Fury -Wilder 3?
by pbm - 02/23/20 06:41 AM
toro super recycler
by passgas55 - 02/23/20 06:05 AM
Chain style for ag tires
by puma4440 - 02/23/20 04:25 AM
2014 GMC Terrain 2.4L AWD
by Char Baby - 02/23/20 02:06 AM
Conventional VS Synthetic In The Winter Months
by BlueOvalFitter - 02/23/20 01:36 AM
Paint Splatter
by rrretiree7 - 02/23/20 12:54 AM
The Jeep Made it to 150k Miles - Storytime
by Nick1994 - 02/23/20 12:54 AM
Supertech vs Dexcool
by WA1DH - 02/22/20 11:44 PM
Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
Chaucha, UofA, Jeffrey78, Markovchain, o_s
70787 Registered Users
84 registered members (4WD, Aero540T, 53' Stude, 55hambone, aba4430, 8 invisible), 1,813 guests, and 17 spiders.
Topics301,818
Posts5,203,284
Members70,787
Page 1 of 3 1 2 3
Putting 195/60/15 on a Car with 205/65/15 #4104586 05/23/16 04:56 PM
R
ram_man Offline OP
R
I have a friend who doesn't have a whole lot of money and I'm trying to help them out. The car in question has 205/65/r15
The front two are junk could I put 195/60/r15 on the front and the good 205's she has one the back? I realize it's not ideal. But 2 different sized tires on the car is vastly better than tires with cords showing right ? Opinions please .
Re: Putting 195/60/15 on a Car with 205/65/15 [Re: ram_man] #4104588 05/23/16 04:59 PM
R
Rand Offline
R
you dont list a car?
no one can give anything more than extremely generic advise
without knowing what vehicle it is.
Re: Putting 195/60/15 on a Car with 205/65/15 [Re: ram_man] #4104598 05/23/16 05:15 PM
slacktide_bitog Offline
This will not work. The load index (weight the tires can support) is lower than the correct size tires.
205/65-15 is a reasonably common tire size, so even if you're THAT poor, a used tire shop should have a couple tires in the correct size.
If there is a Walmart nearby, you can get Douglas tires for $54 each. If you order online in advance, they even have Dextero tires for $49.
Re: Putting 195/60/15 on a Car with 205/65/15 [Re: ram_man] #4104602 05/23/16 05:20 PM
Nick1994 Offline
People on here like to go by the book too much.
I'd put the proper tires up front (her current rears) and throw the smaller ones on the back, less weight, make sure aired up good.
2015 Hyundai Genesis 5.0L 57k Mobil 1 5w30 & Wix
2000 Toyota Camry 2.2L 236k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 150k Mobil 1 HM 10w40 & Fram Ultra
Re: Putting 195/60/15 on a Car with 205/65/15 [Re: ram_man] #4104605 05/23/16 05:21 PM
N
Newreet Offline
N
With the wrong sized tires on the front wheels, the following could be issues:
Speedometer/odometer accuracy
Anti-lock brake system operation
Steering/suspension system operation
Re: Putting 195/60/15 on a Car with 205/65/15 [Re: Nick1994] #4104622 05/23/16 05:49 PM
gaijinnv Offline
This is the difference we're talking about:
You'd put the smaller tires on the rear ... of a rear wheel drive car?
We don't know what car we're talking about, we don't know what the recommended stock tire size is for this car, we don't even know where the OP is going to source the 195/60-15 tires he's talking about.
If the OP is going to buy 2 new tires, then obviously he should buy two of the same size as are on the car - assuming they are the correct size for the car.
If the OP already has 2 195/60-15 tires, then he should buy 2 new 195/60-15 tires - assuming they are suitable for use on the car.
Either way, looks to me like someone is going to have to pony up for 2 new/used tires.
