Old Tundra Headlamp Upgrade
by JeffKeryk - 01/21/20 09:41 PM
MOVIE: Dr. Dolittle
by Kira - 01/21/20 09:34 PM
Oil weight and Oil Grade
by Snagglefoot - 01/21/20 07:11 PM
Which air filter for RAV 4 Hybrid
by NH73 - 01/21/20 06:44 PM
Finding a good "cold weather" vehicle?
by Vern_in_IL - 01/21/20 06:15 PM
Bough NGK Ruthenium sparkplugs
by cronk - 01/21/20 06:07 PM
HF 30% Off $10 and Under
by TheLawnRanger - 01/21/20 06:02 PM
Stolen Battery-New one on Me
by bunnspecial - 01/21/20 05:29 PM
2006 Acura TSX Buying Advice
by maverickfhs - 01/21/20 04:35 PM
Castrol GTX Diesel 15W-40, CK4
by HDoilDude - 01/21/20 04:30 PM
Combo of P0068 and P307A
by Alfred_B - 01/21/20 04:30 PM
Are the plastic battery trays necessary?
by littlehulkster - 01/21/20 03:18 PM
Amsoil ATV/UTV Powertrain Fluid
by IowaFord - 01/21/20 02:13 PM
Motorcraft FL500s 3,630 miles.
by mpgo4th - 01/21/20 01:36 PM
Xcel Class Action Suit
by John_K - 01/21/20 12:33 PM
RV Freightliner Cummins ISB 6.7 oil question
by 1978elcamino - 01/21/20 11:48 AM
Why I became a pilot and not a doctor...
by jetman - 01/21/20 10:52 AM
Wrong oil or not ?
by M119 - 01/21/20 10:48 AM
IowaFord, Origami99, reylafo, PastPresMike, RedBeard83
70497 Registered Users
95 registered members (A310, alphadog, 69GTX, 2003f7, 4WD, 8 invisible), 2,403 guests, and 30 spiders.
Topics300,413
Posts5,175,235
Members70,497
Recommend a wet/dry vacuum #4104298 05/23/16 10:39 AM
dkryan Offline OP
I have a Craftsman wet/dry vac (older model) that has been decent, but I've noticed lately that when I use it indoors, it leaves a fine coating of dust on things.
Is it because I need to use the HEPA filter instead of the general purpose filter that I normally use?
I clean the filter after every use and dump the waste from the vac.
Thoughts?
2014 Nissan Altima 2.5 SL
Valvoline M-E 5w-30/Fram Ultra
2005 Toyota Highlander 3.3L
QSUD 5w-30/Fram Ultra
2019 Subaru Outback 2.5L Limited
Idemitsu Zeepro 0w-20/Wix XP
Re: Recommend a wet/dry vacuum [Re: dkryan] #4104314 05/23/16 10:55 AM
sleddriver Offline
Your subject line asks for a new vacuum recommendation, yet your post indicates dissatisfaction with your filter when used indoors. I'm confused.
Bag, foam, or pleated filter?
Do you want to replace the vac or the filter, or both?
1998 Volvo V70 T5 228,880 mi. Original Owner.
M1 10W-30 HM
"It's never a mistake to buy tools, defined broadly. They're not a cost, they're an investment." - J.B. Peterson
Re: Recommend a wet/dry vacuum [Re: dkryan] #4104375 05/23/16 11:57 AM
blupupher Offline
Change filter types.
I have a small (3 gallon?) wet dry that I have had for years. For outdoor use, I use the little blue cloth thing. For wet, I put the foam cover over it. Most indoor stuff I just use the blue cloth, but I have a cartridge that I use if I really need fine particles cleaned up and not spread into the air.
'18 Santa Fe: PP 10W-30/OEM
'18 Soul: Synpower 5W-30/PG
'10 Santa Fe: Synpower 5w-30/D+
'04 F150: Magnatec 10w-30/ST
'12 xB: M1EP 0W-20/CQ Blue
'02 F150: Magnatec 5W-20/D+
'94 VT1100: Peak 15W-40/D+
Re: Recommend a wet/dry vacuum [Re: dkryan] #4104463 05/23/16 01:56 PM
E
Ethan1 Offline
E
You can find all kinds of filters at Sears (or KMart - if you're brave!)
