Essex Engine Plant (Canada)
by BlueOvalFitter - 01/26/20 03:18 AM
Mopar oil bottles
by Franz - 01/26/20 12:47 AM
Ultra-rare barn find!
by Toy4x4 - 01/26/20 12:11 AM
2015 Hyundai Genesis 5.0L Review
by Nick1994 - 01/25/20 11:56 PM
My doggie had a rough week
by Chris142 - 01/25/20 11:26 PM
Delivery meal kit review - Dinnerly vs HelloFresh
by pezzy669 - 01/25/20 10:32 PM
Eotech Vudu scopes
by OVERKILL - 01/25/20 10:10 PM
'12 Civic burning oil after switch to M1
by sr20detfwd - 01/25/20 09:33 PM
Wix/NAPA Gold and M+H
by Uphill_Both_Ways - 01/25/20 09:06 PM
New seafoam oil stabilizer at AZ
by Chesterr - 01/25/20 08:13 PM
In 3 hours - 730 days and counting
by OVERKILL - 01/25/20 08:12 PM
Pig Parker!
by dishdude - 01/25/20 07:58 PM
NGK Conventional vs. Ruthenium Plugs
by doitmyself - 01/25/20 07:58 PM
Container or funnel?
by Philthy_Phil - 01/25/20 07:24 PM
AC Delco filters at Amazon as little as $1.07
by jayjr1105 - 01/25/20 06:22 PM
Excessive moisture in oil
by mb32 - 01/25/20 05:47 PM
Cover for Jeep + Trailer
by kehyler - 01/25/20 05:34 PM
Low VI gear oils
by dparm - 01/25/20 05:28 PM
kwashabcp, ronster, BackToReality, Scopeman, M635_Guy
70527 Registered Users
27 registered members (Bookmaker, bachman, blufeb95, brages, bbhero, BlakeB, 4 invisible), 921 guests, and 23 spiders.
Topics300,571
Posts5,178,490
Members70,527
Valley plate removal GM 6.0 #4094621 05/12/16 05:46 AM
L
LeakySeals Offline OP
L
Hello.
Performing a knock sensor repair on a 2006 Cadillac Escalade 6.0 this weekend. I would like to remove the valley plate to thoroughly clean out the knock sensor holes and replace the grommets. Is this a difficult task and how are the 2 grommets attached to the knock sensor holes?
Thanks.
06 Escalade 6.0L LQ9 AWD 170k M1 5w30
03 Maxima 3.5L 170k Maxlife HM 10w30
05 Malibu Classic 2.2 111k M1 5w30
06 Altima 2.5L 167k unk
Re: Valley plate removal GM 6.0 [Re: LeakySeals] #4094649 05/12/16 06:26 AM
T
The_Eric Offline
T
Easy job. The knock sensors have to come out first, then the valley plate. Just unbolt and lift off. The seals are a light press fit in the valley plate. They seal like an axle seal the post the knock sensor screws into.
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
Re: Valley plate removal GM 6.0 [Re: LeakySeals] #4094673 05/12/16 06:51 AM
L
L
So if for whatever reason I can't get that sensor out because it's so corroded I can still pull the valley plate off leaving the sensor and The grommet on the post?
Re: Valley plate removal GM 6.0 [Re: LeakySeals] #4094683 05/12/16 07:02 AM
T
The_Eric Offline
T
No.
I've ran into to that before- you just have to get medieval on the sensor. I think I used a chisel and channel lock pliers to get it out.
Re: Valley plate removal GM 6.0 [Re: LeakySeals] #4094696 05/12/16 07:22 AM
L
L
Ok thanks. Reading about sensor removal failures online the stud that goes into the post breaks off the bell part of the sensor leaving enough to grab onto with vice grips are channel locks. I was thinking I could break that top part off then remove the valley to get a grip on it or drill it out
Re: Valley plate removal GM 6.0 [Re: LeakySeals] #4098347 05/16/16 01:18 PM
L
L
The valley plate came out easily. Replaced the gasket and the 2 grommets.
I knocked the grommets out with a hammer and screwdriver then put motor oil around the new grommets and gently tapped them into place with a hammer.
It was much easier to clean the knock sensor holes. Thanks again for the help!
Re: Valley plate removal GM 6.0 [Re: LeakySeals] #4098376 05/16/16 02:13 PM
G
GMBoy Offline
G
You did a very nice job. I've got a 2006 Sierra Denali with the same LQ9 6.0L at 138k miles. Have not needed to do this job yet but when that day comes atleast I know what it looks like down in there. Thanks for the post and excellent pictures.
Re: Valley plate removal GM 6.0 [Re: LeakySeals] #4098590 05/16/16 07:31 PM
dailydriver Offline
Don't you wish that our LSx engines had access to the lifters through the valley, instead of having to completely pull the heads off to get to them? frown
Is that a Victor Reinz valley cover gasket??
