There was a writeup online about how this company appeared on ebay.
There are a couple other ones that sell brake packages for very cheap.
Mine as well were powerstop pads and rotors. They worked fine for my vehicles. I think some of these companies offer better products than you would get over the counter at advance auto parts or autozone. Not quite OEM quality but ok.
Originally Posted By: Bgallagher
Originally Posted By: pdxglocker9mm
I just put ceramic pads on two of my vehicles they are a afrermarket but seem decent quality. I got them off ebay Callahan brake parts sold by brake over stock a shell company really because they are actually Powerstop pads.
I got rotors too.
For the vibe 2005 it was 56 bucks for solid rotors and pads
For the sierra 2008 it was 89 dollars for solid rotors and pads
This was the front only on both vehicles because they have rear drums
I clocked the rotors using a dial indicator to get minimal run out which was about 0.0005" max on the vibe and 0.0007" max on the truck. Since less than 0.001" is the spec i shoot for. (some say less than 0.003" max ok) i feel confident i did my part to have a pulsation free brake job. They seem good so far. one reason i went with the callahans is that they made a good case for their rotors being heftier than the run of the mill junk. I must say i was impressed with the construction of the rotors. They are certainly heavy and machined well. The vibe has 90k and had warped rotors second set of pads.
The sierra has only 28k but got into some road salt and or a trip to the beach and the rotors were rusted beyond the ability to refinish.
For the price i would definately go with rotors and pads again if i ever need to do brakes on something.
I also flushed the brake system on both and cleaned and adjusted thd rear drums. I should be good to go for a while.
Did Tommy Boy sell you the parts?
