2018 Ram 2500 with 21k miles. Delo 400 XSP 5w40
by bigbadbowtie - 02/27/20 11:08 AM
For those always asking about tiny Computers
by jayjr1105 - 02/27/20 11:05 AM
Original 2016 VW Passat cabin filter
by Vaca - 02/27/20 11:02 AM
Original 2016 VW Passat air filter
by Vaca - 02/27/20 10:54 AM
Napa Exceptional Customer Service
by Fitz98 - 02/27/20 10:38 AM
Astra 400 ?
by WyrTwister - 02/27/20 09:58 AM
Will thinner oil damage anything when it is burned?
by Fordiesel69 - 02/27/20 09:38 AM
Old news for Hyundai/Kia?
by Farnsworth - 02/27/20 09:33 AM
Looking for AA 25% off coupon code.
by JustChuck - 02/27/20 09:17 AM
New to the LS460 and The World Of Lexus. Questions!
by gr8gatzby - 02/27/20 08:41 AM
New old guy back.
by BJD2020 - 02/27/20 07:45 AM
Help me Decide
by Gebo - 02/27/20 07:36 AM
FWD - Death traps with miss matched tires.
by Fordiesel69 - 02/27/20 07:13 AM
Napa Gold Sale
by Toto - 02/27/20 06:52 AM
2016 or 17 Honda CR-V
by Loogie - 02/27/20 05:20 AM
RIP Clive Cussler
by PimTac - 02/27/20 04:48 AM
Pirelli Cinturato P7 Allseason PLUS "II"
by Char Baby - 02/27/20 03:31 AM
CCI clean .22 ammo - polymer coated HV
by Shannow - 02/27/20 03:23 AM
5w-20 vs 5w-30
by joel95ex - 02/26/20 10:59 PM
Scotts994Runner, Bu33leGutz, splitthebreak, shadango, JimNastic316
70808 Registered Users
83 registered members (AZjeff, Astro14, atikovi, ARCOgraphite, 1978elcamino, Alfred_B, 4 invisible), 2,034 guests, and 13 spiders.
Topics301,989
Posts5,206,924
Members70,808
"Low Coolant" light doesn't vanish. #4082803 04/29/16 01:07 PM
O
OpenClose Offline OP
O
I started getting a "low coolant" light lately. It disappears after a bit of driving.
I was worried I had a leak of sorts, so I checked the level. It was fine. If not, too high.
The obvious next step was that there was air in the system, so I opened the dribbler valve right above the thermostat while the engine was hot, and closed it afterwards.
The light still pops up every time.
Could this be because my thermostat doesn't have a hole in it?
1999 Buick Regal GS SC 115k
Pennzoil Platinum w/ PurePlus
FRAM Ultra Synthetic
TransGo Shift Kit
Re: "Low Coolant" light doesn't vanish. [Re: OpenClose] #4082806 04/29/16 01:11 PM
Chris142 Offline
Bad sender
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: "Low Coolant" light doesn't vanish. [Re: Chris142] #4082817 04/29/16 01:22 PM
O
O
You mean sensor?
I'm looking them up as we speak.
TransGo Shift Kit
Re: "Low Coolant" light doesn't vanish. [Re: OpenClose] #4082818 04/29/16 01:27 PM
rooflessVW Offline
Sender/sensor are synonymous.
"Zed's dead baby, Zed's dead."
Re: "Low Coolant" light doesn't vanish. [Re: OpenClose] #4082826 04/29/16 01:40 PM
W
Warstud Offline
W
Is it on the expansion tank....or on the radiator?
Re: "Low Coolant" light doesn't vanish. [Re: OpenClose] #4082891 04/29/16 03:30 PM
Chris142 Offline
Of its on his regal it's on the radiator. Passenger side about 5 inches down
Re: "Low Coolant" light doesn't vanish. [Re: OpenClose] #4082909 04/29/16 03:51 PM
T
Trav Offline
T
Open the cap with the engine cold and see if it needs any, this is common with these. Don't go by the level in the overflow bottle.
Re: "Low Coolant" light doesn't vanish. [Re: Chris142] #4082959 04/29/16 05:28 PM
B
BigD1 Offline
B
Same one that fits my Oldsmobile. NEW GM 10096163 ENGINE COOLANT LEVEL SENSOR $18.65 shipped.
1992 Toyota Pickup--AmazonBasics Conventional--10W-30--Toyota 90915YZZD1
Re: "Low Coolant" light doesn't vanish. [Re: OpenClose] #4082990 04/29/16 06:29 PM
Nick1994 Offline
My brother had a 1999 Buick Century that my grandfather owned before him. It had the low coolant light on for years. Never did figure it out, but didn't care because the level was fine.
2015 Hyundai Genesis 5.0L 57k Mobil 1 5w30 & Wix
2000 Toyota Camry 2.2L 236k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 150k Mobil 1 HM 10w40 & Fram Ultra
Re: "Low Coolant" light doesn't vanish. [Re: Nick1994] #4082993 04/29/16 06:33 PM
69GTX Offline
My 1999 5.7L was giving me this problem about 3 years ago, a common occurrence on these cars as they age. No doubt the sensor had never been cleaned. While it wasn't gunked up in the last, a light cleaning of the metal probe with fine sandpaper cleared it up. No problems since.
2001 Lincoln Cont 4.6L DOHC/ 50K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: "Low Coolant" light doesn't vanish. [Re: OpenClose] #4083021 04/29/16 07:28 PM
Dorian Offline
I had a strange feeling that it was a 3800. My aunts was always on in her 97.
15 Camry Hybrid SE 63K 0W20 Magnatec
14.5 Camry SE 2AR 0W20 M1 AFE 68K (Mom's)
98 Chevy Prizm 1ZZ M1 AFE 0W30 163K (Brother's)
Re: "Low Coolant" light doesn't vanish. [Re: Nick1994] #4084684 05/01/16 04:44 PM
T
Trav Offline
T
On these cars if the radiator ever needs changing you need to drill a hole for the sensor on many replacement radiators to get fluid or the sensor will stay dry and the light on.
Even a new OE Delco needs drilling, the boss is there and you can put a sensor in but its a dry hole until you drill through.
The reason for this is the radiator also fits cars with the sensor in the overflow bottle.
Re: "Low Coolant" light doesn't vanish. [Re: OpenClose] #4092236 05/09/16 12:32 PM
O
O
It turns out, coolant wasn't draining from the reservoir properly. Pulled the hose out, and nothing came through.
So I replaced the hose, and it seems to work. It still pops up sometimes, but disappears when the engine warms up. Does that sound like it needs to be burped again?
TransGo Shift Kit
Re: "Low Coolant" light doesn't vanish. [Re: OpenClose] #4100816 05/19/16 08:28 AM
B
BayouTodd Offline
B
My Pontiac does that too sometines, as mentioned take the coolant level sensor out and either replace with a new one or just try cleaning off the crude on the end of the sensor and reinstall, that HAS worked for me in the past too. YMMV
Regards,
Todd
German Castrol Collector, GO Green!
My weekend mid life crisis:
99 Trans Am Firehawk #157 LS1 Vert
http://www.fquick.com/todbnla
Re: "Low Coolant" light doesn't vanish. [Re: OpenClose] #4105583 05/24/16 05:50 PM
O
O
OK, so it still pops up, but it always disappears when the car warms up. What could cause this?
TransGo Shift Kit
