Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
Transmission fluid leak
by dawgn86. 12/17/18 07:53 PM
QuickJack BL-5000SLX and my Optima...
by WhizkidTN. 12/17/18 07:23 PM
Champion Air Filter Opinions?
by JerryBob. 12/17/18 06:18 PM
Tundra transfer case plug torque (Borg Warner)
by Idlewild294. 12/17/18 06:03 PM
Winter tire question?
by Muskieteer. 12/17/18 05:31 PM
Who makes good ball joints these days?
by GSCJR. 12/17/18 04:51 PM
Bought a used Ford Fusion
by krismoriah72. 12/17/18 04:14 PM
Valvoline NextGen Tech Oil
by DirtyOilGuy. 12/17/18 04:08 PM
Witty comment regarding a lame car
by Number_35. 12/17/18 03:43 PM
'80s oil literature
by Number_35. 12/17/18 03:26 PM
Recommend on oil for 2017 Kia Sportage 2.4
by SlavaB. 12/17/18 02:57 PM
No more Delo at my Costco. T4 now
by BeerCan. 12/17/18 02:16 PM
Found this
by davedude. 12/17/18 02:15 PM
Practice CLS material
by RDY4WAR. 12/17/18 01:52 PM
2005 Chevy Silverado 5.3 vortex
by MSpeer. 12/17/18 12:01 PM
hopsofir, genera2800, oghl, hdlss, dsmdylan
66711 Registered Users
28 registered members (dlundblad, 53' Stude, Char Baby, ARB1977, D0nat, biron, 1 invisible), 829 guests, and 33 spiders.
Topics295,205
Posts4,929,884
Members66,711
Most Online2,553
Oct 27th, 2018
303 application process for engine bay #4082462
04/29/16 07:29 AM
04/29/16 07:29 AM
NJ
buster Offline OP
buster  Offline OP
NJ
With Sonus Motorkote, you spray it over the entire engine and let it sit and it will dry to a smooth finish. A good way to speed this up is to spray the engine down while cold, then go for a drive and get the engine hot. That helps cure it.
Does anyone have any experience using 303 in this way? I want to try 303 being I can get it at retail and don't have to order it. Thanks.
Re: 303 application process for engine bay [Re: buster] #4082511
04/29/16 08:30 AM
04/29/16 08:30 AM
Danville, KY
Mark_Walk Offline
Mark_Walk  Offline
Danville, KY
303 is a UV inhibitor. That's an expensive product to use in an area that rarely sees the sun.
2011 BMW328xi (M1 0w40) 118,000mi
2010 Mazda6iTP (SYNPWR 5w20) 151,000mi
2007 VolvoXC70 (M1 0w40) 141,000mi
2002 TrailBlazerEXT (PYB 5w30) 155,000mi
Re: 303 application process for engine bay [Re: buster] #4082512
04/29/16 08:31 AM
04/29/16 08:31 AM
Danville, KY
Mark_Walk Offline
Mark_Walk  Offline
Danville, KY
I use it on my 2 Royalex Canoes by the way....good stuff.
Re: 303 application process for engine bay [Re: buster] #4082513
04/29/16 08:35 AM
04/29/16 08:35 AM
midwest
JamesBond Offline
JamesBond  Offline
midwest
When I do my engine bay, I use either vinylex or some old armor all tire foam and spray some on an old thick sock that has been wet with water but then thoroughly wrung out before the product is applied.
Then I wipe everything down with the sock.
The water thins out the product to avoid everything being too greasy and using the sock avoids the spots you get from just spraying the product on.
Re: 303 application process for engine bay [Re: buster] #4082537
04/29/16 08:58 AM
04/29/16 08:58 AM
NJ
buster Offline OP
buster  Offline OP
NJ
It's used quite a bit by detailers in the engine bay. I just found my answer.
http://www.polishedbliss.co.uk/acatalog/303-aerospace-protectant-cat19.html
Quote:
For use on engine bays, clean and dry your engine bay first. Then spray 303 Aerospace Protectant liberally over all surfaces, and leave for 4-6 hours to dry. At first you may not believe that this method will work, but trust us it does; it will deliver far superior results compared to trying to dress the same surfaces by wiping on the product with an applicator pad. When you check the results after 4-6 hours, there may still be a few areas that need a quick wipe down with a PB Utility Towel, but everything else will be dry to the touch and looking like new. For use on interior surfaces and door seals, spray 303 Aerospace Protectant onto a Meguiar’s Microfibre Applicator Pad and then wipe down the surfaces to be protected lightly and evenly before allowing them to dry naturally. Do not be tempted to over-apply the product or buff the protected surfaces once dry; neither action is necessary, and both will result in a sub-standard finish.
