Standard wix cartridge filter
by Bettez88 - 01/23/20 09:50 PM
Adaptive Driving Beam, Thoughts?
by Vern_in_IL - 01/23/20 09:07 PM
Chevron Delo XLE 15W-40 CK4 (semi synthetic)
by HDoilDude - 01/23/20 08:45 PM
Coronavirus
by buster - 01/23/20 08:04 PM
Used vehicle shopping
by 53' Stude - 01/23/20 08:01 PM
Carquest oil and filter deal.
by JTK - 01/23/20 07:35 PM
Anti seize vs silicone paste
by buck91 - 01/23/20 06:57 PM
UOA - 11 VW GTI 2.0T TSI - Purol 10w40 - 5k
by dubman - 01/23/20 06:33 PM
Old SG/CD Mopar Vintage oil useless?
by BBDartCA - 01/23/20 06:32 PM
Great Slave Lake
by 53' Stude - 01/23/20 04:57 PM
Went used car shopping today. So interesting
by WhyMe - 01/23/20 04:33 PM
Wix 51269 I think cut open
by Mightymouse - 01/23/20 04:08 PM
What oil for a new VW Beetle?
by widetrax - 01/23/20 03:52 PM
Lossless audio music
by Cujet - 01/23/20 03:38 PM
Castrol Edge on Rollback at Walmart
by Matt1980 - 01/23/20 03:35 PM
Regretted Selling a Car?
by RDY4WAR - 01/23/20 02:14 PM
3 American Volunteers lost in Oz fires....
by Shannow - 01/23/20 02:13 PM
Need a tire pressure gauge
by nomas - 01/23/20 02:11 PM
Why Waffle Sipes - but very little depth
by Cressida - 01/23/20 02:05 PM
Perseus, AJEwing, Mailman1995, DougCFL, Sayafi
70514 Registered Users
49 registered members (10WSmuckers, bdcardinal, AZjeff, A310, 4WD, Black_Thunder, 2 invisible), 1,641 guests, and 35 spiders.
Topics300,480
Posts5,176,838
Members70,514
Ford 2.7 Ecoboost F150 oil change interval? #4101016 05/19/16 12:32 PM
A
advocate Offline OP
A
My nephew just got a 2015 F150 xlt sport with the 2.7 ecoboost. We are having a hard time finding much info on people's experiences with this combo. He bought some Pennzoil Platinum 5w-30 for the first couple oil changes (which are not done yet). He has close to 1000 km on it at the moment. Should the oil be changed early in these? What is a reasonable oil change interval for this engine after its had a couple shorter changes? Follow the iolm? Do these have a tendency to get fuel dilution from the direct injection like it's bigger brother 3.5?
Thanks in advance.
I recently picked up a 2016 with a 5.0. Lots more info on those then the new ecoboost. I'll be running the same oil but in 5w-20. And following the oil life monitor once it's broken in nicely.
Re: Ford 2.7 Ecoboost F150 oil change interval? [Re: advocate] #4101038 05/19/16 01:00 PM
CT8 Offline
I have a 2015 2.7 I bought last August and I changed the motor oil and filter at 1000 miles the oil came out black. The rear differential had only 1 qt in it so I drained and refilled the differential. I have only found Motorcraft oil filters for the engine and Rock auto has them at a fair price if they ship across the border. Watch this link then this one and you will be covered.
2015 F150 2.7
2018 F350 6.2
Re: Ford 2.7 Ecoboost F150 oil change interval? [Re: advocate] #4101062 05/19/16 01:19 PM
CT8 Offline
2015 F150 2.7
2018 F350 6.2
Re: Ford 2.7 Ecoboost F150 oil change interval? [Re: advocate] #4101108 05/19/16 02:38 PM
G
Gene K Offline
G
1. Careful of the drain plug it's easy to break. Make sure you press the tabs before attempting to remove. Do not try to torque after you seat as the tabs are easy to break.
2. UOA results are hard to come by but so far the few I've seen both fuel and iron numbers seem to be lower on the 2.7 EB than the 3.5 EB.
3. Motorcraft, Purulator Filter Cartridges are identical. Cheapest place I've found them is the Motorcraft Distributor for $5.05 USD. They seem to be extremely well made.
4. My IOLM is tracking on days instead of miles since I put on less than 8000 miles a year and averaging 22 mpg. The VIC is showing 24.3 mpg but it's optimistic.
5. I changed my factory fill at 2000 mi with Pennzoil Gold Synthetic Blend 5W30 and will likely do it again in another 4000 mi. It will likely get changed to Quaker State Ultimate Durability 5W30 at 12,000 mi total.
Gene
2014 Mustang GT 5.0 SC - 675 bhp
ST Synthetic 10W30 / FL500S
2018 F150 4x4 3.5 EB
OEM Oil & Filter
2018 Lincoln MKX 3.7
OEM Oil & Filter
Re: Ford 2.7 Ecoboost F150 oil change interval? [Re: advocate] #4101140 05/19/16 03:18 PM
U
UltrafanUK Offline
U
Thanks in advance
If it's under warranty just do what the manufacturer recommends in terms of oil type and OCI.
It can be bad news to change the factory fill oil early, as it might be a special brew.
There's nothing wrong with changing the oil (No need to change the filter before Max recommended) early if you are concerned about fuel dillution due to short tripping or too much time stuck in traffic. The best way to figure out if you have a fuel dillution issue to to do a UOA. More the 2% is bad news in the very long term.
If it does show more than 2%, move up one grade to an 0w30 (If the handbook and warranty terms allow that), OR reduce the OCI.
Re: Ford 2.7 Ecoboost F150 oil change interval? [Re: advocate] #4101581 05/20/16 05:20 AM
A
advocate Offline OP
A
Thanks for the tips. Sure is a different engine then what I'm used to with the composite pan and drain plug. Sounds like my nephew will do some early oil changes and try and settle into an interval that he is comfortable with.
Re: Ford 2.7 Ecoboost F150 oil change interval? [Re: advocate] #4109216 05/28/16 07:17 PM
A
advocate Offline OP
A
First oil change done! That has to be the easiest oil change vehicle around! Pretty simple. And no mess. Everything went well with it! Hard to pay the dealer for an oil change when Ford made it this easy!
Re: Ford 2.7 Ecoboost F150 oil change interval? [Re: advocate] #4109219 05/28/16 07:19 PM
RTexasF Offline
So no owner's manual came with it in the glove box?
Re: Ford 2.7 Ecoboost F150 oil change interval? [Re: advocate] #4109236 05/28/16 07:36 PM
A
advocate Offline OP
A
of course it came with an owners manual. It is a new vehicle. However it is a leftover 2015 meaning that it has been on the lots for about a year now... As per the owners manual it states to change the oil when the IOLM tells you to. up to 16000km and ONE YEAR. The truck has a fair amount of idle hours on it from transport and test drives and what not. the oil change monitor was most likely reset at some point as it started out at 100% when my nephew got the truck. The early oil change was for peace of mind due to the engine run time and the yearly oil change required by Ford.
Re: Ford 2.7 Ecoboost F150 oil change interval? [Re: advocate] #4109275 05/28/16 08:18 PM
R
roadrunner1 Offline
R
A couple months ago we bought an F150 with the 2.7, my plans are to follow the IOLM. The truck currently has approx 3,500 mi. and runs like a top with more than enough power.
This truck will never tow anything as I have an F350 for those duties, but my wife drives it to work and we use it making deliveries several times a week, its miles are close to 80% highway.
'15 F350 6.7
