Astra 400 ?
by WyrTwister - 02/27/20 09:58 AM
Will thinner oil damage anything when it is burned?
by Fordiesel69 - 02/27/20 09:38 AM
Old news for Hyundai/Kia?
by Farnsworth - 02/27/20 09:33 AM
Looking for AA 25% off coupon code.
by JustChuck - 02/27/20 09:17 AM
New to the LS460 and The World Of Lexus. Questions!
by gr8gatzby - 02/27/20 08:41 AM
New old guy back.
by BJD2020 - 02/27/20 07:45 AM
Help me Decide
by Gebo - 02/27/20 07:36 AM
FWD - Death traps with miss matched tires.
by Fordiesel69 - 02/27/20 07:13 AM
Napa Gold Sale
by Toto - 02/27/20 06:52 AM
2016 or 17 Honda CR-V
by Loogie - 02/27/20 05:20 AM
RIP Clive Cussler
by PimTac - 02/27/20 04:48 AM
Pirelli Cinturato P7 Allseason PLUS "II"
by Char Baby - 02/27/20 03:31 AM
CCI clean .22 ammo - polymer coated HV
by Shannow - 02/27/20 03:23 AM
5w-20 vs 5w-30
by joel95ex - 02/26/20 10:59 PM
Need help d/l'ing vids from JVC GZ-MG27
by daves66nova - 02/26/20 10:18 PM
Need a riding mower
by FirstNissan - 02/26/20 08:32 PM
Just bot Quicken 2020 Premier for
by Ed_T - 02/26/20 08:31 PM
Corona Virus and Car Sales?
by Vern_in_IL - 02/26/20 07:34 PM
Emblem Adhesive Recommendation
by Fitz98 - 02/26/20 07:18 PM
Scotts994Runner, Bu33leGutz, splitthebreak, shadango, JimNastic316
70808 Registered Users
102 registered members (2015_PSD, Anduril, 4WD, aquariuscsm, 53' Stude, alchargo, 8 invisible), 2,118 guests, and 16 spiders.
Topics301,984
Posts5,206,838
Members70,808
Power Washer oil change today #4103256 05/22/16 12:44 AM
G
Georgiey22 Offline OP
G
After 2 years and 10+ hours of use, I changed the oil on my pressure washer for the first time. It is a 4 stroke Honda engine, purchased the pressure washer at Costco. Manual calls for 15W40 oil, have lots of 5W30 M1 Extended Performance in my stash, so I drained the FF and added the M1 5W30EP. Ran it for 45 minutes today on the fresh oil and it runs perfect, however...
What is your opinion should I keep it in the washer or should I drain it and run a 40 weight? Please share your thoughts??
Garage:
2019 Toyota Tundra 5.7L - M1 EP 0W20 w/OEM Filter (4K miles)
2016 Toyota 4Runner 4.0L - M1 AP 5W20 w/OEM Filter (29K miles)
2013 Acura TL 3.5L - Mobil 1 EP 0W20 w/OEM Filter (55K miles)
Re: Power Washer oil change today [Re: Georgiey22] #4103271 05/22/16 01:33 AM
F
Farmer Offline
F
I use Delo 10W30. I don't see what's stopping you.
Re: Power Washer oil change today [Re: Georgiey22] #4103272 05/22/16 01:33 AM
Marco620 Offline
Maybe run a 15w40 syn and call it a day. The 5w30 Mobil 1 was probably okay but get a 15w40 syn and swap it out and forget about it.
15' Civic 1.8 i-vtec 311,000 mi M1 0w30 & LG Biotech, BP CVT Fluid,GUMOUT W/ PEA
Doberman Whisperer!
E pluribus unum.
Re: Power Washer oil change today [Re: Georgiey22] #4103293 05/22/16 03:30 AM
demarpaint Offline
My 11 HP Honda power washer calls for 10W30, but it's a lot older than yours.