HTH
USN NAVSECGRU 1970-1974
Re: Putting 195/60/15 on a Car with 205/65/15 [Re: ram_man] #4104650 05/23/16 06:27 PM
Quattro Pete Offline
Terrible idea. 195/60/15 has insufficient load rating.
If you really want to help him out, lend him some money so that he can buy the correct size tires.
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Re: Putting 195/60/15 on a Car with 205/65/15 [Re: ram_man] #4104664 05/23/16 06:54 PM
E
eljefino Offline
E
If you had to go with a 60 series you should get a 215 and not a 195. Even then the load range is iffy-- it goes out the window quickly when you go down in aspect.
I got that exact size from sears for $38 ea last winter, and DTD has a Memorial day sale on now. Can get four Cooper CS3s for $105. You could help the friend by slinging the credit and keeping the rebates, buying in your name.
Re: Putting 195/60/15 on a Car with 205/65/15 [Re: ram_man] #4104672 05/23/16 06:59 PM
W
Wolf359 Offline
W
I think you're off on your calculations. Typically if you go down a size, you go up a size in ratio like a 195/70/15 instead of a 60.
You can usually get junkyard tires for $20-$30 each and they usually have at least 1/2 the tread, sometimes as much as 70-80% if the car was in a wreck. Sometimes they even throw in mounting and balancing at that price. Or check your local craigslist.
Re: Putting 195/60/15 on a Car with 205/65/15 [Re: gaijinnv] #4104788 05/23/16 09:18 PM
Nick1994 Offline
HTH
The OP said a "car", so unless it's something for, the 70's, I highly doubt it's RWD.
Also, the OP has a PT Cruiser, so the 195 tires are probably off of that.
Re: Putting 195/60/15 on a Car with 205/65/15 [Re: ram_man] #4104819 05/23/16 10:00 PM
R
ram_man Offline OP
R
The car in question is a 99 Infiniti i30 I have a full set of 195/60/r15 decent tread I was going to give my friend 2 of them .
2014 dodge dart GT
1995 Dodge ram 1500
Re: Putting 195/60/15 on a Car with 205/65/15 [Re: ram_man] #4104934 05/24/16 05:41 AM
B
Bottom_Feeder Online Content
Online Content
B
You would be much better off getting tires that are the correct size. Used, new, cheap, whatever. Anything.
Re: Putting 195/60/15 on a Car with 205/65/15 [Re: ram_man] #4105188 05/24/16 10:32 AM
A
AlaskaMike Offline
A
I'm with Nick on this. This isn't rocket science, and we're not talking about trying to build a Steinway piano here. The existing tires on the car in question have the belts showing. The smaller tires, despite being smaller, are without question an improvement. I don't care what car it is.
Back in high school I thought it was cool to have taller tires on the back of my '68 Cougar. The car didn't leap off the road in a fiery Hollywood explosion at the first movement of the steering wheel, or slightest touch of the brakes. Somehow I put a whole bunch of miles on that car with different size tires front and rear, and I managed to stay alive.
Some of you guys need to put away the calculators and pocket protectors.
Re: Putting 195/60/15 on a Car with 205/65/15 [Re: ram_man] #4105203 05/24/16 10:51 AM
supton Offline
If cords are showing then I'd think anything is better, load index notwithstanding.
Load index withstanding, was 195/60's used in this application? I mean, some cars have that for a base size, and the optional tires are 205 or 215's, which I presume would have a high load index--but dropping down a size would not be hazardous.
2011 Toyota Camry, base, 2.5L/6MT, 201k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 157k, ours
1999 Toyota Camry LE, 2.2L/4AT, 223k, his
Re: Putting 195/60/15 on a Car with 205/65/15 [Re: ram_man] #4105210 05/24/16 10:58 AM
He's not only suggesting dropping a size in width, but also dropping a size in aspect ratio. Double whammy. Two wrongs don't make it right.
If you really want to help, do it right.
If he gifts a friend undersized tires that blow out due to overheating, whose fault is it going to be?
Page 1 of 3 1 2 3
