Castrol edge 0w40
by VQLT - 02/18/20 08:32 AM
Scrap value of this catalytic converter
by atikovi - 02/18/20 06:10 AM
How drunk do you have to be to do this?
by dishdude - 02/17/20 11:09 PM
At least they show you
by Jake777 - 02/17/20 10:04 PM
Ryan Newman update
by P10crew - 02/17/20 09:17 PM
Thoughts on 2015+ Kia Sedona?
by 92saturnsl2 - 02/17/20 09:16 PM
Quiet riding tire
by wolf_06 - 02/17/20 08:27 PM
Where did the Ryan Newman thread go??
by P10crew - 02/17/20 08:02 PM
2013 FX4 repair.
by marine65 - 02/17/20 07:36 PM
New gaming build shutting down on Metro 2033
by Cujet - 02/17/20 07:09 PM
Snapon
by P10crew - 02/17/20 06:51 PM
Conventional or Synthetic
by charmer37 - 02/17/20 06:49 PM
Jeep Wrangler 3.0L Diesel
by HighbrowHillbill - 02/17/20 06:36 PM
94 B4000 overheat Eureka
by HyundaiAbuser - 02/17/20 05:48 PM
PP Euro 5w40 SN Plus formulation VOA
by BurntMusic - 02/17/20 04:35 PM
Bicycle Shops
by CourierDriver - 02/17/20 04:26 PM
EBC Brakes
by hatt - 02/17/20 04:17 PM
Dream Car
by MrQuackers - 02/17/20 04:06 PM
What are people using now for outdoor antennas?
by BAJA_05 - 02/17/20 02:49 PM
tpap, ratt, jeffreytmann, boureesub, Bayrim
70737 Registered Users
88 registered members (BeerCan, Blkstanger, Astro14, Alfred_B, ARB1977, 8 invisible), 1,877 guests, and 20 spiders.
Topics301,600
Posts5,198,891
Members70,737
CQ Blue 84151 | 5,018 Miles | 3 Months [Cut Open] #4103639 05/22/16 01:11 PM
2015_PSD Offline OP
This is the filter from my Powerstroke and is one of the Affinia (WIX) made CarQuest Blues that I bought for $4.06 from Rock Auto back in 2015. Pleats are nice and straight, it had a quart of oil in it so the ADBV was working and it was very pliable, all in all there are no complaints here (well except the oil can stain as badly as crude). Kendall Super-DXa 15W-40 SynBlend was used with this filter and another Affinia made CQ Blue took its place along with Mobil Delvac 1 ESP 5W-40. Unlike my Explorer, it is not possible to capture a good photo of the Gold Plug because the oil pan is steel and I can never remove it without it sticking and rubbing the tip, but I could see some buildup on the end.
Enjoy!
2019 o)|||||(o Rubicon Wrangler Unlimited 3.6L V6 [Castrol Edge + Mahle]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum + Mann filter]
Re: CQ Blue 84151 5,018 Miles | 3 Months [Cut Open] [Re: 2015_PSD] #4103643 05/22/16 01:13 PM
Shellguy Offline
That might be my goto filter on that beast (esp with that wire backing)..lol nice pics
2012 F-150 5.0-Pennzoil Platinum 5w30/Amsoil Eao17
Re: CQ Blue 84151 5,018 Miles | 3 Months [Cut Open] [Re: Shellguy] #4103644 05/22/16 01:15 PM
2015_PSD Offline OP
Hard to beat the price and wire-backed media to boot! grin
Re: CQ Blue 84151 5,018 Miles | 3 Months [Cut Open] [Re: 2015_PSD] #4103680 05/22/16 02:19 PM
Z
ZeeOSix Offline
Z
Now that's how you make decent louvers.
Re: CQ Blue 84151 5,018 Miles | 3 Months [Cut Open] [Re: 2015_PSD] #4103997 05/22/16 11:35 PM
R
robo339 Offline
R
Glad to see this since it's what is on my 6.7 right now
2014 f150 5.0 62K miles
Re: CQ Blue 84151 5,018 Miles | 3 Months [Cut Open] [Re: 2015_PSD] #4104119 05/23/16 06:31 AM
N
Nyogtha Offline
N
Good looking filter.
Waiting to see if crazyoildude will comment on the use of louvers by Wix, and his (unfounded) hypothesis this reduces the velocity of the oil through the media to reduce tearing potential vs. round holes in the center tube.
