P0171 and P0174
by NavyVet88 - 01/26/20 05:04 AM
Essex Engine Plant (Canada)
by BlueOvalFitter - 01/26/20 03:18 AM
Mopar oil bottles
by Franz - 01/26/20 12:47 AM
Ultra-rare barn find!
by Toy4x4 - 01/26/20 12:11 AM
2015 Hyundai Genesis 5.0L Review
by Nick1994 - 01/25/20 11:56 PM
My doggie had a rough week
by Chris142 - 01/25/20 11:26 PM
Delivery meal kit review - Dinnerly vs HelloFresh
by pezzy669 - 01/25/20 10:32 PM
Eotech Vudu scopes
by OVERKILL - 01/25/20 10:10 PM
'12 Civic burning oil after switch to M1
by sr20detfwd - 01/25/20 09:33 PM
Wix/NAPA Gold and M+H
by Uphill_Both_Ways - 01/25/20 09:06 PM
New seafoam oil stabilizer at AZ
by Chesterr - 01/25/20 08:13 PM
In 3 hours - 730 days and counting
by OVERKILL - 01/25/20 08:12 PM
Pig Parker!
by dishdude - 01/25/20 07:58 PM
NGK Conventional vs. Ruthenium Plugs
by doitmyself - 01/25/20 07:58 PM
Container or funnel?
by Philthy_Phil - 01/25/20 07:24 PM
AC Delco filters at Amazon as little as $1.07
by jayjr1105 - 01/25/20 06:22 PM
Excessive moisture in oil
by mb32 - 01/25/20 05:47 PM
Cover for Jeep + Trailer
by kehyler - 01/25/20 05:34 PM
kwashabcp, ronster, BackToReality, Scopeman, M635_Guy
70527 Registered Users
53 registered members (AndyB, 2015_PSD, alchargo, BobsArmory, bmod305, blufeb95, 6 invisible), 1,101 guests, and 19 spiders.
Topics300,572
Posts5,178,518
Members70,527
Lucas 20W50 - good for my low oil pressure GM 350? #4101334 05/19/16 07:12 PM
sr17 Offline OP
I have a 1991 GMC Sierra K2500 that suffers from low oil pressure to the point that the "check gauges" light flickers on when the engine is hot and A/C is running.
The engine is otherwise running very smoothly, pulls strongly and never makes any bad noises. Oil burn is moderate less than 1 qt per 2,500 miles.
I have another thread to discuss diagnostic and repair, but this thread is mainly to seek feedback on oil.
I am going to try a 20W50 to see what it does for oil pressure readings. The local parts store has a pretty good price on Lucas Oil 20W50. Is it any good, or shoul I stay away from it?
2005 VW Jetta TDI - 222,000 km, M1 TDT
2000 VW Golf TDI - 354,000 km, Shell T6
1991 GMC Sierra 2500 5.7L 4 WD
Re: Lucas 20W50 - good for my low oil pressure GM 350? [Re: sr17] #4101342 05/19/16 07:22 PM
A
abycat Offline
A
If you have bad pressure then you have bad flow. a 20w50 would limit the flow even more. I would get a quote for a new pump installed. You might say [censored] it and put a new pump in.
2017 dodge caravan gt
2011 nissan versa hb
Re: Lucas 20W50 - good for my low oil pressure GM 350? [Re: abycat] #4101346 05/19/16 07:27 PM
sr17 Offline OP
I have learned from numerous sources that changing the pump is unlikely to make a significant difference - the pump creates flow, but not pressure, which is more dependent on wear tolerances inside the engine.
In this thread I am mainly hoping to get some good feedback on Lucas 20W50.
Re: Lucas 20W50 - good for my low oil pressure GM 350? [Re: sr17] #4101353 05/19/16 07:36 PM
U
userfriendly Offline
U
Lucas is good for chainsaw bar oil.
What else do you need to now about it?
