P0171 and P0174
by NavyVet88 - 01/26/20 05:04 AM
Essex Engine Plant (Canada)
by BlueOvalFitter - 01/26/20 03:18 AM
Mopar oil bottles
by Franz - 01/26/20 12:47 AM
Ultra-rare barn find!
by Toy4x4 - 01/26/20 12:11 AM
2015 Hyundai Genesis 5.0L Review
by Nick1994 - 01/25/20 11:56 PM
My doggie had a rough week
by Chris142 - 01/25/20 11:26 PM
Delivery meal kit review - Dinnerly vs HelloFresh
by pezzy669 - 01/25/20 10:32 PM
Eotech Vudu scopes
by OVERKILL - 01/25/20 10:10 PM
'12 Civic burning oil after switch to M1
by sr20detfwd - 01/25/20 09:33 PM
Wix/NAPA Gold and M+H
by Uphill_Both_Ways - 01/25/20 09:06 PM
New seafoam oil stabilizer at AZ
by Chesterr - 01/25/20 08:13 PM
In 3 hours - 730 days and counting
by OVERKILL - 01/25/20 08:12 PM
Pig Parker!
by dishdude - 01/25/20 07:58 PM
NGK Conventional vs. Ruthenium Plugs
by doitmyself - 01/25/20 07:58 PM
Container or funnel?
by Philthy_Phil - 01/25/20 07:24 PM
AC Delco filters at Amazon as little as $1.07
by jayjr1105 - 01/25/20 06:22 PM
Excessive moisture in oil
by mb32 - 01/25/20 05:47 PM
Cover for Jeep + Trailer
by kehyler - 01/25/20 05:34 PM
kwashabcp, ronster, BackToReality, Scopeman, M635_Guy
70527 Registered Users
27 registered members (Bobaloo22, ctechbob, bbhero, c502cid, blufeb95, Bookmaker, 1 invisible), 1,027 guests, and 19 spiders.
Topics300,572
Posts5,178,500
Members70,527
Help me figure out this belt noise #4101661 05/20/16 07:13 AM
K
Klutch9 Offline OP
K
For about the past year, the belt on our Fusion makes a chirp on colder mornings. It's not a constant squeal, just a chirp. The noise is consistent with each rotation of the belt, so it seems like a portion of the belt may be glazed. This morning I started it up, chirping was there; I sprayed some water on the ribbed side of belt, and the noise instantly stopped. So it seems like a belt issue, but I'm wondering if the noise is a result of pulley misalignment?
I looked at each pulley while the engine was running, and I didn't see any wobble. I also looked along the length of the belt, and it seemed to run true. The tensioner pulley moved in and out a bit with RPM variation while the engine was warming up, but it was almost unnoticeable. I shut the engine off and tried wiggling each pulley by hand. All were rock solid. The are 2 plastic idler pulleys, which by nature will have more flex than a steel pulley, but both were solidly mounted with little flex.
FWIW, the one edge of the belt has the slightest amount of cord showing; maybe it rubbed on something?
'11 Fusion SE 2.5L - 89k miles - HK 0w20 syn, Carquest Blue filter
'08 Sedona LX LWB 3.8L - 141k miles - Havoline HM 5w20, Carquest Red filter
Re: Help me figure out this belt noise [Re: Klutch9] #4101681 05/20/16 07:36 AM
Nick1994 Offline
At 5 years old, I wouldn't feel bad about replacing the belt. Then you'll know whether the noise is the belt or a pulley.
2015 Hyundai Genesis 5.0L 56k Mobil 1 5w30 & Wix
2000 Toyota Camry 2.2L 236k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 149k Mobil 1 HM 10w40 & Fram Ultra
Re: Help me figure out this belt noise [Re: Nick1994] #4101687 05/20/16 07:44 AM
B
Bgallagher Offline
B
+1 It isn't an expensive thing to replace and it'll help you better determine the noise. At the very least you wont have to think about a belt.
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
Re: Help me figure out this belt noise [Re: Klutch9] #4101811 05/20/16 09:36 AM
H
HerrStig Offline
H
Remove the belt and run the engine for a short listen.
Re: Help me figure out this belt noise [Re: Klutch9] #4101906 05/20/16 11:40 AM
T
The_Eric Offline
T
You likely have a pulley out of alignment. Gates sells this nifty little laser alignment tool that sets in the grooves of the pulleys to see which one is off. I know it can be found at NAPA.
Fix the alignment and put on a new belt- also check the tensioner and idlers.
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
Re: Help me figure out this belt noise [Re: The_Eric] #4102074 05/20/16 03:49 PM
K
Klutch9 Offline OP
K
I picked up a smooth idler pulley and a new auto-tensioner at NAPA today, just in case I need them when I swap the belt. The grooved idler pulley is special order, and the one on this car is quiet with no play anyhow, so I'm fine leaving it.
I noticed that the new tensioner (Gates) has the slightest amount of play in the pulley. I've heard this is normal, especially for a plastic pulley. Any ideas there? Box was sealed, so I know it wasn't tampered with.
Re: Help me figure out this belt noise [Re: Klutch9] #4102083 05/20/16 04:00 PM
R
Rand Offline
R
gates pulleys can be cheapo Chinese.
Re: Help me figure out this belt noise [Re: Rand] #4102087 05/20/16 04:06 PM
K
Klutch9 Offline OP
K
The tensioner was made in Korea. The idler pulley was made in Canada.
Re: Help me figure out this belt noise [Re: Klutch9] #4102335 05/20/16 09:22 PM
T
The_Eric Offline
T
But the important part, the bearing was made in China.
Re: Help me figure out this belt noise [Re: Klutch9] #4104534 05/23/16 03:39 PM
SirTanon Offline
The belt tensioners on the 2.5 engines in these cars are a known issue, and after a while (usually around 60,000 miles or so) start to make nose, and if left long enough, start making noise constantly.
The belt tensioner on mine was doing it the day I bought it, used, at just under 178,000 miles. Sounds a bit like the alternator is going.
Luckily, it's an easy fix if you have an hour or two. I fixed mine myself in about 75 minutes. The replacement part was $45.
Since yours is a chirp, and it's not constant, it may or may not be the tensioner. At 5 years, it could very well be the belt, but the mileage seems about right to potentially be the tensioner.
2013 Nissan Altima SV - 2.5 liter/CVT - 125,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 68,000mi
2010 Ford Fusion - 274k mi - SOLD
Re: Help me figure out this belt noise [Re: The_Eric] #4104805 05/23/16 09:39 PM
The Critic Offline
Bingo.
2011 Toyota Prius 1.8L - 202K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 143K - Valvoline Premium Blue Restore 10W-30