It certainly reduces the velocity through the center tube perforations, and therefore overall differential pressure, but only the type & quantity of media affects the velocity through the media for a given flow set of conditions. This filter obviously uses wire backed media to reduce tearing potential and stand up to the operating conditions of the engine it's designed for.
"No matter how paranoid you are you're not paranoid enough. Tell the truth. Reach as many people as you can with it. That's your weapon." - Susanne Modeski, aka "Holly" to The Lone Gunmen
Re: CQ Blue 84151 5,018 Miles | 3 Months [Cut Open] [Re: Nyogtha] #4104147 05/23/16 07:13 AM
2015_PSD Offline OP
Originally Posted By: Nyogtha
Good looking filter. Waiting to see if crazyoildude will comment on the use of louvers by Wix, and his (unfounded) hypothesis this reduces the velocity of the oil through the media to reduce tearing potential vs. round holes in the center tube. It certainly reduces the velocity through the center tube perforations, and therefore overall differential pressure, but only the type & quantity of media affects the velocity through the media for a given flow set of conditions. This filter obviously uses wire backed media to reduce tearing potential and stand up to the operating conditions of the engine it's designed for.
I would counter, at least in this filter's case, there is at least as much surface area (actually, I think it is more) with this slot design versus holes. What is not readily apparent is there are slots on both sides (some facing up and the others facing down) and we are only seeing one half of them.
Re: CQ Blue 84151 5,018 Miles | 3 Months [Cut Open] [Re: Nyogtha] #4104413 05/23/16 12:51 PM
Z
ZeeOSix Offline
Z
What a well designed louvered center tube does do is help more evenly distribute the oil flow through the media. An extreme example would be if there were only two large holes in the center tube opposite each other, then all the flow would be spit between those two holes. That would mean a pretty good concentration of oil flow would be going through the media just opposite those two holes, which could cause more force on the media at those two spots.
But as we have all seen. the old traditional center tube with a bunch of round holes has always seemed to work fine. I think the manufactures are switching to louvers because it's easier and less messy to manufacture that way. But I still would not feel comfortable if I look down the center of an oil filter and see louvers that are barely opened the thickness of a piece of paper. It shouldn't be rocket science to open them up a fair amount to take all doubt out of their flow capability.
Re: CQ Blue 84151 5,018 Miles | 3 Months [Cut Open] [Re: 2015_PSD] #4104584 05/23/16 04:53 PM
SirTanon Offline
That's a very robust looking filters, and I must agree that the louvers are nice and open..
.. but that oil is BLACK. Was there any additive in there with it, or are we just looking at lots of turbo soot?
2013 Nissan Altima SV - 2.5 liter/CVT - 125,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 68,000mi
2010 Ford Fusion - 274k mi - SOLD
Re: CQ Blue 84151 5,018 Miles | 3 Months [Cut Open] [Re: 2015_PSD] #4104593 05/23/16 05:06 PM
R
robo339 Offline
R
It's oil out of a diesel they always look really black
Re: CQ Blue 84151 5,018 Miles | 3 Months [Cut Open] [Re: 2015_PSD] #4104611 05/23/16 05:31 PM
U
UncleDave Offline
U
Thanks
Looks good to me..
always curious about the magnetic drain plugs condition- so thanks for the update as well
UD
Uncle Dave
Cat 3126/2 MB3500/Titan/RX400H/17 Ridgeline
700HP V10/ 725HP BBC/ Raptor 700/ KFX450/ YZ250/Onan 8K/ Cat3011C
Re: CQ Blue 84151 5,018 Miles | 3 Months [Cut Open] [Re: UncleDave] #4104669 05/23/16 06:57 PM
2015_PSD Offline OP
Here is a photo of the Gold Plug from my Explorer:
Re: CQ Blue 84151 5,018 Miles | 3 Months [Cut Open] [Re: 2015_PSD] #4104747 05/23/16 08:29 PM
U
UncleDave Offline
U
I'd much rather have that ferrous goo on the plug that going round in the mill.
Thanks.
UD
Uncle Dave
Re: CQ Blue 84151 | 5,018 Miles | 3 Months [Cut Open] [Re: 2015_PSD] #4104909 05/24/16 05:03 AM
Sayjac Offline
Stout looking filter construction, very high quality imo. You definitely got your money's worth with these RA CQ filters.
As you bought these last year, shows Affinia/Wix using a louvered center tube design in some applications even before the M&H acquisition.
Thanks for pics.
