I was doing a google search on mixes for my new PoulanPro 42cc chain saw and read 3 replies from here. I was on my phone and now on my PC and cannot find the posts. But the OP was asking if adding a full 8 ounces of oil to TWO gallons was going to be a problem for a 50:1 mix. Some said not really, others said it was perfectly fine, a few actually said it made no difference at all, that the oil amount was not really important! [censored]! Really?
PLease clarify me if i'm wrong here. Really!
50:1 is 50 parts gas to 1 part oil. That would be 2.6 ounces of oil to one gallon.
40:1 is 40 parts gas to 1 pert oil. That would be 3.2 ounces of oil to one gallon.
32:1 (which some referred to as "minimal oil content") would be 4 ounces of oil per gallon.
Some said that 32:1 was good for about everything!
Hmmm, isn't 4 ounces kinda sloppy heavy with oil? Which is not really good for plugs and mufflers and the choking gagging you will be doing in the resulting cloud of smoke?
Anyway, My PoulanPro chain saw calls for 40:1, IE: 3.2 ounces per gallon.
as does my PoulanPro blower.
My Echo HC2000 hedge trimmers and my 21cc grass trimmer call for 50:1, 2.6 ounces per gallon.
Then I find a good site that says its fine to run EVERY TWO CYCLE ENGINE on 50:1 mixes, AS LONG AS I USE DurablendX from Echo????? (this was NOT an Echo site, BTW)
Soooooooooooooo....what say ye? Or should I go buy ANOTHER gas can for my new saw and blower with 3.2 ounces per gallon?
Mark in Phoenix
Mark in Phoenix
