Castrol edge 0w40
by VQLT - 02/18/20 08:32 AM
Scrap value of this catalytic converter
by atikovi - 02/18/20 06:10 AM
How drunk do you have to be to do this?
by dishdude - 02/17/20 11:09 PM
At least they show you
by Jake777 - 02/17/20 10:04 PM
Ryan Newman update
by P10crew - 02/17/20 09:17 PM
Thoughts on 2015+ Kia Sedona?
by 92saturnsl2 - 02/17/20 09:16 PM
Quiet riding tire
by wolf_06 - 02/17/20 08:27 PM
Where did the Ryan Newman thread go??
by P10crew - 02/17/20 08:02 PM
2013 FX4 repair.
by marine65 - 02/17/20 07:36 PM
New gaming build shutting down on Metro 2033
by Cujet - 02/17/20 07:09 PM
Snapon
by P10crew - 02/17/20 06:51 PM
Conventional or Synthetic
by charmer37 - 02/17/20 06:49 PM
Jeep Wrangler 3.0L Diesel
by HighbrowHillbill - 02/17/20 06:36 PM
94 B4000 overheat Eureka
by HyundaiAbuser - 02/17/20 05:48 PM
PP Euro 5w40 SN Plus formulation VOA
by BurntMusic - 02/17/20 04:35 PM
Bicycle Shops
by CourierDriver - 02/17/20 04:26 PM
EBC Brakes
by hatt - 02/17/20 04:17 PM
Dream Car
by MrQuackers - 02/17/20 04:06 PM
What are people using now for outdoor antennas?
by BAJA_05 - 02/17/20 02:49 PM
tpap, ratt, jeffreytmann, boureesub, Bayrim
70737 Registered Users
91 registered members (ArrestMeRedZ, BeerCan, ARCOgraphite, Blkstanger, Astro14, 10 invisible), 1,896 guests, and 21 spiders.
Topics301,600
Posts5,198,899
Members70,737
Unknown fluid/miles, 249K 00 Pontiac WS6 #4095803 05/13/16 12:39 PM
dhellman12 Offline OP
Fluid was replaced at time of sample. Picked this car up a month ago and changed the fluids to get a baseline.
Make/Model: GM Differential (Rear)
Vehicle: 2000 Pontiac Trans-Am WS6
Code:
OIL             Unknown
MILES IN USE    Unknown
MILES ON UNIT   249K
SAMPLE TAKEN    4/22/16
MAKE UP OIL	0
ALUMINUM	2
CHROMIUM	2
IRON		294
COPPER		3
LEAD		0
TIN		0
MOLYBDENUM	1
NICKEL		12
MANGANESE	3
SILVER		0
TITANIUM	1
POTASSIUM	1
BORON		5
SILICON		58
SODIUM		3
CALCIUM		24
MAGNESIUM	4
PHOSPHORUS	449
ZINC		16
BARIUM		0
SUS @ 210F	79.5
Visc @ 100C	15.4
Flashpoint	435
Water %		0.0
Insolubles %	0.3
Oil Analysis Comments:
This sample shows a little extra nickel and silicon compared to universal averages but other metals are fine. Nickel may just be an alloy with steel, though iron isn't out of line at all, and silicon is likely just sealer material; it's fine. Looks pretty good from what we can see here! Try 40K miles or so.
00 WS6 5.7L - Amsoil ASL 5w30 256K
04 DMax 6.6L - Amsoil AME 15w40 238K
12 Jeep 3.8L - Amsoil ASL 5w30 74K
Re: Unknown fluid/miles, 249K 00 Pontiac WS6 [Re: dhellman12] #4095826 05/13/16 12:59 PM
2015_PSD Offline
I believe it has been changed at least once in its life. My rationale for this is typically most of the wear happens in the first 5-10K of an axle's life. For example, (granted it is a truck and a different OEM), but my 2010 FX4 had 429ppm of Fe at 13K, but at 70K it was 148ppm of Fe, and at 150K it was 120ppm of Fe. As you can see the ppm of Fe was the most early on and then decreased on a ppm per mile basis after that. At 250K, I would expect your Fe to be much higher than 294.
2019 o)|||||(o Rubicon Wrangler Unlimited 3.6L V6 [Castrol Edge + Mahle]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum + Mann filter]
Re: Unknown fluid/miles, 249K 00 Pontiac WS6 [Re: dhellman12] #4095833 05/13/16 01:04 PM
69GTX Offline
Iron seems high to me. It's the 2nd highest number. Not a very strong add package if you ask me. Nothing other than phosphorus. There are ATF's that have a better add pack.
2001 Lincoln Cont 4.6L DOHC/ 50K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Unknown fluid/miles, 249K 00 Pontiac WS6 [Re: dhellman12] #4095838 05/13/16 01:09 PM
P
Pontual Offline
P
This is Diferential oil, not engine. No need for too much calcium, but need EP.
Re: Unknown fluid/miles, 249K 00 Pontiac WS6 [Re: 69GTX] #4095849 05/13/16 01:17 PM
2015_PSD Offline
It is not high, in many ways it seems low for 250K miles or at the very least the OP has an excellent wearing axle on his hands if this is the original rear axle oil.
Re: Unknown fluid/miles, 249K 00 Pontiac WS6 [Re: dhellman12] #4095888 05/13/16 01:42 PM
AZjeff Offline
Wondering how a fluid with unknown history can provide a baseline? How will you interpret this against a future UOA of known history?
Not dissing you, just curious.
Seems like with a 250K car you just change the diff fluid and forget about it..
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, 0W-20 QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Unknown fluid/miles, 249K 00 Pontiac WS6 [Re: AZjeff] #4106228 05/25/16 11:51 AM
MolaKule Offline
Global Moderator
Global Moderator
The only way to get a baseline is to do a VOA on the replacement fluid and sample fluid every 20k to see trending.
Charlie Eppes: "Larry, have a minute?"
Dr. Larry Fleinhardt: "Yes. Because we all have exactly the same number of minutes at all times, do we not?" From NUMB3RS
