Next 504/507 oil change
by sloinker - 01/26/20 03:02 PM
Salsa, do you buy it or make your own?
by 53' Stude - 01/26/20 02:29 PM
Cracklins/pork skins anyone?
by 53' Stude - 01/26/20 01:55 PM
RIP Kobe Bryant
by sloinker - 01/26/20 01:54 PM
Re-purposing an old iPad
by KrisZ - 01/26/20 01:10 PM
Put my dog down
by dja4260 - 01/26/20 01:09 PM
Oil choices for 240Z race car
by michaelsvintage - 01/26/20 12:54 PM
About Ballistol
by MGF1964 - 01/26/20 12:44 PM
Pop Quiz!
by Mad_Hatter - 01/26/20 12:41 PM
Tire Pressure Gauge
by Smoky14 - 01/26/20 12:06 PM
Castrol Gold Jug
by JohnnyJohnson - 01/26/20 11:22 AM
Honda/Multi-Vehicle ATF Comparison Chart
by jayjr1105 - 01/26/20 11:06 AM
4runner oil level.
by laserred96gt - 01/26/20 10:17 AM
Redline SL1 and Diesel Engines
by BigJohn - 01/26/20 09:53 AM
2011 Silverado red or orange dex cool?
by Corollaman - 01/26/20 08:39 AM
The Worst Muscle Cars Made. The Pinto was a M.C.?
by atikovi - 01/26/20 07:57 AM
2012 Ford Escape Transfer Case
by radtech91 - 01/26/20 07:49 AM
P0171 and P0174
by NavyVet88 - 01/26/20 05:04 AM
duppyman, MBDon, Socioil, kwashabcp, ronster
70530 Registered Users
101 registered members (2K2AcuraTL, 4WD, 750IX, Alfred_B, 53' Stude, 15 invisible), 2,676 guests, and 20 spiders.
Topics300,592
Posts5,178,917
Members70,530
Molybdenum, is there a downside? #4084141 05/01/16 06:52 AM
5
5170 Offline OP
5
I constantly read how this additive is the favorite of many bitog members. Is there any downside to this ingredient? Why don't all mfc use it?
'14 Hyundai Sonata Sport 2.4L - 5W-20 Havoline DS, TG9688
Re: Molybdenum, is there a downside? [Re: 5170] #4084147 05/01/16 06:59 AM
J
Jetronic Offline
J
Deposits form during the Thermo-oxidation Engine Oil Simulation Test, so you're not guaranteed to pass if you have a lot of moly.
AR Giulietta 2.0 JTDM-2 -- Total Quartz 9000 Energy 0w30
Hankook Ventus Prime 2 215/50R17 (front)
Pirelli P7 Cinturato 225/45R17 (rear)
Re: Molybdenum, is there a downside? [Re: 5170] #4085032 05/01/16 11:48 PM
U
UltrafanUK Offline
U
YES!
1/ Good quality (Tri-nuke etc) Moly is expensive, so most oils in use in the USA do not contain any Moly(Mo), OR have so little that it has no real effect.
2/ Cheap forms (Not made and fully certified by a German chemical company) drop out of solution or suspension after a few years (Then it sure does not work unless stirred up).
3/ CORROSION, too much Moly can increase corrosion rates (Big issue with older diesels), hence some engines must not use an engine oil with Mo in it. Castrol GTX is a good one for such engines.
4/ A lot of engine oil mixers do NOT CHECK FOR CHEMICAL INTERFERENCE WITH OTHER ADDITIVES, or even new high tech base stocks. The big players like Mobil, Castrol, SHELL and Liqui Moly sure do.
CONCLUSION: Use a major brand full synthetic and stay away from the use of non TUV Sud (German certs) oil additives not sold by Liqui Moly (Owned by Fuchs a big refiner) or Castrol (Their classic car division do sell a few, but only in bulk).
PS: If you have bought a non TUV or API certified oil additive, READ THE PRODUCT DATA SHEET (Contents and instructions), then throw it in the correct rubbish bin, before rather than after use (Gingerbeer joke)!
Re: Molybdenum, is there a downside? [Re: 5170] #4085170 05/02/16 07:00 AM
5
5170 Offline OP
5
Thank you UltrafanUK
Re: Molybdenum, is there a downside? [Re: 5170] #4085176 05/02/16 07:05 AM
V
Virtus_Probi Offline
V
An additive with very small MoS2 particles in suspension (like Liqui Moly) will make your oil look darker, even when it is fresh. Some people don't like this effect...
