Chrome Polish
by rrretiree7 - 01/22/20 11:57 PM
2009 Infiniti G37x
by mjk - 01/22/20 10:51 PM
Boy did I have a scare today! Still a little concerned...
by SubieRubyRoo - 01/22/20 10:32 PM
Castrol Edge 0w20
by Mr_Luke - 01/22/20 10:17 PM
Air purifier/vacuum scheme?
by The_Eric - 01/22/20 09:14 PM
Car for short, elderly person?
by BBDartCA - 01/22/20 08:34 PM
Amsoil discontinues ACD SAE 30/10w30 HDEO
by CleverUserName - 01/22/20 07:34 PM
Chromium-based Microsoft Edge
by uc50ic4more - 01/22/20 07:13 PM
Reason for new car problems
by Exhaustgases - 01/22/20 05:50 PM
Selling the VW need a replacement.
by ram_man - 01/22/20 05:48 PM
Williams Tools Made in Taiwan
by BBDartCA - 01/22/20 05:32 PM
Synthetic Power Steering Fluid?
by TXCarGeek - 01/22/20 05:03 PM
New 5% RA discount code
by bullwinkle - 01/22/20 04:12 PM
17 Dodge Ram 6.7, 5K
by merdog - 01/22/20 02:16 PM
Mobile 1 in a Subaru Manual transaxle?
by someoldguy - 01/22/20 01:17 PM
Castrol and NASCAR
by kstanf150 - 01/22/20 01:14 PM
AMSoil Signature / AMSoil European - 5-40
by 335xiE92FBO - 01/22/20 12:06 PM
How happy are you in your profession ?
by Mr Nice - 01/22/20 11:52 AM
Mikemac2008, Jeff1024, EricWestland, Brian200001, Phildrum
70507 Registered Users
40 registered members (bradepb, cjcride, CapriRacer, Char Baby, AurionX2, 5 invisible), 1,236 guests, and 20 spiders.
Topics300,451
Posts5,176,104
Members70,507
How long did it take?......window motor failure #4102746 05/21/16 12:07 PM
W
wrcsixeight Offline OP
W
My drivers side window has been acting a bit funny, sounding like it is struggling, and taking longer to open and shut than the passenger side, but not always, often it is just a bit slower than passenger side.
I am fairly sure it is not a wiring/connector/switch issue.
Was just wondering how long others might have observed since they first noticed the motor getting weak, and total unresponsive failure.
Need to budget time and money for attending to this.
Re: How long did it take?......window motor failure [Re: wrcsixeight] #4102751 05/21/16 12:11 PM
SatinSilver Offline
I noticed this with the rear windows that zip up and down in lightning speed. Since they're hardly used. Now when I want to vent the cabin I lower the rear windows and try to use the front ones when only necessary. Spraying the rubber window channels with silicone spray helped but be careful since it can stain the black trim around it.
Re: How long did it take?......window motor failure [Re: wrcsixeight] #4102755 05/21/16 12:16 PM
Cardenio327 Offline
Same on mine...
There's a service bulletin out on my car for the driver's door window motor, but not any of the other doors. Apparently the rivets tear out of it.
It has been slow since the first year of ownership. I've greased it twice and gotten it to last 7 years, but it is noticeably slower.
'08 Honda C90ST Super Cub 15w-40 mixture of Delvac & Rotella
'08 Honda NX4 Falcon 5w-40 Delo 400LE
'09 Honda Fit LX 0w-20 PP
Re: How long did it take?......window motor failure [Re: wrcsixeight] #4102794 05/21/16 01:06 PM
NavyVet88 Offline
My 13 civic driver window made it just a hair past 63k miles and one 37 degree morning in Virginia at a Hardee's drive thru it didn't go back up...I was conviently just outside of my warranty so I had to go shell out $180 at a local shop to have it fixed. I'm a country boy so I prefer window down to a/c and probably too much use caused it
2013 Honda Civic LX 1.8L 178k M1 HM 0w20 with Fram XG7317
2002 Ford Ranger Edge 3.0L 67k Castrol Edge 5w30 with Fram XG3600
Maintenance Technician by trade, working class for life.
Re: How long did it take?......window motor failure [Re: wrcsixeight] #4102816 05/21/16 01:44 PM
W
Wolf359 Offline
W
It's probably not the motor, sounds like the window regulator. Sometimes you can take the door apart and clean the grooves that the window goes up and and down in, that sometimes gets dirty and that slows the window from going up and down.
