2010 Subaru OB 3.6R, 3500miles, 76semisyn
You are throwing away good oil.
If you chose to..you could easily do 10K miles.
Great motor and great used oil.
You could defy factory OCI's further, and I would've considered a 7K/10K mi OCI
Originally Posted By: charger
Another boring run on a thirsty 3.6R motor. Approx. 3/4 quart consumption during run.
Report
http://imgur.com/11RTXDi Prior conventional run
That's not consumption. My Honda sucks down 0w20 at about a quart per 2k. Which is why I run 5w30 or 5w40 (doesn't hardly use a drop) during the non winter months.
Great report!!
Did you change the air filter? I see your sodium went down a lot on this report, and so did your iron levels. Can you attribute that to anything?
Here is my UOA on our 2009 Subie with the 4 cylinder. I used MOS2, but ran with M1 5w40 TDT, instead of SuperTech.
My 2009 Subie UOA with LM MOS2
