Thermo King T1080S
Re: Mini Cooper OEM Purflux 5153 miles [cut open] [Re: ZeeOSix] #4104906 05/24/16 04:55 AM
N
N
I know what you're saying ZeeO, but I think if you look a bit closer, you'll see that the zig zags in fact "interlock" with one another, they aren't separated by an unusually large valley, so no more pleats could be in there if they were straight. It's probably easiest to see if you look at the end caps where the media is glued in; there's definitely not extra room.
Re: Mini Cooper OEM Purflux 5153 miles [cut open] [Re: nicrfe1370] #4104997 05/24/16 06:52 AM
A
ActionJoe Offline
A
Purflux est une marque Française. Les plis en chevron permettent de mettre plus de papier dans un même volume. C'est des excellents filtres à huile.
Re: Mini Cooper OEM Purflux 5153 miles [cut open] [Re: KingCake] #4105335 05/24/16 01:02 PM
Z
ZeeOSix Offline
Z
Not really ... surface area is also determined by the depth of the pleats. The only way zig-zag wins is if you compare the same sized filter with straight pleats and do an accurate media surface area measurement to compare the two.
Re: Mini Cooper OEM Purflux 5153 miles [cut open] [Re: nicrfe1370] #4105339 05/24/16 01:06 PM
Z
ZeeOSix Offline
Z
Looking at the photo, it looks like there are only about 28~30 zip-zag pleats total. Look at some of the typical non-synthetic filters with straight pleats and they will have nearly twice that many pleats.
Re: Mini Cooper OEM Purflux 5153 miles [cut open] [Re: nicrfe1370] #4105368 05/24/16 01:40 PM
J
jk_636 Offline
J
But the filter media came out wavy... hide
Just kidding, great looking filter! thumbsup
2006 Dodge Ram 1500 4.7 (Supertech 5w30 + OCOD)
2012 Ford Escape 3.0 (Royal Purple 0w20 + Fram Ultra)