Re: How long did it take?......window motor failure [Re: wrcsixeight] #4102821 05/21/16 01:54 PM
Nick1994 Offline
The passenger front window on my Camry was making noise and started to get a little stuck sometimes. So I unplugged the switch to it, I just don't use it.
Maybe someday I'll fix it.
2015 Hyundai Genesis 5.0L 56k Mobil 1 5w30 & Wix
2000 Toyota Camry 2.2L 236k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 149k Mobil 1 HM 10w40 & Fram Ultra
Re: How long did it take?......window motor failure [Re: Wolf359] #4102834 05/21/16 02:09 PM
O
Oro_O Offline
O
+1, do maintenance.
A) Check your rubber molding, too. The "glass run" (factory name) on this era Corolla and Camry are known to tear. If ok, still lube it w/Sil-Glyde or similar. Then go do your other window/door/trunk/sunroof gaskets. And do this annually.
B) Another cause is the glass getting loose in the regulator. It then cants fore or aft and drags. Often, re-aligning it and re-tightening is all you need to do.
Re: How long did it take?......window motor failure [Re: wrcsixeight] #4102846 05/21/16 02:33 PM
A
andyd Offline
A
On the 528e, I can still get the window to work if I beat hard enough on the right spot on the door panel. It is either a bad connection or a sticky brush. I can fix it with a mini maul. grin2
The Rat has roll ups that work perfectly
Thick oil is better grin2
Re: How long did it take?......window motor failure [Re: wrcsixeight] #4102858 05/21/16 02:47 PM
9
901Memphis Offline
9
I thought my drivers window was going to die on my Buick going extremely slow and it's apparently a common failure point, but I lubed it up good with 20% silicone and it's been fine for almost 2 years.
I am amazed how much difference it made
2012 Chevy Cruze LT 1.4T - 69k - M1HM 5w30 + Fram Ultra
2002 Buick Century 147k - Built 4T65e(Maxlife) - GTX 5w30 + Fram XG3980
Re: How long did it take?......window motor failure [Re: wrcsixeight] #4102866 05/21/16 02:53 PM
W
W
Binding could certainly be an issue. the window pulled out from the C channel many years ago and My fix, meant to be temporary and fixed correctly later, well later turned into never, and that was nearly a decade ago.
Some of that 'temporary', included duct tape.
I'll get in there and inspect it before clicking place order on a new window motor.
Thanks for the replies and input.
Re: How long did it take?......window motor failure [Re: wrcsixeight] #4102887 05/21/16 03:19 PM
T
Trav Offline
T
If nothing is broke or you just want to help prevent failure and have faster winowd in the bargain this is a good answer.
http://www.amazon.com/SE-CS100-6-Cotton-...long+wood+qtips
http://www.amazon.com/3M-08946-Clear-Sil...=silicone+paste
Put the window all the way down and run a long swab dipped in silicone paste in the channel seal be sure to get down into the channels on the side of the glass.
inside the door.
After a few operations it will speed up and cause less wear on the motor and regulator, I do mine before and after winter or twice a year.
Re: How long did it take?......window motor failure [Re: wrcsixeight] #4102901 05/21/16 03:33 PM
Chris142 Offline
My f250 uses a gear with a rubber shock absorber.the dr side one lasted 27 yrs.pass is still original. A new gear is $20 and took about 20 minutes to replace
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: How long did it take?......window motor failure [Re: Chris142] #4102983 05/21/16 05:08 PM
P
punisher Offline
P
Huge difference between those old "scissor" regulators, and later sliders with the wire. Those old Fords you could get a gear kit (with the 3 plugs) and fix it 90% of the time.
Re: How long did it take?......window motor failure [Re: wrcsixeight] #4103097 05/21/16 07:40 PM
J
JC1 Offline
J
What make of car and how old is it? I would check the rubber track that the window slides in. After time the rubber can get hard and slow down the window.
On my 94 accord the fix was to cut the rubber that is behind the door panel with a box cutter. You need to remove the door panel first. After that the windows worked like new.
In periodically sprayed silicone spray on that rubber twice a year.
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: How long did it take?......window motor failure [Re: wrcsixeight] #4103145 05/21/16 08:32 PM
sw99 Offline
I like roll up windows...