2016 Ford Fiesta ST 17K miles
Ravenol REP 5W-30
Fram XG3600 filter
Ravenol MTF-2 in the IB6 transaxle
Re: Valley plate removal GM 6.0 [Re: LeakySeals] #4098989 05/17/16 09:35 AM
L
L
GMBoy: In hindsight wish I had done it before the CEL went off. Its not a hard job at all. I didn't get a real good picture of what I found when I took the intake manifold off but in this pic you can see that both harness boots where popped off exposing both KS to the environment for what looks like years.
The rear sensor which tripped CEL P0332 had a half inch of standing water in the hole. The new harness fit very tight into the hole but to be doubly sure I used RTV / gasket maker black around the boot to seal it in really good. Then used more around the seal to make sure it doesn't come out again. Not sure if the rear foam had anything to do with tugging on the harness but I did not put it back in only the front
Morning piston slap - gone.
GM ticks - gone
Slightly rough idle - gone
Drivetrain slop and clunk - much better almost gone.
Yes I put in a new IMG so some of it can be attributed to that. But I'm also thinking that although they were not tripping a code maybe both KS were not setting timing correctly because without the boots sealing the holes they were picking up other noises??
dailydriver: I did not use that VICTOR REINZ master set because it did not have the grommets for the valley cover. This is the parts I used... ( some Amazon, some RockAuto)
- VICTOR REINZ MS16340 IMG set
- FEL-PRO MS92465 Lifter Valley Cover Set
- FEL-PRO ES71190 lower injector O-rings (not used)
- Lisle 37000 Air Conditioning/Fuel Line Disconnect Tool Set
- Permatex 82180 Ultra Black Maximum Oil Resistance RTV Silicone Gasket Maker
- STANDARD MOTOR PRODUCTS J72001 TechSmart KS harness
- ACDelco 213-3521 OEM KS
Should have bought..
- ACDelco 17113552 GM Original Equipment Fuel Injection Fuel Rail O-Ring Kit. ( or a Fel-Pro/Vic reinz equiv).
The way the fuel rail crossover tube connects to the rails it has the potential to leak. At a minimum the gaskets should be replaced in my case should have replaced the entire crossover tube because of surface corrosion at the seal. I can't find a part number for that.
Re: Valley plate removal GM 6.0 [Re: LeakySeals] #4099258 05/17/16 01:52 PM
dailydriver Offline
One other thing to be aware of with these engines;
IF you ever wash, power wash, or steam clean this engine MAKE SURE that you COMPLETELY/TOTALLY block off/seal the ends (BOTH) of the intake manifold openings under the intake and above the valley cover.
THIS is why I had to change out my factory knock sensors, but I'm guessing you already figured this out with how much standing water was in your knock sensor recesses.
Ravenol REP 5W-30
Fram XG3600 filter
Re: Valley plate removal GM 6.0 [Re: LeakySeals] #4104317 05/23/16 10:56 AM
L
L
I put a small amount of water on the front of the engine to clean off some coolant after replacing the throttle body. I didn't hose the engine down or pressure wash it or anything like that. 2 Days Later the check engine light was on for the rear knock sensor . In hindsight I'm glad it happened. It's never run better. The piston slap and the ticking is gone.
Re: Valley plate removal GM 6.0 [Re: LeakySeals] #4104620 05/23/16 05:42 PM
clinebarger Offline
I wish I would have seen this thread earlier....Any time you have a valley cover off a Gen-3 LS engine, Install a LS6 Valley Cover with a integrated PCV/oil separator, Far superior oil control over the "Orificed" PCV in the Valve Cover.
It bolts on any iron block & '03 & up Aluminum blocks, '97-'02 non-LS6 aluminum blocks require grinding.
2001 Chevy Camaro L92/4L80E
Re: Valley plate removal GM 6.0 [Re: LeakySeals] #4104897 05/24/16 04:27 AM
L
L
What happens to the existing PCV? How would it function and connect to the intake?
Re: Valley plate removal GM 6.0 [Re: LeakySeals] #4105490 05/24/16 04:10 PM
dailydriver Offline
^^^It just uses the same hose routing as the C5 Z06 Vettes, and one can still use a catch can, or additional air/oil separator as well if they so desire.
Ravenol REP 5W-30
Fram XG3600 filter
Re: Valley plate removal GM 6.0 [Re: LeakySeals] #4105731 05/24/16 08:09 PM
clinebarger Offline
Plug the PCV on the left Valve Cover with the red vacuum cap that comes with the new Valley Cover.
Truck intakes don't have a vacuum source near the "LS6 PCV" port like car intakes. If not using a Catch Can, Run some 3/8" Transmission Cooler Hose from the valley cover around the back of the intake to the original PCV vacuum source.
