2012 Elantra battery running at 11.7 volts
by schuylkill - 01/26/20 03:31 PM
Chevron Supreme no longer at Costco
by OilUzer - 01/26/20 03:18 PM
Next 504/507 oil change
by sloinker - 01/26/20 03:02 PM
Salsa, do you buy it or make your own?
by 53' Stude - 01/26/20 02:29 PM
Cracklins/pork skins anyone?
by 53' Stude - 01/26/20 01:55 PM
RIP Kobe Bryant
by sloinker - 01/26/20 01:54 PM
Re-purposing an old iPad
by KrisZ - 01/26/20 01:10 PM
Put my dog down
by dja4260 - 01/26/20 01:09 PM
Oil choices for 240Z race car
by michaelsvintage - 01/26/20 12:54 PM
About Ballistol
by MGF1964 - 01/26/20 12:44 PM
Pop Quiz!
by Mad_Hatter - 01/26/20 12:41 PM
Tire Pressure Gauge
by Smoky14 - 01/26/20 12:06 PM
Castrol Gold Jug
by JohnnyJohnson - 01/26/20 11:22 AM
Honda/Multi-Vehicle ATF Comparison Chart
by jayjr1105 - 01/26/20 11:06 AM
4runner oil level.
by laserred96gt - 01/26/20 10:17 AM
Redline SL1 and Diesel Engines
by BigJohn - 01/26/20 09:53 AM
2011 Silverado red or orange dex cool?
by Corollaman - 01/26/20 08:39 AM
The Worst Muscle Cars Made. The Pinto was a M.C.?
by atikovi - 01/26/20 07:57 AM
duppyman, MBDon, Socioil, kwashabcp, ronster
70530 Registered Users
116 registered members (antone, 69Torino, 2009Caraman, Ag76, alchargo, ArrestMeRedZ, 16 invisible), 2,410 guests, and 22 spiders.
Topics300,595
Posts5,178,952
Members70,530
Free Riding Mower Needs a Carb #4083671 04/30/16 02:41 PM
Delta Offline OP
Since I'm mowing two lawns now I needed something to make it quicker and easier. Acquired a 10 year old Craftsman rider. Previous owner had the carb bead blasted? Never heard of that, but it runs very poorly, as in way too rich. The oil smells like fuel really bad. Not wanting to fool with another carburetor rebuild this year, I'm just going to replace it. Looking for suggestions as to where online to purchase.
Couple pics:
Not got into it too much, but it's a 13.5 HP Briggs with the electric fuel shut-off solenoid. Any help would be appreciated.
'17 VW GTI 2.0T - 6MT - 19K - Edge 0w40
'15 Camry SE - 2.5 - 26K - PP 0w20
'09 Tacoma TRD Offroad 4x4 - 4.0 - 138K - RGT 5w30
Re: Free Riding Mower Needs a Carb [Re: Delta] #4083678 04/30/16 02:50 PM
P
Pop_Rivit Offline
P
It sounds like the previous owner didn't know what they were doing when/if they rebuilt it. But it shouldn't be too hard to find either a local source or an online source if you don't want to open up the existing carburetor. You can probably find one on Ebay or one of the many small engine specialty websites. If you're not sure which carburetor you need then you can contact them and they'll should be able to make a recommendation. I'm guessing even Amazon may have some available.
Re: Free Riding Mower Needs a Carb [Re: Delta] #4083682 04/30/16 02:56 PM
Soggydog Offline
Currently running...
2011 Ford F250 4x4 6.7L, 2011 Toyota Camry SE 2.5L, 2002 Dodge Caravan 3.3L,
2012 Honda Rincon,2012 Honda Rancher AT,09 Honda Trx90
Re: Free Riding Mower Needs a Carb [Re: Delta] #4083706 04/30/16 03:28 PM
J
JayhawkRoy Offline
J
searspartsdirect has your carb. Part # 69916 $96.79 plus shipping
I used model 21B807 and Type 0326E1 to get there in their parts locator.
Double-check to make sure it is correct, though.
Re: Free Riding Mower Needs a Carb [Re: JayhawkRoy] #4083721 04/30/16 03:45 PM
Delta Offline OP
That's exactly it, but after clicking the part it came up $120. Still cheaper than tearing it off a dozen times.
Re: Free Riding Mower Needs a Carb [Re: Delta] #4083764 04/30/16 04:53 PM
J
JTK Offline
J
My Sears rider has the same Briggs "AVS" single cylinder engine. I know on mine, the choke on occasion will not flip back open on it's own and I have to do it manually. I believe the plastic throat on the carb is warped a bit, causing the choke plate to stick.