God Bless Our Troops
Re: Power Washer oil change today [Re: Georgiey22] #4103311 05/22/16 04:43 AM
M
marc1 Offline
M
Interesting, what engine model is it? Mine is a Honda GC190 and the manual asks for 5w30, 10w30 or if above 50F straight 30. The preferential grade mentioned is 10w30. The factory fill oil was a 10w30 (it came in a Karcher bottle). I have changed it once (after the first 2 hours or so when new) and am now using Esso XD3 0w30 (same for my snow blower). I find all the pull start engines I have ever owned are quite sensitive while trying to start them to the low temperature number so I like that to be quite low (0w or 5w) if possible. This GC190 engine is probably my favorite small engine I have ever owned, it is very quiet, starts on the first few pulls out of hibernation then on the first pull during regular use, uses no oil and is run hard for hours on end (idle - WOT - idle - WOT... etc.). Does your manual provide a chart showing viscosity choice against ambient temp or just 15w40 and nothing else?
2017 Tacoma SR5 4WD 24k km M1 EP 0w20 M1 EP Filter
Gone but not forgotten:
1970 Chevelle SS454 LS6
1970 GTO Judge RAIV
1968 GTO
1968 GS400
2011 Shelby GT500
Re: Power Washer oil change today [Re: Georgiey22] #4103335 05/22/16 06:02 AM
J
Jimzz Offline
J
Since you used a syn oil its probably ok in the protection area.
Only thing is it might use a little more oil buy always good to check the level before using anyways.
yup
Re: Power Washer oil change today [Re: Georgiey22] #4103348 05/22/16 06:17 AM
toneydoc Offline
Use the Mobil 1 with confidence
1994 Jeep 167k NextGen 10w30
2014 Camry 44k Castrol Magnatec 0w20
2018 Jeep Cherokee 8k Pennzoil Platinum 5w30
2014 HD Ultra 51k Mobil1 15w50
Re: Power Washer oil change today [Re: Georgiey22] #4103399 05/22/16 07:24 AM
Donald Offline
I would run Rotella T6. Given that it takes a QT or so and you change the oil ever year or two I would use the proper oil.
However I probably would not dump what you have. Just go to the proper oil during the next oil change.
2015 Ford F-250 w/Powerstroke
Re: Power Washer oil change today [Re: Georgiey22] #4103412 05/22/16 07:47 AM
J
JR Offline
J
Run that syn 5w-30 with confidence. It is a 30 at temp.
Harvey
97 F250HD 7.3 320K 01 Astro 220K
93 metroXFi 94.5K
01 Impala 300K
04 RTV900R 1150hrs
Re: Power Washer oil change today [Re: Georgiey22] #4103424 05/22/16 08:02 AM
T
tig1 Offline
T
For the last 20-25 years I have used M1 10-30 in all of my OPE, including my Craftsman PW. Never had an engine wear problem.
2007 Ford Fusion 254,000 miles
M1 5-20HM
2017 Ford Fusion 86K
M1 0-20EP
M1 ATF and M1 LV HP ATF
M1 10-30 in all OPE
MC filters
Re: Power Washer oil change today [Re: Georgiey22] #4103460 05/22/16 08:55 AM
dave123 Offline
If washer pump has oil I'd change that FF as well.
Re: Power Washer oil change today [Re: Georgiey22] #4103463 05/22/16 08:58 AM
R
Rand Offline
R
what model recommends 15w40? never seen it.
Re: Power Washer oil change today [Re: Rand] #4103508 05/22/16 10:06 AM
A
abycat Offline
A
I've only seen chinese washers reccomend that. And it's usually in the pump side of it.
2017 dodge caravan gt
2011 nissan versa hb
Re: Power Washer oil change today [Re: Rand] #4103534 05/22/16 10:55 AM
dave123 Offline
+1 never seen on a Honda
Re: Power Washer oil change today [Re: Georgiey22] #4103820 05/22/16 05:57 PM
B
bubbatime Offline
B
I've never seen a Honda recommend anything but 5W30 or 10W30. Look up the engine manual for that engine and you will find that Honda recommends a 30 weight. So you are fine.
The manufacturer of the pressure washer is the one that is probably recommending the 40 weight, which is actually a very good recommendation because pressure washers are ran at full throttle and full load for their entire life span.
So I would use that synthetic 5W30 with confidence. Next time you are at the store, pick up a jug of 5W40 synthetic for the next oil change.
I'm still using my free after rebate synthetic 10W30 Valvoline VR1 oil in my pressure washers with full confidence.
2019 Honda CRV 1.5T dealer bulk
2017 Chrysler Pacifica SuperTech synthetic 5W20
2013 Yamaha XT250 Valvoline motorcycle 10W40
2006 GMC Sierra SuperTech high mileage 5W30
