AME 37330 Hub Cleaner for Impact Wrench
by The Critic - 11/18/19 01:54 AM
Plastic bag vs Car
by The Critic - 11/18/19 01:50 AM
Fram XG7317 20k miles cut open
by dbeau - 11/17/19 09:46 PM
2021 Ford Mach-E Electric SUV
by KeithS_NW_Ohio - 11/17/19 09:05 PM
Walker mower Oil
by Joey737 - 11/17/19 09:03 PM
Rough service tough light bulb 1ยข at Home Depot
by JLawrence08648 - 11/17/19 08:40 PM
2015 F150 5.0 8592 miles
by Buzzinhalfdozen - 11/17/19 08:36 PM
MOPAR MO-285 FACTORY OIL FILTER CUT OPEN
by 53' Stude - 11/17/19 07:43 PM
Best Garage Door Seals
by Gebo - 11/17/19 07:18 PM
Bar oil as fogging oil
by WA1DH - 11/17/19 06:47 PM
Fram PH2 ExtraGuard Cut Open
by A310 - 11/17/19 06:38 PM
C&P Pentius UFXL PH16-equiv.
by 92saturnsl2 - 11/17/19 06:18 PM
Fleetguard WF2074 Coolant Filter Cut Open
by Pyrotechnic - 11/17/19 05:24 PM
Cuts on tire sidewall
by mclasser - 11/17/19 03:19 PM
Hyundai Theta II Engine in Newer Years
by smc733 - 11/17/19 02:41 PM
Walmart deals
by Deere John - 11/17/19 02:33 PM
Grumpy Kid
by wings&wheels - 11/17/19 01:57 PM
h9/95R FLA Batteries
by TXCarGeek - 11/17/19 01:40 PM
Preventative parking brake service
by Donald - 11/17/19 01:26 PM
JimBobSeeker, Joey737, bdavis218, XTR74, 2009Caraman
69899 Registered Users
24 registered members (ctechbob, A_A_G, FordBroncoVWJeta, CharlieBauer, 53' Stude, 2 invisible), 699 guests, and 16 spiders.
Topics297,569
Posts5,118,205
Members69,899
Most Online3,589
Nov 2nd, 2019
Page 1 of 3 1 2 3
Mobil M1-110 or Fram Ultra XG7317 ? #4088624 05/05/16 02:10 PM
Srt20 Offline OP
Which one?
I have always used the M1. Before I got on here, I was one of those guys that wouldn't touch a Fram filter. Obviously Ultras are very respected on here.
Ultra is cheaper by a few dollars.
It will be going on a 2015 Polaris RZR 900. Oil and filter gets changed every spring. Usually about 1,000 miles on OCI. Oil will be M1 15-50, two quart capacity. Warm weather use mainly. Sits in heated garage in winter if I needed to use it.
What say you? They about the same quality wise?
Thanks!
Re: Mobil M1-110 or Fram Ultra XG7317 ? [Re: Srt20] #4088633 05/05/16 02:20 PM
Z
ZeeOSix Offline
Z
I'd say they are both very good quality filters, but the XG is a bit more efficient than the M1. XG is also full synthetic and might flow a bit better since the M1 is a blend media - 15W-50 is pretty thick oil. Both would do a fine job, and both over kill for the OCI unless you're focusing mainly on efficiency and quality.
Re: Mobil M1-110 or Fram Ultra XG7317 ? [Re: Srt20] #4088634 05/05/16 02:21 PM
K
Koz1 Offline
K
I used to use M1 now I use Ultras.
Currently using, 8100 X-clean EFE 5W-30, M1 5W-20 and Castrol Edge 0W-20 Gold B.
Re: Mobil M1-110 or Fram Ultra XG7317 ? [Re: Srt20] #4088637 05/05/16 02:26 PM
K
Kawiguy454 Offline
K
I would stay with the M1 if you dont have a reason to change. That would be the oil I use and you could probably go more than one season on it.
The m1-110 is pretty small I use it on one of my bikes. If you have more room a m1-104,105 or 210 will fit and also increase system capacity a good amount but that's just my way.
Re: Mobil M1-110 or Fram Ultra XG7317 ? [Re: Srt20] #4088638 05/05/16 02:28 PM
slacktide_bitog Offline
Both filters are high quality. Get whichever is the better price or on sale.