http://www.detailedimage.com/Ask-a-Pro/how-to-detail-your-engine-bay/
http://www.autogeek.net/engine-guide.html
Re: 303 application process for engine bay [Re: buster] #4082571
04/29/16 09:31 AM
04/29/16 09:31 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
I like the Mothers VLR for engines, not too shiny and doesn't smear or attract dust.
Re: 303 application process for engine bay [Re: buster] #4082600
04/29/16 09:46 AM
04/29/16 09:46 AM
5600 feet elevation, Arizona
double vanos Offline
I recently used what was left of my Duragloss rinse less car wash to wipe down the engine bay and what a nice job it did! Next time I do it, I'll post pictures.
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Re: 303 application process for engine bay [Re: double vanos] #4082612
04/29/16 09:55 AM
04/29/16 09:55 AM
Imperial Valley, California
Jeffs2006EvoIX Offline
I have used 303 for years on my car. Its a good product, but I dont use it on the engine. You can but I choose not to. Yes if you mist it over everything and let it dry for 6 hrs it will be nice, but not many people can just leave their cars parked for that long.
I just use my Duragloss instant detailer. I mist it over everything and wipe it down immediately. It leaves a shine and is anti static. Car is done in minutes, not HOURS.
I use the 303 on ALL outside rubber/hard plastic on my cars. Good Stuff.
Jeff
"You don't have to be crazy to do this... But it helps." Bob Ross.
Re: 303 application process for engine bay [Re: buster] #4082671
04/29/16 10:59 AM
04/29/16 10:59 AM
Las Vegas NV
Tempest Offline
Tempest  Offline
Las Vegas NV
I have used 303 on a few engines and it makes the engine look very nice.
Make sure to get a better atomizing sprayer as the sprayers that come on the bottle move too much product in too tight a pattern.
I spray and let sit for a few minutes then come back with a microfiber towel and sop up the excess. Far too dry here to let it sit for "a few hours" as in the link. It will dry up in minutes here.
It is very expensive for engines however, and I'm on the look out for something cheaper and also water based with the same results.
“Never underestimate the difficulty of changing false beliefs by facts.” --- Henry Rosovsky
Re: 303 application process for engine bay [Re: buster] #4082684
04/29/16 11:09 AM
04/29/16 11:09 AM
Las Vegas NV
Tempest Offline
Tempest  Offline
Las Vegas NV
I've tried Meguiars D156 as an experiment on the engine trim cover.
It went on OK but didn't leave any gloss or enhancement at all. Just looked flat.
Re: 303 application process for engine bay [Re: Tempest] #4082688
04/29/16 11:12 AM
04/29/16 11:12 AM
NJ
buster Offline OP
buster  Offline OP
NJ
thanks Tempest.
Tempest, I've used this and it works well. I just don't want to order it.
http://www.autogeek.net/sonus-trim-motor-kote.html
Re: 303 application process for engine bay [Re: buster] #4082694
04/29/16 11:22 AM
04/29/16 11:22 AM
NJ
buster Offline OP
buster  Offline OP
NJ
*where can one get a better sprayer?
Re: 303 application process for engine bay [Re: buster] #4082716
04/29/16 11:40 AM
04/29/16 11:40 AM
NJ
buster Offline OP
buster  Offline OP
NJ
I'll try Lowes/Home Depot.
Re: 303 application process for engine bay [Re: buster] #4082815
04/29/16 01:20 PM
04/29/16 01:20 PM
Las Vegas NV
Tempest Offline
Tempest  Offline
Las Vegas NV
I'm lucky in that I have a couple of detail shops around town that have a good selection of these things.
I would look for one of these:
They make a blue and white version which produces a very fine mist for glass cleaners, but I haven't tried it with 303, yet.
Re: 303 application process for engine bay [Re: buster] #4082823
04/29/16 01:38 PM
04/29/16 01:38 PM
NJ
buster Offline OP
buster  Offline OP
NJ
cheers Thank you
