Chrome Polish
by rrretiree7 - 01/22/20 11:57 PM
2009 Infiniti G37x
by mjk - 01/22/20 10:51 PM
Boy did I have a scare today! Still a little concerned...
by SubieRubyRoo - 01/22/20 10:32 PM
Castrol Edge 0w20
by Mr_Luke - 01/22/20 10:17 PM
Air purifier/vacuum scheme?
by The_Eric - 01/22/20 09:14 PM
Car for short, elderly person?
by BBDartCA - 01/22/20 08:34 PM
Amsoil discontinues ACD SAE 30/10w30 HDEO
by CleverUserName - 01/22/20 07:34 PM
Chromium-based Microsoft Edge
by uc50ic4more - 01/22/20 07:13 PM
Reason for new car problems
by Exhaustgases - 01/22/20 05:50 PM
Selling the VW need a replacement.
by ram_man - 01/22/20 05:48 PM
Williams Tools Made in Taiwan
by BBDartCA - 01/22/20 05:32 PM
Synthetic Power Steering Fluid?
by TXCarGeek - 01/22/20 05:03 PM
New 5% RA discount code
by bullwinkle - 01/22/20 04:12 PM
17 Dodge Ram 6.7, 5K
by merdog - 01/22/20 02:16 PM
Mobile 1 in a Subaru Manual transaxle?
by someoldguy - 01/22/20 01:17 PM
Castrol and NASCAR
by kstanf150 - 01/22/20 01:14 PM
AMSoil Signature / AMSoil European - 5-40
by 335xiE92FBO - 01/22/20 12:06 PM
How happy are you in your profession ?
by Mr Nice - 01/22/20 11:52 AM
Mikemac2008, Jeff1024, EricWestland, Brian200001, Phildrum
70507 Registered Users
60 registered members (AZjeff, 77GrandPrix, 750IX, Bailes1992, bradepb, 5 invisible), 1,036 guests, and 16 spiders.
Topics300,451
Posts5,176,108
Members70,507
Mercon V - Amalie or Castrol for 2002 Lincoln? #4104152 05/23/16 07:18 AM
69GTX Offline OP
Was figuring to load up on Walmart's ST Mercon V ($4.19) for a 14-16 qt fluid change on my 2002 Lincoln. But, the local stores are out of stock. Doesn't appear ordering it will speed it up either. The other closest prices are Amalie ($4.61) and Castrol ($5.19 on sale). For an extra $10 the Castrol is probably the safest bet. Don't know much about Amalie.
Castrol is certified and approved by Ford. Amalie just "meets" Ford's requirements. WIX filter package runs $22.65 with rubber gasket. Ford dealer wants $7/qt, $39 for filter, and $43 for gasket, all MotorCraft parts. For those prices I'd almost expect labor included. My OEM rubber gasket should be reusable anyways.
Common filter choices appear to be Napa ATP 18553, AAP/B-155, Duralast (AutoZone) TF217, Wix 58822, TF151 Hastings, M/C FT158...all mostly in the $17-$22 range.
2001 Lincoln Cont 4.6L DOHC/ 50K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Mercon V - Amalie or Castrol for 2002 Lincoln? [Re: 69GTX] #4104171 05/23/16 07:38 AM
B
Bgallagher Offline
B
Castrol makes some great ATFs, Wix or MC would be my choices in filters. Amalie is a good brand but I always felt that Castrol and Valvoline make some top notch ATFs.
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
Re: Mercon V - Amalie or Castrol for 2002 Lincoln? [Re: Bgallagher] #4104174 05/23/16 07:45 AM
69GTX Offline OP
Didn't know this earlier, but Amalie bought Wolfshead from Shell/Pennzoil a few years back.
My 1997 Lincoln had the same engine/trans as my 2002. The 1997 owner's manual specs Mercon. By 2002 they up-specced to Mercon V. Considering I could probably use DEX III/Mercon in either of these cars, Valvoline Max Life ATF might be an option too.
1969 Ply GTX/RRs
Re: Mercon V - Amalie or Castrol for 2002 Lincoln? [Re: 69GTX] #4104238 05/23/16 09:17 AM
N
Noey Offline
N
Save the money.
Check the specs, they're all the same.
"I don't know nothin' 'bout birthin' babies!"
Re: Mercon V - Amalie or Castrol for 2002 Lincoln? [Re: 69GTX] #4104288 05/23/16 10:24 AM
R
rq375 Offline
R
The pan gasket is reusable, torque it to proper specs and it will not leak. I don't even pull them off the pan, just make sure both surfaces are clean.
Motorcraft trans filter box will contain a made in China Filtran, no point in paying a premium.
Maxlife atf meets Mercon, Mercon V, and Mercon LV, I would not use a fluid that meets LV in a trans speced for Mercon/V.
Re: Mercon V - Amalie or Castrol for 2002 Lincoln? [Re: 69GTX] #4104459 05/23/16 01:47 PM
E
Ethan1 Offline
E
The pan gasket really is reusable. I thought that mine was seeping at first but it was just drips from spilling fluid when refilling. smile
Re: Mercon V - Amalie or Castrol for 2002 Lincoln? [Re: 69GTX] #4104554 05/23/16 04:13 PM
slacktide_bitog Offline
Maxlife smile
Re: Mercon V - Amalie or Castrol for 2002 Lincoln? [Re: 69GTX] #4104562 05/23/16 04:26 PM
O
Oregoonian Offline
O
Mercon V...the Ford recommended ATF.
A few years back I ordered the amount needed from O'Reileys, had the had it for me the next day.
03' Ford Focus SE(2.3L Duratec PZEV)/ 140K +
Pnz. Ultra 0w20 / Fram 'Ultra'/ OCI: 8000 +/-
ATF: Mercon V w/Lubegard Red
Re: Mercon V - Amalie or Castrol for 2002 Lincoln? [Re: 69GTX] #4104883 05/24/16 02:58 AM
L
Lubener Offline
L
I doubt either would matter.
The "thinking" man's friend.
Re: Mercon V - Amalie or Castrol for 2002 Lincoln? [Re: 69GTX] #4105967 05/25/16 06:25 AM
T
tig1 Offline
T
I used M1 ATF in my 96 Merc GM with 30-40K OCIs. With 218K when sold the shifting, both up and down was fine.
2007 Ford Fusion 252,000 miles
M1 5-20HM
2017 Ford Fusion 85K
M1 0-20EP
M1 ATF and M1 LV HP ATF
M1 10-30 in all OPE
MC filters
Re: Mercon V - Amalie or Castrol for 2002 Lincoln? [Re: 69GTX] #4106220 05/25/16 11:42 AM
dew Offline
Maxlife
Best bang for the buck. It has improved my shift quality over Supertech. A little crisp at first but it has settled in to like new shift quality.
I'll drain and fill 4 quarts about every 30k now. Every 20k before synthetic.
Re: Mercon V - Amalie or Castrol for 2002 Lincoln? [Re: 69GTX] #4115205 06/04/16 04:18 PM
chucky2 Offline
NAPA I believe has Valvoline Mercon V if you ask for it.
Re: Mercon V - Amalie or Castrol for 2002 Lincoln? [Re: 69GTX] #4115211 06/04/16 04:32 PM
You should also get the Dorman transmission pan, which includes a drain plug, so you won't have to remove it again. You have the AX4N, right? Dorman part number 265-803.
Maxlife is great stuff. Valvoline also makes Napa's house brand ATF.
