Fury -Wilder 3?
by pbm - 02/23/20 06:41 AM
toro super recycler
by passgas55 - 02/23/20 06:05 AM
Chain style for ag tires
by puma4440 - 02/23/20 04:25 AM
2014 GMC Terrain 2.4L AWD
by Char Baby - 02/23/20 02:06 AM
Conventional VS Synthetic In The Winter Months
by BlueOvalFitter - 02/23/20 01:36 AM
Paint Splatter
by rrretiree7 - 02/23/20 12:54 AM
The Jeep Made it to 150k Miles - Storytime
by Nick1994 - 02/23/20 12:54 AM
Supertech vs Dexcool
by WA1DH - 02/22/20 11:44 PM
Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
Chaucha, UofA, Jeffrey78, Markovchain, o_s
70787 Registered Users
80 registered members (55hambone, 4WD, 53' Stude, Aero540T, aba4430, 2010Civic, 6 invisible), 1,715 guests, and 19 spiders.
Topics301,818
Posts5,203,279
Members70,787
Nissan SR20DET - looking for recommended turbo oil #4102524 05/21/16 06:50 AM
sr20detfwd Offline OP
Hello,
Been reading around the site and have found some great info on here. I have a 1995 Nissan SR20DE engine with 160k miles, that i added a rebuilt T28 turbo, and was looking for a recommended oil.
Typically i have run Pennzoil Platinum and Mobil1, but they have been in mostly stock vehicles. I installed a new cam in this engine and used Wallys Supertech dino(drained after 10 miles), just to help me clean out gunk from what i had removed and replaced on the engine. After that, I had fallen victim to advertising (and a promotion) and ended up getting some Royal Purple API 5w-30, however when i poured it in the funnel it looked like water and did not even fill up the funnel. Just seemed strange to me, like it is extremely thin. I have not started it with this oil, and plan to drain it right back out.
I live in northern ca, our lowest temps would probably be in the 40s or 50s that this car would ever see, and i was thinking about going with Redline 5w-30, but was not sure if i should use a 10w-30 or maybe even another brand besides Redline? I plan on have spirited commutes to work which consist of 10 mile each way open road conditions, and possibly drag racing every now and then.
Re: Nissan SR20DET - looking for recommended turbo oil [Re: sr20detfwd] #4102540 05/21/16 07:14 AM
O
Olas Online Content
Online Content
O
GO with your instinct and use a Redline 30. In California 0w/5w/10w won't make any difference, go for the best priced option.
Cable ties should hold it
Re: Nissan SR20DET - looking for recommended turbo oil [Re: sr20detfwd] #4102547 05/21/16 07:24 AM
J
jorton Offline
J
Just curious. Is this unit cooled by the vehicles cooling system? 2. Is it lubricated by the vehicles oiling system?
3. Does the manufacturer provide engine oil specification for this application?
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
Re: Nissan SR20DET - looking for recommended turbo oil [Re: jorton] #4102550 05/21/16 07:27 AM
O
Olas Online Content
Online Content
O
T28 is oil cooled wink
Re: Nissan SR20DET - looking for recommended turbo oil [Re: jorton] #4102551 05/21/16 07:28 AM
This turbo is a journal bearing with engine oil supply and is cooled by the cooling system as well.
Nissan factory manual says 5W-30, but that is without a turbo. I bought the turbo used and had it rebuilt, i never saw a recommendation provided from the seller.
Re: Nissan SR20DET - looking for recommended turbo oil [Re: sr20detfwd] #4102554 05/21/16 07:29 AM
O
Olas Online Content
Online Content
O
Is the coolant circulation an aftermarket add-on? I could've sworn that T25s and T28s had no provision for coolant flow?
Re: Nissan SR20DET - looking for recommended turbo oil [Re: Olas] #4102556 05/21/16 07:31 AM
I think you are right, some T28 are only oil cooled but this is an OEM unit and has coolant ports. It is off an OEM Nissan that was only available overseas from the US
Re: Nissan SR20DET - looking for recommended turbo oil [Re: jorton] #4102579 05/21/16 08:03 AM
J
jorton Offline
J
Here is info for a 1995 300zx tt. I don't think Amsoil shows a 2.0 turbo in their oil finder tool.
- Mario Andretti
Re: Nissan SR20DET - looking for recommended turbo oil [Re: sr20detfwd] #4102593 05/21/16 08:19 AM
skyactiv Offline
You don't need to use boutique oils such as Redline that cost more and don't do anything any better. Castrol Edge 0W40 is a great choice for your car. Look for the one that says Titanium on the bottle. It is cheap if you have a Wal-Mart that happens to carry it in 5 quart jugs. DON'T worry that it starts out as a 0 weight. If anything, it's better as you get faster lubrication to the internals and still protects as a 40 weight when things heat up. The oil meets the Porsche spec meaning its good , contains some real PAO synthetic base and the oil itself actually comes from Germany in that weight.
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: Nissan SR20DET - looking for recommended turbo oil [Re: sr20detfwd] #4102620 05/21/16 09:04 AM
simple_gifts Offline
It is a 30 weight oil regardless of what it looked like.
Base decisions on facts, not feelings or perceptions.
2004 Prius; 126K; ALM
2007 Yaris 103K ATM
2006 B2300;137K;ALM
Was driving an ox cart; Now on the USS Enterprise
Re: Nissan SR20DET - looking for recommended turbo oil [Re: sr20detfwd] #4102741 05/21/16 12:03 PM
donnyj08 Offline
M1 0w40
2008 Silverado LT Z71 99k PP 10w30
2016 Tucson Limited 1.6T AWD 32k M1 5w30 AP
2016 Yamaha XSR900 13k, Spectro 10w40, Yamaha Filter.
Re: Nissan SR20DET - looking for recommended turbo oil [Re: simple_gifts] #4102743 05/21/16 12:04 PM
wemay Offline
Originally Posted By: simple_gifts
"ref RP 5w30"
Take both opinions and run with them. thumbsup
19 VW Passat Wolfsburg TSI (VW Genuine 0W-20+OEM)
13 Hyundai Santa Fe Sport 2.0T (Shell RGT 5W-30+OEM)
Re: Nissan SR20DET - looking for recommended turbo oil [Re: skyactiv] #4102781 05/21/16 12:44 PM
P
Pontual Offline
P
Group III also meets Porsche A40. Look at P. Synthium 3000.
Re: Nissan SR20DET - looking for recommended turbo oil [Re: sr20detfwd] #4104994 05/24/16 06:51 AM
I ended up buying some Castrol Edge 0W-40. Runs smooth!
Re: Nissan SR20DET - looking for recommended turbo oil [Re: sr20detfwd] #4105030 05/24/16 07:32 AM
Y
yvon_la Offline
Y
The manufacturers stock recommendation based on regular service intervals and "normal" driving is as follows:
API SG/SH
Temp Range -20 degC to 0+
10w-40 Semi or Fully Synthetic
10w-50 Fully Synthetic
15w-50 Fully Synthetic
10w-60 No recommendation
this was their recommendation with normal driving!
want my advice?
they didnt have the oil avail today back then
use the mobil delvac le 5w-30 and you wont have issue ,just let it warm up to 100 f and let it cool 5 minute before shutting it off and you will have ton of fun.as a precaution you could put an aluminium wire from the head to the frame ! aside from this? those were great engine almost unkillable
Truck driver
Nissan versa note s 2014 total classic 5w30(qc.ca) drivework oil filter
