2016 or 17 Honda CR-V
by Loogie - 02/27/20 05:20 AM
RIP Clive Cussler
by PimTac - 02/27/20 04:48 AM
Pirelli Cinturato P7 Allseason PLUS "II"
by Char Baby - 02/27/20 03:31 AM
CCI clean .22 ammo - polymer coated HV
by Shannow - 02/27/20 03:23 AM
5w-20 vs 5w-30
by joel95ex - 02/26/20 10:59 PM
Need help d/l'ing vids from JVC GZ-MG27
by daves66nova - 02/26/20 10:18 PM
Need a riding mower
by FirstNissan - 02/26/20 08:32 PM
Just bot Quicken 2020 Premier for
by Ed_T - 02/26/20 08:31 PM
Corona Virus and Car Sales?
by Vern_in_IL - 02/26/20 07:34 PM
Emblem Adhesive Recommendation
by Fitz98 - 02/26/20 07:18 PM
Drain Plug Washer Frozen to Oil Pan
by CrackyWainwright - 02/26/20 06:31 PM
ams OE 0/20 6100 mi 14 KIA 2.4L GDI
by pair of Blazers - 02/26/20 06:17 PM
Any Exotic Brand Dealership Mechanics Here?
by john_pifer - 02/26/20 06:14 PM
Sentra no start
by Aredeeem - 02/26/20 06:07 PM
Sync Update 2016 Cmax
by borgward - 02/26/20 03:30 PM
Kirkland 0w20 at local Costco
by paulri - 02/26/20 03:12 PM
LG Red in a VW DSG trans?
by racin4ds - 02/26/20 02:31 PM
2013 Jaguar XF 3.0 AWD
by ET16 - 02/26/20 02:25 PM
Ford....in trouble??
by earthbound - 02/26/20 01:31 PM
Scotts994Runner, Bu33leGutz, splitthebreak, shadango, JimNastic316
70808 Registered Users
47 registered members (Bailes1992, 53' Stude, antone, Amkeer, AurionX2, Aichiguy, 4 invisible), 1,029 guests, and 20 spiders.
Topics301,970
Posts5,206,667
Members70,808
2004 corolla with sludge fix #4104052 05/23/16 03:52 AM
M
Msalem Offline OP
M
Hi I'm new in the forum and registered especially for this question hope you can help me
I have a Toyota corolla 2004 with 3zz Fe engine that owned for 3 years at the start I used Toyota oil 10w30 that it burns about 1.5 Lt every 5000 km and had to clean the oil screen every year to clean oil sludge that was formed because previous owner changed oil every 15000 km now I I used different oil type max life and Mobil 1 the only oil that stopped the burn is liqui moly 5w40 now the problem is liqui moly is fine oil and clean the sludge well causing the oil screen to get dirty only after 1 month of use can I use liqui moly engine flush to clean what's left or what can I do I don't want to harm the engine
Thank you
Re: 2004 corolla with sludge fix [Re: Msalem] #4104072 05/23/16 05:02 AM
T
Trav Offline
T
What does it look like under the valve cover? Its possible most of your sludge is coming from that area and may need to be cleaned manually.
I would begin by removing the valve cover to get a better idea of your your dealing with and doing an overnight piston soak through the spark plug holes.
Manually clean the head and drain back holes if necessary, remove the pan and clean it and the pickup screen then run a short oil change with cheap oil to flush any residual away.
Post pictures and ask questions if you need help on how to do any of this.
I would probably run Mobil 1 0w30, Castrol 0w40, or Euro Castrol 0w30 in this engine in your climate, you will probably be better served with an oil with a 3.5 min HTHS.
Re: 2004 corolla with sludge fix [Re: Msalem] #4104076 05/23/16 05:15 AM
Y
yvon_la Offline
Y
ground head directly to the frame with an aluminium wire!
Truck driver
Nissan versa note s 2014 total classic 5w30(qc.ca) drivework oil filter
Re: 2004 corolla with sludge fix [Re: Msalem] #4104103 05/23/16 06:00 AM
M
Msalem Offline OP
M
Re: 2004 corolla with sludge fix [Re: Msalem] #4104108 05/23/16 06:09 AM
T
Trav Offline
T
Nothing with that link.
Re: 2004 corolla with sludge fix [Re: Msalem] #4104122 05/23/16 06:36 AM
B
barkingspider Offline
B
Clean under valve cover, clean oil pan & screen, valve soak, and short OCIs as suggested above. I prefer 5 or 10w30, but If 5w40 is working for you, then keep using it
04 Avalanche Z71 4x4
Re: 2004 corolla with sludge fix [Re: Msalem] #4104129 05/23/16 06:45 AM
T
The_Eric Offline
T
Yes, what Trav said- remove the rocker cover and the oil pan, then manually clean it up.
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
Re: 2004 corolla with sludge fix [Re: Msalem] #4104175 05/23/16 07:45 AM
M
Msalem Offline OP
M
Re: 2004 corolla with sludge fix [Re: Msalem] #4104177 05/23/16 07:45 AM
M
Msalem Offline OP
M
Re: 2004 corolla with sludge fix [Re: Msalem] #4104178 05/23/16 07:46 AM
M
Msalem Offline OP
M
Sorry I try to post pic but no use
Re: 2004 corolla with sludge fix [Re: Msalem] #4104184 05/23/16 07:49 AM
M
Msalem Offline OP
M
[img]http://s1381.photobucket.com/user/msalem052372594/media/Mobile%20Uploads/20160323_161136_zpsdhtvnapj.jpg.html][IMG]http://i1381.photobucket.com/albums/ah23...zpsdhtvnapj.jpg[/img][/URL][/img]
Re: 2004 corolla with sludge fix [Re: Msalem] #4104186 05/23/16 07:52 AM
M
Msalem Offline OP
M
Try last post I think this pic will work
Re: 2004 corolla with sludge fix [Re: Msalem] #4104187 05/23/16 07:57 AM
O
Oldmoparguy1 Offline
O
Here you go.
Actually, it doesn't look that bad.
A Randomly Selected Thought For The Day:
If Noah had used Zip, he could have used a smaller boat.
Re: 2004 corolla with sludge fix [Re: yvon_la] #4104189 05/23/16 08:00 AM
H
HerrStig Offline
H
Why? (this has GOT to be good)
Re: 2004 corolla with sludge fix [Re: Msalem] #4104196 05/23/16 08:15 AM
M
Msalem Offline OP
M
Mean can I use liqui moly engine flush for 10 minute cause my friend advised for doing it as he is mechanic and will it be effective in washing the remaining sludge
