GunsInternational
by Yah-Tah-Hey - 02/19/20 03:39 PM
400hp VW Arteon confirmed for 2021
by wemay - 02/19/20 03:11 PM
redline 75W140
by mobilaltima - 02/19/20 02:50 PM
brake flush, upgrade to dot 4 or stay with dot 3
by apollo18 - 02/19/20 02:49 PM
I'm hoping it is the battery. 2016 Camry
by andyd - 02/19/20 02:48 PM
New Zoro 20% off $75 or more
by bullwinkle - 02/19/20 02:24 PM
New platinum beta ratio?
by mpgo4th - 02/19/20 01:40 PM
Lubrizol GF-6 Video Interview w/ Martin Birze
by ARCOgraphite - 02/19/20 01:31 PM
2008 GMC Sierra - AMSOIL SS 5w30 - 5300~ miles
by Samrsnow - 02/19/20 01:23 PM
Factory Ford filter cut open
by mpgo4th - 02/19/20 01:01 PM
VW coolant G12+ compatable G12++
by raaizin - 02/19/20 12:27 PM
Fun Electrical Gremlins with the Jeep
by Miller88 - 02/19/20 11:59 AM
Checking inner CV joints on fwd
by ram_man - 02/19/20 11:39 AM
AIR FRANCE FLIGHT 296
by 53' Stude - 02/19/20 10:51 AM
Brakes failing randomly
by Avery4 - 02/19/20 10:28 AM
Reliable Brand Washer / Dryer
by diyjake - 02/19/20 10:05 AM
Royal purple oil filters have gone downhill?
by Sprite - 02/19/20 09:25 AM
Meguiar's Ceramic Wax, $13.97 @ Wmart
by wemay - 02/19/20 09:23 AM
2015 Forester - whine/Rough at specific RPM
by MoneyJohn - 02/19/20 09:06 AM
Brake hum when backing up after a rain storm
by vortex - 02/19/20 08:54 AM
TorchHypnosis, Tgibson, GardenStateAudi, Strommen95, Idaholewis
70748 Registered Users
119 registered members (1978elcamino, andreigbs, 28oz, 750IX, 01rangerxl, 4WD, 14 invisible), 2,364 guests, and 25 spiders.
Topics301,659
Posts5,200,094
Members70,748
Page 1 of 3 1 2 3
Mazda Type-FZ Fluid & Skyactiv Drain/Refill Tips #4085059 05/02/16 02:13 AM
The Critic Online Crying OP
OP Online Crying
I recently performed a transmission service on a Mazda 3 sedan that is equipped with the 2.0L Skyactiv engine.
The transmission service on this car is performed a bit differently than other Mazdas so I wanted to pass along a few tips in case anyone decides to do one. In all honesty, this one is a lot easier than most transmissions that are marketed as "sealed" or "filled-for-life."
Here we go:
- You need to remove the underbody cover in order to remove the drain plug. The drain plug uses a 8mm allen key.
- Depending on the temperature, you will drain between 3.5-4 quarts. Install a new drain plug washer before re-installing the drain plug. You may find the drain plug washer to be stuck onto the pan - I had to use a painter's pole scraper and a mallet to remove the washer.
- There is a grey-colored dipstick marked "FZ" that is secured by a bolt. It is much easier to remove the bolt from under the car.
- To fill the transmission, some folks suggest removing the air intake tube to allow for more room to insert a funnel - but this is not necessary. There is a radiator hose that is adjacent to the air intake; the radiator hose is secured by a bracket. Remove the bracket (1 bolt) and this will allow you to move the hose around. By doing so, this step will give you barely enough room to squeeze a long funnel (18") into the space. I actually inserted a second funnel into the long funnel to allow for easier pouring.
- When refilling, start with 3.5 quarts. Start the engine and connect your scan tool to confirm the AT fluid temperature. The fluid level should be checked at 122F, which is warm (but not hot). Mazda only states that the fluid should be checked at a minimum of 122F, but does not specify a maximum temp. I would check/adjust the fluid level no higher than a few degrees above 122F; any AT fluid level will rise significantly once warmed up, so if you check the fluid level when the temp is too high, you may risk an under-fill.
- Check the fluid from underneath the car - this is the easiest way to access the dipstick. Do not try to remove the dipstick from the engine compartment. This particular vehicle took a total of 3.75 quarts for the drain and refill. If you do not have access to a scan tool, my experience was that the fluid temperature was at 122F within 1 minutes of start-up (but I drained the fluid when the car was still fairly hot and refilled right away, so your experience may vary).
Untitled by The Critic, on Flickr
This is a picture of the old fluid with 49,000 miles - it still looks very good. This transmission holds about 8 quarts and you will remove 40-50% with a drain and refill. The transmission does not have external cooler lines, so a "flush" is not possible. After the drain/refill, the fluid was a bit lighter, but did not turn blue.
Yes, the fluid is blue, but it turns light yellow after a few miles.
Confirming the fluid temperature before performing a level check - which is the ideal method for verifying the fluid level.
2011 Toyota Prius 1.8L - 203K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 143K - Valvoline Premium Blue Restore 10W-30
Re: Mazda Type-FZ Fluid & Skyactiv Drain/Refill Tips [Re: The Critic] #4085060 05/02/16 02:25 AM
Char Baby Offline
This is great information, Thanks!
What year was this Mazda3? Does it matter after 2010?
