Anti-Counterfeiting packaging
by sloinker. 01/17/19 09:13 PM
Heavy Snow Predicted for Northeast Sat/Sun
by Donald. 01/17/19 08:34 PM
Pennzoil Ultra Plat 5w30 1.4L T Chevy Cruze 10k
by SubieBlue. 01/17/19 08:03 PM
Coated rotors
by supton. 01/17/19 07:51 PM
Good samaritan
by JLTD. 01/17/19 07:15 PM
Doing suspension work. Need alignment?
by HawkeyeScott. 01/17/19 05:45 PM
100mg CBD Cannabis Gel
by Al. 01/17/19 05:36 PM
Electric Car "Green Test"
by redbone3. 01/17/19 05:06 PM
Want to try a uoa
by Dylan1303. 01/17/19 04:56 PM
Happy Birthday, Betty White!
by eljefino. 01/17/19 04:20 PM
Fram Ultra for Ecoboost 2.7
by Purpfox. 01/17/19 04:10 PM
Idle Speed / 1998 Olds 88
by Mark72. 01/17/19 03:28 PM
Heat blanket for your oil filter!
by MrWideTires. 01/17/19 03:24 PM
Proper oil viscosities.
by Bullwinkle007. 01/17/19 03:20 PM
44$ for 5 gals of home heating oil treatment!
by Audios. 01/17/19 03:05 PM
Good job Hyundai!!!
by Andy636. 01/17/19 02:43 PM
PP 0W-20 vs PP HM 0W-20 - Difference in VI
by The Critic. 01/17/19 02:34 PM
Dickerson888, Frisky, polarisman340, jfradella, Bigyetti83
66964 Registered Users
97 registered members (Astro14, ArrestMeRedZ, AdditiveOCD, 209paulc, 2015_PSD, 40w8, 7 invisible), 1,519 guests, and 35 spiders.
Topics296,753
Posts4,958,255
Members66,964
Most Online2,577
Jan 14th, 2019
Page 1 of 6 1 2 6
QSUD in Ecotec: 2 qts. consumed in 3K ! #4084255
05/01/16 08:54 AM
05/01/16 08:54 AM
Da Swamp
Benzadmiral Offline OP
Da Swamp
Okay, I'll admit I haven't been checking the oil on the Regal with the 2.4L Ecotec as often as I should. The Buick has 65K miles, 3K miles/4 months on the current fill of 5W-30 QSUD dexos. For the first two years of my ownership, it's gotten AC Delco dexos oil from the dealer every 6 months/4500 miles, and the oil level never budged during an OCI. When my 4 "free" OCs were used up, I thought I'd try QSUD.
My last oil level check, I think, was in early March (mea culpa). I drew out the dipstick this morning, and it was bone dry. It took 2 qts. of Castrol Magnatec 5W-30 dexos to bring the level up to where it should be. I don't see any oil on the ground, and the engine compartment looks dry as well -- there are no obvious leaks on the block or on the components below.
True, coincidence is not causation . . . but it sure looks that way. Have any of you had a sudden change in oil consumption with QSUD, esp. on an Ecotec engine? This could be the old worry about synthetic cleaning stuff out inside my engine so that leaks occur. But how could that much crud have accumulated with my short OCIs?
Or is it simply that this engine does not "like" QSUD?
-- Paul W. (The Benzadmiral)
('11 Buick Regal CXL, charcoal/cream, 2.4L NA)
http://benzadmiral-uncle.blogspot.com/
Re: QSUD in Ecotec: 2 qts. consumed in 3K ! [Re: Benzadmiral] #4084261
05/01/16 09:02 AM
05/01/16 09:02 AM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
Sometimes, it will take an OCI or two for things to stabilize. Of course, your engine may not "like" this particular oil, but it hasn't been really given much of a chance yet.
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
Re: QSUD in Ecotec: 2 qts. consumed in 3K ! [Re: Benzadmiral] #4084309
05/01/16 09:34 AM
05/01/16 09:34 AM
Illinois
mrsilv04 Offline
mrsilv04  Offline
Illinois
Give it some time. They tend to use oil when brands are changed, until things settle down.
This is why it is a good idea to find an oil, and then stay with it. I use the same oil in everything that I drive. No unexpected consumption issues.
2004 Silverado - on its 3rd Jasper engine in less than one year.
Re: QSUD in Ecotec: 2 qts. consumed in 3K ! [Re: mrsilv04] #4084330
05/01/16 09:59 AM
05/01/16 09:59 AM
Twin Cities MN USA
Inspecktor Offline
Inspecktor  Offline
Twin Cities MN USA
+1
2001 Ranger 3.0 165,000 mi
2006 Dakota 4.7 156,000 mi
1986 GL1200A 73,500 mi
2001 Buick LeSabre Limited 292,000 mi
Re: QSUD in Ecotec: 2 qts. consumed in 3K ! [Re: Benzadmiral] #4084333
05/01/16 10:01 AM
05/01/16 10:01 AM
Leesport, PA
MedicRxDoc Offline
MedicRxDoc  Offline
Leesport, PA
There is also a TSB about oil consumption if it doesn't settle down.
