ATF brown color, smells sweet; Lexus 5pd SC430
France
Hi,
I bought a high-mileage (100k miles) Lexus SC430 on the cheap. It ran well during test drive.
After I got it, I noticed that the transmission has been overfilled. From service records, it seems to have been this way since 70k (5 years). I did one drain & refill on Friday and one yesterday (personality default, couldn't wait).
When I checked the car before purchase, I only looked at the fluid on the dipstick, and it was dark, but still reddish. After I drained it, I realized how dark it actually was (see image).
It's dark brown. The smell is sweet.
How bad is it?
Also, I was lazy and didn't bother to jack up the car. Unfortunately, I stripped perhaps the pan or the bolt when putting it back. Now it won't torque. I'll bring it probably to Toyota in a week's time (for a drain and refill and, if unlucky, pan replacement).
This transmission uses Toyota Type IV, which is red and doesn't have a sweet smell. I think it actually smells a bit like gear oil when new.
When people say 'burnt' smell, what exactly does 'burnt' fluid smell like? Is the sweet smell 'burnt'?
Also, since I had a look at the color of the fluid, I paid extra attention to the gear shifts. I noticed that sometimes the car rushes from 2nd to 3rd when very light on the gas. Using manual shifting, from 2nd to 3rd it would thump. Other shifts are unnoticeable. Also, when picking up speed very slowly, the car doesn't really stay long in 2nd. It's like 1000 rpm -> 1700 rpm in 1st -> 1500 - 1700 in 2nd -> 1000 - 1700 in 3rd...
Is the 2nd slipping?
I'm evaluating whether to sell this car on.
Thanks in advance!
In my GM service manual, Dexron 3 automatic transmission fluid brownish color is normal if it does not have a burned smell. That's about all I know about it.
If I didn't know any better judging from the picture it looks like someone might have filled it with oil.
It just looks old. 100,000 miles isnt "high mileage."
It is hard to judge ATF colors on the computer.. I am betting it looked slightly better in person?
If it was engine oil, it wouldn't have that sweet smell either.
Actually it did look like engine oil a bit. Also, when I say it smelled sweet, it did smell like some traditional engine oil (none synthetic).
So maybe the question is this: What exactly does burnt fluid smell like?
While my two drain and refills have changed almost half of the fluid, it still has that 'sweet smell' that is different from the fluid I poured in (which smelled like gear oil a little bit, but not that bad).
I also just found out that it's leaking from the stripped drain bolt. I originally plan to park it for a week before going to the dealer. Maybe I'll make time this week if the leak is serious (no more Type IV in hand to top up). Dealer is close, but probably won't have the parts to work on it. (the pan -> hopefully not needed).
If its the original Mobil 3309 (Toyota T-IV), it is a mineral ATF. That might be what you're smelling.
Burned ATF smells how it sounds. You'd be able to tell.
Now it smells like gear oil though? That stuff isnt sweet at all.
Once your gasket is fixed, you should do a cooler line flush and get as much out as possible.
Maybe all it needs is a new washer. The pan should be dropped and filter changed if it has one.
They sell a drain plug to use after the hole is stripped. At least for engine drain pans. The dealer will probably install a new pan.
Does the drain plug take a large Allen wrench to remove it? You really should not lean on that Allen wrench.
As above, that looks normal in the pan for neglected 100k fluid.
"Sweet" smells sweet, "burned" smells burned. This is not rocket science. It is difficult to judge color just from a dipstick; it leaves impurities behind in the pan. That is why you do a drop/blot test and not just gaze lovingly at the dipstick like a rube at a carnival. See this thread:
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=59757&page=all
This is troublesome, also:
I assume you mean after either fixing it or fully disclosing any problem. Just covering up stuff and sticking it to the next guy is not really what I view as kosher.
The 2nd-3rd issue you describe is not "slipping" by any stretch. Change the fluid completely and then evaluate.
How bad is it?
Thanks for the picture .... and this is my take:
The smell is sweet ..... hence it's not 'burnt' smell , as 'burnt' smell is unpleasant to most people whose first reaction would be to keep sample at a certain distance apart.
Looking at the picture of brown colored oils as provided, and your comment oil on dipstick is dark but still reddish .........
the ATF is oxidised no doubt about it, but is still performing it's basic function ..... more so after D&F's ...........
this auto trans should be good to go.
