Essex Engine Plant (Canada)
by BlueOvalFitter - 01/26/20 03:18 AM
Mopar oil bottles
by Franz - 01/26/20 12:47 AM
Ultra-rare barn find!
by Toy4x4 - 01/26/20 12:11 AM
2015 Hyundai Genesis 5.0L Review
by Nick1994 - 01/25/20 11:56 PM
My doggie had a rough week
by Chris142 - 01/25/20 11:26 PM
Delivery meal kit review - Dinnerly vs HelloFresh
by pezzy669 - 01/25/20 10:32 PM
Eotech Vudu scopes
by OVERKILL - 01/25/20 10:10 PM
'12 Civic burning oil after switch to M1
by sr20detfwd - 01/25/20 09:33 PM
Wix/NAPA Gold and M+H
by Uphill_Both_Ways - 01/25/20 09:06 PM
New seafoam oil stabilizer at AZ
by Chesterr - 01/25/20 08:13 PM
In 3 hours - 730 days and counting
by OVERKILL - 01/25/20 08:12 PM
Pig Parker!
by dishdude - 01/25/20 07:58 PM
NGK Conventional vs. Ruthenium Plugs
by doitmyself - 01/25/20 07:58 PM
Container or funnel?
by Philthy_Phil - 01/25/20 07:24 PM
AC Delco filters at Amazon as little as $1.07
by jayjr1105 - 01/25/20 06:22 PM
Excessive moisture in oil
by mb32 - 01/25/20 05:47 PM
Cover for Jeep + Trailer
by kehyler - 01/25/20 05:34 PM
Low VI gear oils
by dparm - 01/25/20 05:28 PM
kwashabcp, ronster, BackToReality, Scopeman, M635_Guy
70527 Registered Users
27 registered members (Bookmaker, bachman, blufeb95, brages, bbhero, BlakeB, 4 invisible), 921 guests, and 23 spiders.
Topics300,571
Posts5,178,490
Members70,527
Page 1 of 7 1 2 7
Motor oil university 106 #4079727 04/26/16 03:19 AM
F
FordCapriDriver Offline OP
F
On chapter 6 of the motor oil university called "Personal preference" it says that No conventional Xx-w50 oils are reccomended because apparently they are all too thick at startup, does this refer to Straight 50 weight oils? 20w50 oils? , if it does refer to 20w50's for example this sounds pretty ridiculous to me since it seem to claim that they are too thick regardless of the application or anything else.
Discuss
1975 Ford Capri II Ghia 3000 V6 - Repsol Elite Super 20W-50
1988 Ford Escort XR3i Cabrio - Repsol Elite Super 20W-50
Re: Motor oil university 106 [Re: FordCapriDriver] #4079731 04/26/16 03:38 AM
Silk Offline
Where does the person who wrote Chapter 6 live? That could be the clue....
1987 BMW R65 - Penrite VTwin 20-50
2005 Nissan Expert - 5W-30 Castrol Edge
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
Re: Motor oil university 106 [Re: FordCapriDriver] #4079736 04/26/16 03:50 AM
F
F
i think in Florida due to all the Florida related questions in which case a 20w50 would probably be just fine to use during most of the year in the proper application ofcourse
Re: Motor oil university 106 [Re: FordCapriDriver] #4079743 04/26/16 04:01 AM
Shannow Offline
It's a meme that 101 and a few other posters regurgitate.
The premise is that engines are built for "10" (that's in 101, and in spite of questioning the author he hasn't come out with any evidence to that end.)
The premise is also that at lower temperatures the oil is "too thick" to do it's job, and that the ideal lubricant must be "10" from the time the engine is started to the time that operating temperature.
That's incorrect, as in the cooler (warmup) temperatures before the additives kick in, viscosity is all you have to keep wear at bay (or some of the newer novel additives).
It's the reason that the industry standard wear test (sequence IVA, and soon to be replaced by IVB) hold the engine and oil at 65C or thereabouts, as that's where the most valvetrain wear occurs.
The designers of the test claim that the test has no discernable preference to viscosity...if 101 was correct, then the thinnest, highest VI oils MUST perform better than these "too thick" oils.
As to the author of 101, he could run SAE30, which has no "W" rating and not suffer the effects of "too thick" when cold.
Re: Motor oil university 106 [Re: FordCapriDriver] #4079753 04/26/16 04:33 AM
A
alcyon Offline
A
101 is wrong on many things. anyway regarding what shannow said "It's the reason that the industry standard wear test (sequence IVA, and soon to be replaced by IVB) hold the engine and oil at 65C or thereabouts, as that's where the most valvetrain wear occurs."
So only wear at the valvetrain at the warm up phase is cause for concern? At this temp range 60 - 70C, wont affect bearings and rings ?
Kyosho Optima Mid SWB, LWB and Lazer ZX
1991 Proton Saga 1.3S SOLD
1989 Toyota Soarer GT Twin Turbo L
1985 Kuwahara Survivor
1992 Robinson Pro
Re: Motor oil university 106 [Re: FordCapriDriver] #4079758 04/26/16 04:47 AM
Shannow Offline
alcyon,
in order to be a standard, the results must be easily discerned and be repeatable...and be obtained in a reasonably short timeframe.