Re: Recommend a wet/dry vacuum [Re: dkryan] #4104478 05/23/16 02:27 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
I've got a big wet dry that I use dry only. In the few times I've had to use a wet cac, I use a smaller (2.5 gal) vac. At 8 lb/gal, I'm not all that interested in carrying a ton of water to dump someplace safe. Then again, knock on wood, I've never encountered that much water to suck up.
Re: Recommend a wet/dry vacuum [Re: dkryan] #4104493 05/23/16 02:41 PM
M
Merkava_4 Offline
M
I recommend this + this
Re: Recommend a wet/dry vacuum [Re: Merkava_4] #4104511 05/23/16 03:16 PM
J
JerryBob Offline
J
+1
The Ridgid vacs are the definitely the go-to vacs. I've had the same contractor grade for 8 years, and still going strong.
Re: Recommend a wet/dry vacuum [Re: dkryan] #4104556 05/23/16 04:18 PM
spasm3 Online Happy
Online Happy
I have an older rigid probably 18 years old. Great, i'd buy another without hesitation.
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Recommend a wet/dry vacuum [Re: dkryan] #4104567 05/23/16 04:32 PM
Skid Offline
You can add one of these as a pre-filter (I use one on a 3.5 gallon bucket):
http://www.amazon.com/Oneida-Molded-Dust-Deputy-Cyclone/dp/B002JP315K
The really fine stuff will eventually clog the regular filter element, however.
Re: Recommend a wet/dry vacuum [Re: sleddriver] #4104745 05/23/16 08:26 PM
dkryan Offline OP
Thanks for the reply, sleddriver.
I was actually asking both.
I use the vac "dry" 90% of the time.
My question referred directly to the dust that is obviously emanating from the vac. "General purpose pleated filter" or should I be using a HEPA filter indoors?
Or buy another vac?
Thanks.
Re: Recommend a wet/dry vacuum [Re: Merkava_4] #4104749 05/23/16 08:32 PM
dkryan Offline OP
Thanks, Merkava.
Re: Recommend a wet/dry vacuum [Re: dkryan] #4104825 05/23/16 10:09 PM
tom slick Offline
I like Gore Cleanstream filters.
http://www.cleanstream.com
You get what you pay for...
So keep in mind how much you paid for this advice.
Re: Recommend a wet/dry vacuum [Re: dkryan] #4105045 05/24/16 07:47 AM
dkryan Offline OP
Thanks, Tom!
Re: Recommend a wet/dry vacuum [Re: dkryan] #4106340 05/25/16 01:38 PM
sleddriver Offline
Or buy another vac?
Thanks.
You didn't mention what brand of vac you presently have. If available for your vac, I'd recommend a Clear-Stream pleated filter made of Gore-Tex. You can vac up fireplace ashes & sheetrock dust with it, then simply rinse it off with water to clean. Rather amazing actually and well worth the cost. I've been using them for 20yrs on two different vacs with no worries.
Re: "Another Vac". I have a small Fein that is incredibly quiet, comes with a great hose, a powerfull motor and produces lots of suction. Great for indoor & auto use, but I don't use it for 'wet' nor nasty jobs.
The second one, a Rigid, gets used for that. It's the $100 model, picked up cheap at a garage sale. Strong suction, has a tub drain, fitted with a Clear Stream filter.
A great tip is to replace the cheap, restrictive hose with 2-1/2" dust collection hose + accessories from Rockler, Woodcraft, etc. With couplers, you can make hose any length, long rigid pipe sections + a floor sweep to vac up water or the garage floor. Less restriction = more CFM + you'll save $$$$ as well.
A great benefit is this 2-1/2" hose works with both the Fein & the Ridgid!
M1 10W-30 HM