My point being, make sure the choke is really open after the engine starts and warms slightly.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: Free Riding Mower Needs a Carb [Re: Delta] #4083814 04/30/16 06:08 PM
M
MinamiKotaro Offline
M
Carbs suck. Put fuel injection and COP on that sucker.
1967 VW Beetle: Delo 15w40/ST4386
2004 Saturn Ion: Magnatec 5w30/DW5436
2014 Polaris Ranger 570: Delo 5-40/Wix 51356
Re: Free Riding Mower Needs a Carb [Re: Delta] #4083826 04/30/16 06:30 PM
spk2000 Offline
For that price i would opt for a new motor. Subaru or Honda would be best but cost more. Then you don't have to worry about the cost of the next part that goes.
96 Grand Marquis 203,000 mi
01 Sable LS Wagon 163,000 mi
02 Montero 191,000 mi
03 Sable LS Sedan 73,000 mi
Re: Free Riding Mower Needs a Carb [Re: Delta] #4083943 04/30/16 08:49 PM
Y
yeehaw1960 Offline
Y
Type the model number into Ebay search block with the word carburetor. Almost positively the cheapest place to find one. Don't buy one until you look at all of them offered to get the best price. Be careful if you consider re powering it...the motor will have to be about the same horsepower and have a cast iron flywheel.
Does it run as rich when the air filter isn't in place? Could be the air filter. Keep in mind that even a novice can pull that carb and rebuild it in less than an hour or so for much less than the price of a carb. Go to you tube for a video walking you through the process. Also take a few digital pictures to reference when you're reassembling it. You can "bead blast" the outside of the carb all day and not clean the little passages that get clogged. It sounds like the needle and seat is letting fuel drain into the crankcase.
Bubbatime or JTK might be able to share why poorly adjusted valves or something internal might be causing it to run rich. I'd get as much information as possible before investing a dime.
http://www.ebay.com/itm/Carburetor-590400-Briggs-217807-219977-21B807-21B877-21B906-more-/381589187060?hash=item58d87ce9f4:g:IZwAAOSwQgpW~9Mr
Free shipping makes it comparable to the other price above and pay pal makes it easy to do a charge back if it turns out to be junk.
Re: Free Riding Mower Needs a Carb [Re: Delta] #4083952 04/30/16 08:59 PM
B
bubbatime Offline
B
Always replace the fuel line at 10 years old. Add a fuel shutoff into the line as well.
2019 Honda CRV 1.5T dealer bulk
2017 Chrysler Pacifica SuperTech synthetic 5W20
2013 Yamaha XT250 Valvoline motorcycle 10W40
2006 GMC Sierra SuperTech high mileage 5W30
Re: Free Riding Mower Needs a Carb [Re: spk2000] #4083953 04/30/16 09:02 PM
B
bubbatime Offline
B
The cost of a replacement 13.5HP engine would be more than what the mower is worth. The engine is likely perfectly fine other than it's current fuel delivery problem.
Re: Free Riding Mower Needs a Carb [Re: Delta] #4083975 04/30/16 09:42 PM
P
Panzerman Offline
P
Ebay !!!!!
2006 Dodge Ram 2500 Hemi 4x4
2016 Dodge Challenger Scat Pack
Re: Free Riding Mower Needs a Carb [Re: Delta] #4084074 05/01/16 04:43 AM
Delta Offline OP
I will probably do a little tinkering with it here later on today. I'm a little suspect of the choke sticking, as it's rich all the time, it gets really bad under load. Air filter is like new. I will also pop off the valve cover for a quick inspection. Whoever had it previously kept good care of it. For 10 years old there is no rust or obvious damage I can see.
Re: Free Riding Mower Needs a Carb [Re: Delta] #4084252 05/01/16 08:52 AM
J
JTK Offline
J
That mower does look to be in good shape. I'd play with the choke or just replace the carb if it's not that.
I've got a Craftsman LT2000 with the 18hp version of that engine. It will continue to run when the choke sticks, but it pops, sputters,smokes and has no power as you'd suspect from a sticking choke.
Re: Free Riding Mower Needs a Carb [Re: Delta] #4084258 05/01/16 09:00 AM
Delta Offline OP
Dug a little bit into it, the choke does not appear to be sticking. The spark plug was all wet from fuel as well as the intake tube having fuel in it. New carb will be ordered today so I can put it on next weekend.