2014 Forester XT, 111000 miles
Last Change;
M1 0W30 AFE
Tokyo Roki 15208AA170 filter
Re: Molybdenum, is there a downside? [Re: 5170] #4085277 05/02/16 09:07 AM
Solarent Offline
The primary use for molybdenum compounds is for fuel economy benefits. This benefit works best when combined with ZDDP and adding more Molybdenum compounds doesn't necessarily increase the benefit or extend the benefit through longer oil changes.
Most formulators have chosen to balance zdp and molybdenum compounds to give you the performance required by the specifications list in the owners manual.
Re: Molybdenum, is there a downside? [Re: Solarent] #4086343 05/03/16 11:51 AM
MolaKule Offline
Global Moderator
Global Moderator
thumbsup
Charlie Eppes: "What do you think we should do now?"
Don Eppes: "The same thing when I was in school and I didn't know the answer – fake it." From NUMB3RS
Re: Molybdenum, is there a downside? [Re: UltrafanUK] #4086796 05/03/16 07:47 PM
dailydriver Offline
Are you claiming that 'small player'/boutique blenders (like Red Line) which have high 'dimer'/di-nuke type moly levels are also guilty of the above omission/oversight?? shrug
Or was this ONLY directed at car owners dumping untold amounts of (non-LM) moly additives into their sumps?
2016 Ford Fiesta ST 17K miles
Ravenol REP 5W-30
Fram XG3600 filter
Ravenol MTF-2 in the IB6 transaxle
Re: Molybdenum, is there a downside? [Re: 5170] #4088941 05/05/16 07:09 PM
steve20 Offline
I love the part throttle increased responsiveness effect of LM MSO2 in older engines, say 100K & up--more than the butt-dyno IMO. Newer engines may make a difference, but not felt by the dyno
Steve
Re: Molybdenum, is there a downside? [Re: dailydriver] #4097632 05/15/16 05:49 PM
U
UltrafanUK Offline
U
No, when the folks here talk about additives, they are talking about ones not included in an engine oil by the oil mixer or oil company. Oil mixers like Redline do test their products to some extent, BUT most of the so called Snake Oil Mixers do not.
I do use Ceratec with Shell Ultra and LM Synthoil High Tech, but I'm sure LM test their additives with common major brand oils.
Most Redline oils seem to be aimed at Race engines or thin oil applications, so they have a lot of Moly and less detergents. So they are not designed for long OCI's.
Re: Molybdenum, is there a downside? [Re: 5170] #4099657 05/17/16 10:30 PM
Marco620 Offline
In my new Honda Civic I use Lubegard Biotech. Arco used LM Mos2 in a quite new Honda and it gave him trouble. Mos2 works well in older cars but newer cars I would use Lubegard Biotech or Redline oil as an additive for a kick in molybdenum.
15' Civic 1.8 i-vtec 302,000 mi M1 AP 0w20 & LG Biotech, BP CVT Fluid,GUMOUT W/ PEA
Doberman Whisperer!
Doberman,Heckler & Koch & SONY Aficionado
Re: Molybdenum, is there a downside? [Re: Marco620] #4099929 05/18/16 07:35 AM
K
kschachn Offline
K
Yeah, considering his track record of ruining nearly every vehicle he touches (or at least claims he did), I wouldn't worry about that.
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 430K
2000 Toyota ECHO, 284K
Re: Molybdenum, is there a downside? [Re: Virtus_Probi] #4100461 05/18/16 07:24 PM
A
andrewp1998 Offline
A
Royal Purple support emailed me back and they don't use it cause it stays in suspension.. Maybe they don't think it is a decent wear anti- additive or causes other issues as you guys have stated?
i didn't ask them details.
2001 Honda civic HX vtecE- 5 spd.
Re: Molybdenum, is there a downside? [Re: andrewp1998] #4101921 05/20/16 12:08 PM
MolaKule Offline
Global Moderator
Global Moderator
What did they say exactly - could you quote their text? Something doesn't add up here.
Re: Molybdenum, is there a downside? [Re: UltrafanUK] #4101925 05/20/16 12:18 PM
O
Olas Offline
O
Under what circumstances might this happen? Is the Mo in 4 litres of Redline & 1 can of LM mos2 of sufficient concentration to cause harm?
Cable ties should hold it