You can buy a pail of 15W40 CJ-4 at Canuck Tire for $59 which is as good as it gets for very little money.
Re: Lucas 20W50 - good for my low oil pressure GM 350? [Re: sr17] #4101354 05/19/16 07:37 PM
R
Run Offline
R
Stick to a 5 or 10w-30 oil.
02 Escape
Re: Lucas 20W50 - good for my low oil pressure GM 350? [Re: sr17] #4101364 05/19/16 07:45 PM
GumbyJarvis Offline
Rotella SAE 30? Defy 10w40?
I was stationed with a buddy who had a 315CI, He ran Berrymans mixed in with Rotella sae30 for 500 miles on his mid eighties chevy truck, ran a can in the oil and a can in the gas tank, afterwards he switched to QSGB 10w40, his Oil pressure went back to normal after the "clean up"
Re: Lucas 20W50 - good for my low oil pressure GM 350? [Re: GumbyJarvis] #4101368 05/19/16 07:52 PM
GumbyJarvis Offline
This was paired with a Napa Proselect filter.
Re: Lucas 20W50 - good for my low oil pressure GM 350? [Re: sr17] #4101369 05/19/16 07:52 PM
sr17 Offline OP
Hmmmmm, no love for Lucas, Eh?
I have set my mind on trying a 20W50, was hoping Lucas was good since it is inexpensive but I suppose it was not to be.
Re: Lucas 20W50 - good for my low oil pressure GM 350? [Re: sr17] #4101373 05/19/16 07:56 PM
Chris142 Offline
Have you actually checked the pressure with a real gauge?
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Lucas 20W50 - good for my low oil pressure GM 350? [Re: sr17] #4101374 05/19/16 07:57 PM
R
Run Offline
R
Define inexpensive? It must be old slow moving stock, wouldn't matter in this engine.
02 Escape
Re: Lucas 20W50 - good for my low oil pressure GM 350? [Re: Chris142] #4101375 05/19/16 07:57 PM
A
abycat Offline
A
I assumed that was done but yeah that's a great idea.
Re: Lucas 20W50 - good for my low oil pressure GM 350? [Re: sr17] #4101380 05/19/16 08:03 PM
A
abycat Offline
A
an adjustable brand new oil pump is 52$ which would fix the pressure and volume problem on the most worn engine and it's an hour to replace for the backyard mechanic. I just don't want to see you cause more problems with oil starvation. a new oil sender is under 20$ or even cheaper from a wrecking yard. hopefully you only have a bad sender and have great pressure.
Re: Lucas 20W50 - good for my low oil pressure GM 350? [Re: sr17] #4101420 05/19/16 09:05 PM
J
JR Offline
J
Sounds like wear at the bearings. It time for a refreshing.
Climate permitted a heavy oil will help. Sae30/40, 20w-50, 15w-40, and alike.
Lucas is a choise, if priced the same as cheap dino. It is a bandaid for worn bearings.
Harvey
97 F250HD 7.3 320K 01 Astro 220K
93 metroXFi 94.5K
01 Impala 300K
04 RTV900R 1150hrs
Re: Lucas 20W50 - good for my low oil pressure GM 350? [Re: sr17] #4101443 05/19/16 09:50 PM
F
Farmer Offline
F
Lucas isn't really that great, even their synthetic doesn't look good on paper.
Probably be better to pick up some HDEO. Inland Kenworth has 5 Gallon buckets of Delo 400 for $65. There should be one close by, Burnaby or Langley.
Re: Lucas 20W50 - good for my low oil pressure GM 350? [Re: sr17] #4101470 05/19/16 10:31 PM
M
Michael_P Offline
M
As Chris142 asked; Have you actually checked the pressure with a real gauge?
Those GMT400 trucks with the small block notoriously had bad oil pressure sending units. I've replaced a bunch of those. A crowfoot makes the job easier. Given the year, make and model, I would first replace the oil pressure sending unit.