BTW, the M1 is also made by Fram smile
Re: Mobil M1-110 or Fram Ultra XG7317 ? [Re: Srt20] #4088648 05/05/16 02:41 PM
M
micmac Offline
M
The XG is a good filter, and cheaper. I had a UOA done after using an XG for 15000 miles, and there were no signs of problems with filtration. Less than $8 for the Fram
http://www.rockauto.com/en/partsearch/?partnum=xg7317
2011 Mazda2, 5 speed manual, 115k miles, 0w20 Eneos Sustina, xg6607 filter
Re: Mobil M1-110 or Fram Ultra XG7317 ? [Re: Srt20] #4088661 05/05/16 02:57 PM
CT8 Offline
you will never notice any difference in a million miles. The most important filter is the air filter.
Re: Mobil M1-110 or Fram Ultra XG7317 ? [Re: Srt20] #4088674 05/05/16 03:10 PM
B
Brybo86 Offline
B
Run the ultra for 2 years
12 Honda Odyssey 112k
09 Kymco Super8
08 Honda Accord 2.4L 164k
01 Kymco People 50
95 Yamaha Jog
Re: Mobil M1-110 or Fram Ultra XG7317 ? [Re: Srt20] #4088784 05/05/16 04:49 PM
Srt20 Offline OP
Thanks guys!
Ultra it is then. Yeah the OCI might be a little early for what I'm using, but it's only once a year and it's about $20.
Cheap piece of mind.
I'm using a R2C air filter this year. Used OEM last year. R2C makes no claims about hp, just claims it's a better filter efficiency filter. Non oiled reusable media. Blow it out from inside with 50-70 psi air, or vacuum outside.
I'll make a post in air filter section.
Re: Mobil M1-110 or Fram Ultra XG7317 ? [Re: Srt20] #4088792 05/05/16 04:55 PM
4
440Magnum Offline
4
XG for sure. M1 is seriously over-priced and under-tech for what it is- a synthetic blend media with no wire backing- compared to the XG which is a dual -layer synthetic media WITH wire backing.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 XJ 4x4 4.0/AX15, '14 WK2 4x4 3.6/8HP
Re: Mobil M1-110 or Fram Ultra XG7317 ? [Re: Brybo86] #4088816 05/05/16 05:09 PM
O
Oregoonian Offline
O
+1....agree. The Fram Ultra and M-1 are premium, top-grade filters....and can be used for much longer periods (might even go 3 or 4 years).
If you planned OCI (for filter) is just one year....using the above filters is just wasteful money wise. The Fram Tough Guard (a mid-tier filter),would be a better choice, and at about half the price.
03' Ford Focus SE(2.3L Duratec PZEV)/ 140K +
Pnz. Ultra 0w20 / Fram 'Ultra'/ OCI: 8000 +/-
ATF: Mercon V w/Lubegard Red
Re: Mobil M1-110 or Fram Ultra XG7317 ? [Re: Srt20] #4088829 05/05/16 05:16 PM
B
BigD1 Offline
B
A SuperTech 9688 has your name written on it. Buy a six pack with the money saved. I am in the crowd that is not going to leave a filter on for years.
1992 Toyota Pickup--AmazonBasics Conventional--10W-30--Toyota 90915YZZD1
Re: Mobil M1-110 or Fram Ultra XG7317 ? [Re: Srt20] #4088981 05/05/16 07:50 PM
G
gregk24 Offline
G
The Fram is the better of the two. It has better filtration, more capacity, superior media AND is the less expensive of the two.
2012 Honda Accord EX-L K24z3
59,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
51,xxx miles
Castrol Edge 0w40 / OEM filter
Re: Mobil M1-110 or Fram Ultra XG7317 ? [Re: Srt20] #4088986 05/05/16 07:55 PM
davison0976 Offline
Here are the internal parts and materials of the XG6607 which is a short version of XG7317.
If only there was some flow rate data for M1-110 and Fram XG7317, that would make it easier to decide.
Re: Mobil M1-110 or Fram Ultra XG7317 ? [Re: davison0976] #4089063 05/05/16 09:42 PM
Z
ZeeOSix Offline
Z
They will both flow way more than the engine can put out. But since the XG is full synthetic it probably flows a hair better than the M1 under the same conditions.
Page 1 of 3 1 2 3