The the industry standard test uses cams and valvetrain rather than rings and bores, or shafts and bearings...it doesn't mean that only these items were.
I'm (presuming) that the ability to replace cams and valvetrains fairly quickly on an engine, while leaving the bottom end untouched makes the test a heap cheaper/quicker than a full tear-down.
Re: Motor oil university 106 [Re: FordCapriDriver] #4079776 04/26/16 05:05 AM
M
mjoekingz28 Offline
M
Isnt Florida kind of related to Spain? When I vacation there I sometimes hear Spanish accents and see French/Spanish type cities and landmark type objects. 20w is probably not going to be a problem in some vehicles above freezing temperatures. Below freezing, you probably want to have a 10w in the sump.
Re: Motor oil university 106 [Re: FordCapriDriver] #4079795 04/26/16 05:40 AM
Y
yvon_la Offline
Y
My Enzo Ferrari calls for the Shell Helix Ultra racing 10W-60 but I have used the Castrol Syntec European Formula 0W-30. This is different than the easy to find plain 0W-30 Syntec
as from my point of view? his idea work. baught a brand new car and used his concept ,never had issue with my car !
Truck driver
Nissan versa note s 2014 total classic 5w30(qc.ca) drivework oil filter
Re: Motor oil university 106 [Re: FordCapriDriver] #4079803 04/26/16 05:49 AM
Shannow Offline
yvon_la, wow to change a post between initial and edit...I nearly responded to the 10psi/1000RPM post...wouldn't I have looked silly.
Re: Motor oil university 106 [Re: FordCapriDriver] #4079816 04/26/16 06:01 AM
A
alcyon Offline
A
the 10psi per 1000rpm thinghy seems unrealistic to me. if you rev say above 3000rpm, the heat in the oil will rise and the viscosity will go down, so will oil pressure, I bet with a 0W-20 he will achieve max oil pressure at 7000rpm,albeit only for a minute or less. If he keeps the revs at 7000rpm for a few minutes, I bet the oil pressure will start dropping drastically, with a drastic increase in oil temps.
1992 Robinson Pro
Re: Motor oil university 106 [Re: FordCapriDriver] #4079836 04/26/16 06:25 AM
Shannow Offline
10psi per 1000RPM was an old small block (chev, ford, chrysler) rule of thumb for "adequate" oil supply volume to get the job done.
It doesn't define, nor provide lubrication.
101 states that the pressure is lubrication, then later that it's the flow, not the pressure.
It's neither.
With an adequate volume of oil supplied, the bearings will lubricate themselves, and draw from that supply most adequately...thicker oil they suck less oil out, and the backpressure goes up.
Piston squirters rely on pressure/density to provide flow...more pressure, more flow, more cooling.
As to your premise that a few minutes at 7,000RPM will result in lots of oil heat, and viscosity drop, I concur.
Re: Motor oil university 106 [Re: FordCapriDriver] #4079849 04/26/16 06:43 AM
R
Rolla07 Offline
R
Rarely ever a need for such a thick oil... not sure but alot of cars in Florida run 0w20 and have no oil related issues.. so not sure what your point is. They can run a thick oil, but whats the point? This argument of thick vs thin could go on forever. You cant prove thin oil to cause issues and it is most recommended by manufacturers here, so prove how they are doing it for CAFE or for claiming better mileage? You would have a point if there were multiple engine failures due to the use of oil that is, "too thin". If thin works as good as thick, and the only benefit being you save gas money using thinner, wouldn't that mean thin is a better option?
I do see you said in the proper application.. which I agree with.. but not much applies for 20w50 oil, at least when it comes to automobiles.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
2015 Toyota Venza Parisian Blue Pearl 25k miles
TGMO 0W20 & OEM filter
Re: Motor oil university 106 [Re: FordCapriDriver] #4079854 04/26/16 06:49 AM
M
Miller88 Offline
M
If a 20w-50 is too thick, a straight 50 (if such a thing is even available) is going to be way too thick.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Motor oil university 106 [Re: FordCapriDriver] #4079875 04/26/16 07:10 AM
F
F
i agree with modern oil technology very few cars, even classics "need" a 20w50, i run it mostly to keep oil consumption down, my owner's manual specs 20w50 for hot climates but in the 70s a 20w50 would've likely quicly sheared to a 40wt due to fuel dilution and other things, my engine would probably run just fine on a quality 5w30 or 5w40 synthetic with all the right additives for an older engines like zddp etc...
Re: Motor oil university 106 [Re: alcyon] #4079893 04/26/16 07:30 AM
4
440Magnum Offline
4
It is exactly what a new-from-factory 1956-1996 Chevy smallblock v8 did, so it became "the rule." Its that simple.
Despite the fact that the majority of other engines (even other GM engines) don't act quite the same way.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 XJ 4x4 4.0/AX15, '14 WK2 4x4 3.6/8HP
Page 1 of 7 1 2 7