JMHO
Maybe it's the monitor I have but even the fluid running down the side of the drain pan "looks" like spent oil to me. I would definitely do a line exchange or a few fluid extractions via the dipstick to try to get as much of that old spent fluid out.
How bad is it?
JMHO
I agree with Zeng....I'd get an oversized drain bolt (rather than change the whole pan which is pricey), change the filter and get another 100K out of that beauty....
The sweet smell is just how some ATF fluids are. When I drained ATF from my G37 only after 6,000 miles since transmission was flushed with new fluid by dealer at 15,000 miles, the drained ATF had a sweet smell. In fact, it smelled like cherry soda.
I wouldn't worry too much about color at this point. Just refill with quality synthetic ATF that meets the spec and drive on. Not long ago in Blackstone's newsletter they showed an ATF UOA for a Toyota with 264K miles on it where ATF was never changed. The UOA showed on the order of 1,500ppm in iron wear and transmission was still in working order.
In your case the transmission was serviced at 70K. That's a big plus already.
That Blackstone report is from my Rav4. My wife will be thrilled her Rav is "famous". The OP's fluid looks exactly like the ATF in my older Toyotas looked at 100k miles. I've put another 200k miles on the Rav with that ugly brown fluid. Truth be told, the Rav is at 299,500 miles today and it slips a little bit going from 1st to 2nd gear before it gets warmed up. I don't think it's going to make it to 400k miles.
Since that Blackstone report, I've pulled out 3 quarts of ATF and replaced with T-IV and half a bottle of Lubegard.
This is one of those threads that superficially seems to ask a mechanical question, but in fact, what you're after is reassurance.
Regardless of the quality of the ATF or the shift points (they're set up to get into high gear ASAP for fuel consumption and in a Lexus, "smoothness", or overall NVH), you;ve got what you;ve got. I'd suggest you flush and refill with correct amount and type of ATF and filter and be done with it. You can wring your hands and fret all you want over what might have happened or what it means, but it won't change anything.
Just as an aside, I always marvel at guys who buy used cars largely b/c they proudly claim they got such a "Great deal", only to discover to their dismay that maybe it wasn't such a great deal after all. Remember, if something is too good to be true...
Thanks a lot for the comments and information.
Yes, I was partially after reassurance, but also for information to decide on whether this is a keeper. As for disclosure, if I sell there will be a technical inspection, and it would be sold without warranty (or to a used car dealer). Currently, the only thing is that it once had brown fluid inside.
As for the smell, 'gear oil' is what I think the new fluid a Toyota dealer sold me smells like, but much, much less repugnant. It was in a bottle like this [link] http://www.ebay.co.uk/itm/Genuine-Toyota...r-/221568606203 [/link]
As for the pan / bolt, it's a 14mm hex head. I guess it's the pan that's stripped, but if lucky it's the bolt. I actually felt the broken thread. I don't have any fluid now, so I don't plan on doing another D&RF. It's leaking (slowly), but the bolt is finger tight and hopefully fine to drive to the dealer 25 km away. I may top up a little 3309 before leaving. Here, Type IV is only available at the dealer, but 3309 is everywhere.
I think probably I'll just go to the dealer, because if I couldn't get an oversized plug in I'd need a toll on top of a pan. The pan is $120 on the net, so I guess max 200 euro at the dealer, maybe less. The toll is 150 at least. If lucky, it's just the bolt. The labor cost should be the same as dropping the pan and refilling.
Of course, I take the risk of the bolt backing out on the way, but I have a feeling it's not going anywhere (it just spins now if I try to tighten it beyond finger tight and after half a turn becomes finger tight again).
Just an update:
I got a 'rendez-vous' on 10 May, and finally got the car back today. They charged me 567 euros to change the oil pan. - And they used the wrong fluid - WS!
They insisted that it is the 'new' fluid. I had to drive to another Lexus dealer to get another quote. I also called this one later. They called Toyota. Finally, they've agreed to change to Type-4 next Tuesday.
Thank god I'm leaving France soon.
Since you just changed the fluid it takes some time for the transmission to re-adjust to the new fluid. I think the shift points are electronically controlled, and the new fluid will work different than the old fluid, and the computer needs to adjust.
It happened to me when I changed my original fluid at 100k, but now the transmission shifts at the same points as before. It used to stay in gear for too long right after I changed my fluid, but now it shifts like normal.
100k on original fluid is usually OK.
