Fury -Wilder 3?
by pbm - 02/23/20 06:41 AM
toro super recycler
by passgas55 - 02/23/20 06:05 AM
Chain style for ag tires
by puma4440 - 02/23/20 04:25 AM
2014 GMC Terrain 2.4L AWD
by Char Baby - 02/23/20 02:06 AM
Conventional VS Synthetic In The Winter Months
by BlueOvalFitter - 02/23/20 01:36 AM
Paint Splatter
by rrretiree7 - 02/23/20 12:54 AM
The Jeep Made it to 150k Miles - Storytime
by Nick1994 - 02/23/20 12:54 AM
Supertech vs Dexcool
by WA1DH - 02/22/20 11:44 PM
Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
Chaucha, UofA, Jeffrey78, Markovchain, o_s
70787 Registered Users
79 registered members (AndyB, 4WD, 53' Stude, Aero540T, aba4430, 2010Civic, 6 invisible), 1,708 guests, and 19 spiders.
Topics301,818
Posts5,203,270
Members70,787
2014 Cruze 2.0, RLI 5w-30HD low ash, 10.010 miles #4094772 05/12/16 08:59 AM
R
Rat407 Offline OP
R
This is the second UOA on the RLI. I didn't drain it and like an idiot, I did change it out before the results came back because it was up on my lift to rotate the tires and figured may as well change out the oil. Terry said it could go to 15k no problems. So this oil change will see if it holds up the same and I will take it out to possibly 20k. Terry thinks it can do it with no problem.
This has the AC Delco cartridge oil filter and AC Delco air filter. Kind of wild to see the TBN stay so high.
Code:
OIL           RLI Low Ash 5w-30  RLI Low Ash 5w-30  ACDelco Dex2 5w-30
MILES IN USE    10,010             5,498               5,178
MILES           30,101             25,677             20,178
SAMPLE TAKEN    5/6/2016           03/14/16           11/5/2015
ALUMINUM        7                  4                  4
CHROMIUM        0		   0                  1
IRON            34		   17                 27
COPPER          4		   2                  3
LEAD            0		   0                  0
TIN             0   	 	   0                  0
MOLYBDENUM      0		   0                  8
NICKEL          0		   0                  0
MANGANESE       0	           0                  0
SILVER          0		   0                  0
TITANIUM        0                  0
POTASSIUM       19		   0                  15
BORON           76                 54
SILICON         9		   5                  7
SODIUM          3		   2                  6
CALCIUM         2363		   2296               1674
MAGNESIUM       8		   7                  9
PHOSPHORUS      1098		   1059               727
ZINC           1225		   1176               831
BARIUM          0		   0                  0
INSOLUBLES      0.0		   0.2                0.3
FLASHPOINT F
SUS VIS 210F   64.5		   62.0               63.6
cSt @ 212F     11.5		   11.1               11.22
Vis ASTMD 2270  175		   171
Fuel % by GC	0.9		   1.2                0.5
Antifreeze%     0		   0                  0.0
Water ppm       659		   620                0.0
TBN             8.37		   8.83               5.0
Oxidation       110		   138
Nitration       10		   10
Antiware        29		   36
Sulfation       89		   114
Soot (%)        0.0		   0.0
TAN             3.03		   2.53               4.0
2002 Silverado 5.3 0w-20 AMSOIL
Re: 2014 Cruze 2.0, RLI 5w-30HD low ash, 10.010 miles [Re: Rat407] #4094793 05/12/16 09:42 AM
B
bullwinkle Offline
B
Dumb question-what is "antiware" (antiwear?) & what is a good & bad value?
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: 2014 Cruze 2.0, RLI 5w-30HD low ash, 10.010 miles [Re: bullwinkle] #4094802 05/12/16 09:54 AM
R
Rat407 Offline OP
R
I'm not sure, might want to contact Terry Dyson.
Re: 2014 Cruze 2.0, RLI 5w-30HD low ash, 10.010 miles [Re: Rat407] #4095813 05/13/16 12:50 PM
J
Jetronic Offline
J
The same engine is specced for 22k miles on acea C2 oil (pretty much an ILSAC 5w-30) in my car. The only thing Fiat is adamant about is 10% or less Noack.
the RLI has incredible high TBN for a low-ash oil...
AR Giulietta 2.0 JTDM-2 -- Total Quartz 9000 Energy 0w30
Hankook Ventus Prime 2 215/50R17 (front)
Pirelli P7 Cinturato 225/45R17 (rear)
Re: 2014 Cruze 2.0, RLI 5w-30HD low ash, 10.010 miles [Re: Rat407] #4098770 05/17/16 04:33 AM
P
pb379 Offline
P
Water 659 ppm? What's up with that?
2014 RAM 1500 ECODIESEL
2002 Toyota Sequoia
1995 BMW M3
Re: 2014 Cruze 2.0, RLI 5w-30HD low ash, 10.010 miles [Re: pb379] #4099611 05/17/16 08:57 PM
B
BobFout Offline
B
Water is one of the by-products of combustion.
2003 VW Jetta TDI (Sold) / 2015 VW GTI 2.0T
Re: 2014 Cruze 2.0, RLI 5w-30HD low ash, 10.010 miles [Re: Rat407] #4100942 05/19/16 10:55 AM
B
bulwnkl Offline
B
I always thought it was odd how the 5Wxx products from RLI do/did noticeably better than their 0Wxx products.
You still finding that to be the case, Rat?
I use speech recognition frequently. Please excuse any consequent grammatical or typographical errors.
Re: 2014 Cruze 2.0, RLI 5w-30HD low ash, 10.010 miles [Re: bulwnkl] #4106683 05/25/16 07:35 PM
R
Rat407 Offline OP
R
I have not noticed that. So far what I have been using is the 5w-x weights. Using this one specifically per Terry's suggestion. Low ash so it will be OK with my particulate filter.