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Mazda Type-FZ Fluid & Skyactiv Drain/Refill Tips [Re: The Critic] #4085083 05/02/16 04:47 AM
P
Popsy Offline
P
Great post, thsnks!
96 Barchetta, 300V 5W40 | Forfour 95, M1 0W40
Mazda 6 2.3, Castrol 0W30 | Colt Ralliart, 300V 5W40
Re: Mazda Type-FZ Fluid & Skyactiv Drain/Refill Tips [Re: The Critic] #4085115 05/02/16 05:44 AM
Mr Nice Offline
Dang, too bad other mechanics don't have as much pride in their jobs as The Critic has.
Re: Mazda Type-FZ Fluid & Skyactiv Drain/Refill Tips [Re: The Critic] #4085144 05/02/16 06:29 AM
DBMaster Offline
I am planning to do this with my Mazda3 Skyactiv soon. I have a little over 60K miles on it. I know that there is a filter that COULD be changed, but I didn't plan to change it. I read a thread on a Mazda3 site showing that the pan is basically glued to the transmission with a very durable sealant that took the guy two hours to scrape off.
I got my four bottles of FZ fluid online from a Mazda parts site and I appreciated seeing this thread to confirm that I will have enough for the D&F. Thanks!
Re: Mazda Type-FZ Fluid & Skyactiv Drain/Refill Tips [Re: Char Baby] #4085409 05/02/16 11:06 AM
OP Online Crying
This post should be applicable to the ones that are equipped with a 2L Skyactiv engine.
The glue that you are referring to is RTV. I usually just wire wheel it off the transmission pan and use an old credit card to scrape off the residue from the transmission side. I really do not see a reason to drop the pan and replace the "rock stopper."
Re: Mazda Type-FZ Fluid & Skyactiv Drain/Refill Tips [Re: The Critic] #4085453 05/02/16 12:02 PM
DBMaster Offline
So, it is RTV? I was informed by a transmission shop a long time ago that silicone sealants and ATF didn't work well together. Maybe that was not correct.
Here's the thread I was talking about.
http://mazda3revolution.com/forums/2010-...uid-change.html
I've seen the filter being sold on eBay. It almost appears to have some sort of pleated media inside it. (Look at the fourth pic in the listing.) I'm still not changing it, though. Just doing a D&F on this already exceeds the maintenance recommended by Mazda. (Yes, I know about the whole "lifetime fill" argument.)
Transmission Filter
Re: Mazda Type-FZ Fluid & Skyactiv Drain/Refill Tips [Re: Mr Nice] #4085460 05/02/16 12:21 PM
B
Bgallagher Offline
B
+1 Great work!
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
Re: Mazda Type-FZ Fluid & Skyactiv Drain/Refill Tips [Re: The Critic] #4108377 05/27/16 05:24 PM
DBMaster Offline
Thanks again for the post. I just did my D&F. I, too, used two funnels after removing the bolt for the radiator hose bracket. The stuff I drained out wasn't dark and smelled almost the same as the new stuff. It's thin, like water, or maybe like a nice bourbon. It's amazing how clean that underbody pan keeps the entire engine compartment. Mine still looks new on top and hardly has anything dirty on the underside.
Re: Mazda Type-FZ Fluid & Skyactiv Drain/Refill Tips [Re: DBMaster] #4109896 05/29/16 04:02 PM
OP Online Crying
No prob. Glad it worked out well for you.
Re: Mazda Type-FZ Fluid & Skyactiv Drain/Refill Tips [Re: The Critic] #4109907 05/29/16 04:09 PM
SatinSilver Offline
How much time for labor does this job specify?
Re: Mazda Type-FZ Fluid & Skyactiv Drain/Refill Tips [Re: SatinSilver] #4109912 05/29/16 04:17 PM
OP Online Crying
It's a little more involved than the drain/refill on a Honda since the underbody cover needs to be removed, plus you should use a scan tool to verify the fluid temp when checking the fluid level. Filling the unit is sort of a pain too. But it is still much less involved than any of the current Toyota's that do not have a dipstick.
I think 45 minutes is a fair labor charge.
Re: Mazda Type-FZ Fluid & Skyactiv Drain/Refill Tips [Re: The Critic] #4111148 05/31/16 06:33 AM
DBMaster Offline
Personally, based upon what you saw here and what my drained fluid looked and smelled like (my 2012 Mazda 3 has 61,000 miles on it) I don't think this service is required.
But, the funny thing was that the owner's manual has no service interval specified. It was my understanding Mazda stated that the fluid should be CHECKED at 100,000 miles for signs of deterioration but, not necessarily changed). Then, the dealer tells me, "We recommend fluid and filter change at 30,000 miles.) The fluid did resemble fish sauce but seems like it would only smell fishy at the dealership.
YMMV
Re: Mazda Type-FZ Fluid & Skyactiv Drain/Refill Tips [Re: The Critic] #4111517 05/31/16 02:44 PM
T
ttvr4 Offline
T
I find it odd that Mazda states to check the ATF level at minimum of 122F. My rule of thumb is always "put back in exactly the same quantity that was drained". This way there is no discrepancies on overfill/under-fill.
-ttvr4
Re: Mazda Type-FZ Fluid & Skyactiv Drain/Refill Tips [Re: ttvr4] #4111617 05/31/16 04:28 PM
cjcride Offline
-ttvr4
Good rule, I follow it myself.
Keep in mind, what comes out hot has increased in volume a bit. What goes in at room temperature has not.
Page 1 of 3 1 2 3