Link to TSB
Re: QSUD in Ecotec: 2 qts. consumed in 3K ! [Re: Benzadmiral] #4084357
05/01/16 10:19 AM
05/01/16 10:19 AM
Cascadia
BikeWhisperer Offline
Cascadia
I had an Ecotec back 2005-2010 that absolutely guzzled Mobil 1. As it got older it started using all oil but not ever at the rate that it drank Mobil 1. It did better on Napa Synthetic which was cheaper anyway (when on sale).
Some engines just like to consume different oil formulations...try something else and see if things continue (indicating a possible problem) or things settle down.
2015 F150 XLT SCrew 2.7 Eco-Boost
5w-30 Motorcraft Semi-Syn, FL2062
2018 Ford Edge SEL Eco-Boost 2.0
5w-30 Motorcraft Semi-Syn, FL-910S
Re: QSUD in Ecotec: 2 qts. consumed in 3K ! [Re: Benzadmiral] #4084393
05/01/16 10:51 AM
05/01/16 10:51 AM
stower17 Offline
stower17  Offline
Sorry to hear about the oil burning problem youre having. This is a known problem with that engine and there are TSB's about the issue. There are a few threads on this site regarding the issue as well, mainly in the Equinox. If youre under warranty i would go to your dealer with your concern. When my ecotec was new i used QSUD or actually "Q Horsepower" exclusively for the first couple of years. This is not a QSUD problem.
Re: QSUD in Ecotec: 2 qts. consumed in 3K ! [Re: Benzadmiral] #4084421
05/01/16 11:23 AM
05/01/16 11:23 AM
Toronto Canada
WobblyElvis Online content
WobblyElvis  Online Content
Toronto Canada
It's hard to get an accurate oil level reading on this engine. The cartridge filter will slowly drain back into the sump causing the level to rise over night [no anti drain back valve]. This is a false high reading. According to the manual, you are supposed to check the oil within a few minutes of shut down.
My ecotec uses more synthetic oil than conventional.
Not to hi-jack this thread but it is relevant. Would someone explain to me the mechanism by which more oil would be used when switching brands. Hard to believe it is true.
Re: QSUD in Ecotec: 2 qts. consumed in 3K ! [Re: WobblyElvis] #4084437
05/01/16 11:40 AM
05/01/16 11:40 AM
stower17 Offline
stower17  Offline
What? If your oil level is going up after the engine has been shut off for awhile then you might not have the oil filter cap torqued down tight enough. The o-ring on the oil filter nipple is what keeps the oil in the filter housing and if its not torqued enough it will drain down to the oil pan. Ive been around these engines for over a decade now and have made all these mistakes when first getting accustomed to them.
Re: QSUD in Ecotec: 2 qts. consumed in 3K ! [Re: Benzadmiral] #4084440
05/01/16 11:44 AM
05/01/16 11:44 AM
stower17 Offline
stower17  Offline
The shoulders of the oil filter cap should be making contact with the engine block. If its not then its not torqued enough and oil will drain back.
Sorry this is off the OP topic but just had to clarify. Many people dont torque down the cap tight enough.
Re: QSUD in Ecotec: 2 qts. consumed in 3K ! [Re: WobblyElvis] #4084512
05/01/16 01:17 PM
05/01/16 01:17 PM
Garak Offline
Garak  Offline
It's been observed often enough, but I've never seen a valid mechanism presented. wink
Re: QSUD in Ecotec: 2 qts. consumed in 3K ! [Re: Benzadmiral] #4085171
05/02/16 07:00 AM
05/02/16 07:00 AM
Da Swamp
Da Swamp
Thanks, everybody,
I did check the oil within a few minutes of shutting down, as I always do -- and as I did in January and February, when I didn't notice any movement of the oil on the stick. It does seem odd that the engine would suddenly start burning oil just at the 62K mark, after I changed to QSUD.
That TSB: Is that something that a dealer will do out of warranty? My extended warranty just ended about 3-4K ago.
Re: QSUD in Ecotec: 2 qts. consumed in 3K ! [Re: Inspecktor] #4085197
05/02/16 07:37 AM
05/02/16 07:37 AM
Boston, MA
Bgallagher Offline
Bgallagher  Offline
Boston, MA
+1
+2 Castrol Magnetic should be a good oil for that.
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
Re: QSUD in Ecotec: 2 qts. consumed in 3K ! [Re: Benzadmiral] #4085241
05/02/16 08:29 AM
05/02/16 08:29 AM
stower17 Offline
stower17  Offline
Does Buick have the 5yr/100k mile powertrain like the Chevys did?
Re: QSUD in Ecotec: 2 qts. consumed in 3K ! [Re: stower17] #4085264
05/02/16 08:57 AM
05/02/16 08:57 AM
Da Swamp
Da Swamp
I hope so; I'll check my paperwork. However, the car first went into service in late 2010, I think, so the 5 years may be up.
Page 1 of 6 1 2 6
