P0171 and P0174
by NavyVet88 - 01/26/20 05:04 AM
Essex Engine Plant (Canada)
by BlueOvalFitter - 01/26/20 03:18 AM
Mopar oil bottles
by Franz - 01/26/20 12:47 AM
Ultra-rare barn find!
by Toy4x4 - 01/26/20 12:11 AM
2015 Hyundai Genesis 5.0L Review
by Nick1994 - 01/25/20 11:56 PM
My doggie had a rough week
by Chris142 - 01/25/20 11:26 PM
Delivery meal kit review - Dinnerly vs HelloFresh
by pezzy669 - 01/25/20 10:32 PM
Eotech Vudu scopes
by OVERKILL - 01/25/20 10:10 PM
'12 Civic burning oil after switch to M1
by sr20detfwd - 01/25/20 09:33 PM
Wix/NAPA Gold and M+H
by Uphill_Both_Ways - 01/25/20 09:06 PM
New seafoam oil stabilizer at AZ
by Chesterr - 01/25/20 08:13 PM
In 3 hours - 730 days and counting
by OVERKILL - 01/25/20 08:12 PM
Pig Parker!
by dishdude - 01/25/20 07:58 PM
NGK Conventional vs. Ruthenium Plugs
by doitmyself - 01/25/20 07:58 PM
Container or funnel?
by Philthy_Phil - 01/25/20 07:24 PM
AC Delco filters at Amazon as little as $1.07
by jayjr1105 - 01/25/20 06:22 PM
Excessive moisture in oil
by mb32 - 01/25/20 05:47 PM
Cover for Jeep + Trailer
by kehyler - 01/25/20 05:34 PM
kwashabcp, ronster, BackToReality, Scopeman, M635_Guy
70527 Registered Users
51 registered members (bullwinkle, 2015_PSD, alchargo, BobsArmory, bmod305, blufeb95, 4 invisible), 1,155 guests, and 19 spiders.
Topics300,572
Posts5,178,518
Members70,527
Temp gauge mod? #4104624 05/23/16 05:51 PM
A
Avery4 Offline OP
A
Any way to mod my temp sensor and or change its location or something to make it read hot if it leaks out all of its coolant? I almost blew the engine in my 05 Civic again. The new Airtex water pump blew it's seal. I only knew it was hot because it was pinging when I was on the gas. I thought it was the exhaust rattling and kept driving until the oil pressure light came on about 20 minutes later. I immediately pulled over. Blew the head gasket but did not warp or crack anything. Doing great with a new head gasket. Any way I could have prevented this?
Re: Temp gauge mod? [Re: Avery4] #4104635 05/23/16 06:03 PM
clinebarger Offline
Temp sensors do not read correctly if they are not submerged in water/coolant, So if you lose all the coolant....It will not register hot.
You can usually smell the antifreeze when you lose a large amount of coolant. Hopefully this will be lesson for you, Odd noises/smells/steam means pull over now!
2001 Chevy Camaro L92/4L80E
Re: Temp gauge mod? [Re: Avery4] #4104637 05/23/16 06:05 PM
surfstar Offline
trolling
Re: Temp gauge mod? [Re: Avery4] #4104667 05/23/16 06:54 PM
R
Rand Offline
R
gee that is a pretty big story for one paragraph.. did it melt the paint on the hood like the last one...
NOT believing this new fantasy of yours
Pics?
Receipt for parts.. anything?
trolling trolling trolling trolling trolling trolling trolling trolling
Re: Temp gauge mod? [Re: clinebarger] #4104678 05/23/16 07:06 PM
A
Avery4 Offline OP
A
If I pulled over every time I heard a rattle, I would be on the side of the road 99 percent of the time! I knew I had an exhaust hanger that was hanging on by a strand of rubber. I figured that the hanger just failed. I did not smell or feel anything, so I figured it was just the exhaust rattling. Would oil temp be higher if I had a gauge?
Re: Temp gauge mod? [Re: Avery4] #4104693 05/23/16 07:26 PM
crazyoildude Offline
i had a 69 Buick Wildcat with the 430 when i was in high school and it had a head temperature light that flashed when it got hot
Check To See That The Oil Jugs You Buy Have The Exact Amount Of Oil In Them And Have An Inner Seal Under The Cap. I Use Mobil 1 And Fram Ultra Filters
Re: Temp gauge mod? [Re: Avery4] #4104938 05/24/16 05:42 AM
supton Offline
Install a coolant level sensor. [No I don't know how, but I know one of my prior cars had one.]
Do you have some sort of OBDII scanner which can read real-time the actual engine temperature? I'd think it'd rise abnormally first--gauges are notorious for being slow to respond and/or having deadzones.
2011 Toyota Camry, base, 2.5L/6MT, 200k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 157k, ours
1999 Toyota Camry LE, 2.2L/4AT, 221k, his
