Old Tundra Headlamp Upgrade
by JeffKeryk - 01/21/20 09:41 PM
MOVIE: Dr. Dolittle
by Kira - 01/21/20 09:34 PM
Oil weight and Oil Grade
by Snagglefoot - 01/21/20 07:11 PM
Which air filter for RAV 4 Hybrid
by NH73 - 01/21/20 06:44 PM
Finding a good "cold weather" vehicle?
by Vern_in_IL - 01/21/20 06:15 PM
Bough NGK Ruthenium sparkplugs
by cronk - 01/21/20 06:07 PM
HF 30% Off $10 and Under
by TheLawnRanger - 01/21/20 06:02 PM
Stolen Battery-New one on Me
by bunnspecial - 01/21/20 05:29 PM
2006 Acura TSX Buying Advice
by maverickfhs - 01/21/20 04:35 PM
Castrol GTX Diesel 15W-40, CK4
by HDoilDude - 01/21/20 04:30 PM
Combo of P0068 and P307A
by Alfred_B - 01/21/20 04:30 PM
Are the plastic battery trays necessary?
by littlehulkster - 01/21/20 03:18 PM
Amsoil ATV/UTV Powertrain Fluid
by IowaFord - 01/21/20 02:13 PM
Motorcraft FL500s 3,630 miles.
by mpgo4th - 01/21/20 01:36 PM
Xcel Class Action Suit
by John_K - 01/21/20 12:33 PM
RV Freightliner Cummins ISB 6.7 oil question
by 1978elcamino - 01/21/20 11:48 AM
Why I became a pilot and not a doctor...
by jetman - 01/21/20 10:52 AM
Wrong oil or not ?
by M119 - 01/21/20 10:48 AM
IowaFord, Origami99, reylafo, PastPresMike, RedBeard83
70497 Registered Users
101 registered members (alphadog, 69GTX, A310, 2003f7, 4WD, 8 invisible), 2,445 guests, and 37 spiders.
Topics300,411
Posts5,175,228
Members70,497
Page 1 of 3 1 2 3
What fuel additives do you use for ethanol? #4072319 04/18/16 10:10 AM
I
Islandvic Offline OP
I
I run 93 octane for all my 2&4 cycle small engines. I keep my fuel in "No Spill" brand containers.
http://nospill.com/Products.html these fuel cans are the only ones I will buy now.
I first used Sta-Bil additive (red), now I use their Sta-Bil Marine version (blue). The blue version supposedly has more concentrated additives for ethanol, storage, and system cleaning. It costs more than the red version, but it treats more gallons per oz.
Ethanol free fuel is not readily available where I live.
What additives (if any) do you guys run for your small equipment?
Re: What fuel additives do you use for ethanol? [Re: Islandvic] #4072329 04/18/16 10:26 AM
Donald Offline
I use blue Stabil for the 4 cycle OPE and premix for the 2 cycle.
2015 Ford F-250 w/Powerstroke
Re: What fuel additives do you use for ethanol? [Re: Donald] #4072340 04/18/16 10:37 AM
M
motor_oil_madman Offline
M
I don't use anything. Not going to spend $30 buck for a bottle of stabil.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: What fuel additives do you use for ethanol? [Re: Islandvic] #4072348 04/18/16 10:49 AM
R
rslifkin Offline
R
If the fuel is going to sit for a while, it gets sta-bil. If it's not going to sit for all that long, nothing. The only big concern with storage is to avoid condensation in the tank / container holding the fuel.
1998 Jeep Grand Cherokee 5.9 Limited with lots of mods (225k miles, bought with 100k in 1/2010)
Rotella T6 @ 6k OCI
Re: What fuel additives do you use for ethanol? [Re: Islandvic] #4072368 04/18/16 11:15 AM
R
racer12306 Offline
R
I just use the normal dose of marine stabil for regular fills but over the winter I'll super dose it, like 4x the dosage.
I normally use Trufuel for my trimmer because I just don't burn enough gas through it to mix it up.
16 Ford Focus/2.0/6A
04 Dodge Neon SXT/2.0/MTX
17 Chrysler Pacifica/3.6/9A
Re: What fuel additives do you use for ethanol? [Re: Islandvic] #4072388 04/18/16 11:28 AM
I
I
Rslifkun, in NY, is most of your available fuel 10% ethanol or w/ lower amounts or non-ethanol?
Madman, I find 32oz of Marine Sta-Bil locally for $20-22. Red is few bucks cheaper.
Donald, which pre-mix brand do you use? My co-worker and I were discussing premix fuel for our 2-cycle equipment a few months ago, but I never started using it.
I started using it after my 3 month old Echo hand held leaf blower started having problems. The dealer (authorized Echo service center) took apart/cleaned/reassembled/adjusted the carb. They said it was from bad gas. Tech said they advise all customers and especially their commercial lawn accounts to use some type of stabilizer and/or enthanol additive if all fuel, even if fuel was to be used that day.
He explained (although this may be incorrect but sounded plausible to me) that with our high humidity, the ethanol draws in moisture even while in the underground storage tank at the gas station.
The gas I had used was less than week old and stored in a newer fuel can w/ no visible contaminates. I dumped it out, got fuel from another service station and started using Sta-Bil red.
That was in 2010 and my Echo Blower Weed Trimmer have ran like new since.
May have been a fluke and the Sta-Bil has just been a placebo.
Re: What fuel additives do you use for ethanol? [Re: Islandvic] #4072430 04/18/16 11:56 AM
Donald Offline
I buy premix at HomeDepot, I think its TrueFuel but thats only a guess. I probably use 2 - 3 QTs of premix a year. The cost is low enough to prevent carb problems. I use the 2 cycle implements sporadically. So it might be a month or two between uses of my backpack blower, maybe a year for the chain saws.
Re: What fuel additives do you use for ethanol? [Re: Islandvic] #4072498 04/18/16 12:58 PM
R
RedOakRanch Offline
R
You can add water, that will pull out all the ethanol, then drain off the water and enjoy your pure gas! I won't use ethanol gas in small engines, I buy AV gas at the local airport.
1994 Ford Crown Vic 207k-Frankenbrew 0w20,30,40!
2005 Chevy 1500 Crewcab 4X4 180k-BC 0w30 $2/qt
2016 Outback 2.5 Limited 60k-shop brand?
Re: What fuel additives do you use for ethanol? [Re: Islandvic] #4072515 04/18/16 01:29 PM
P
Pop_Rivit Offline
P
I always add StaBil to my stored fuel. Some of my small engines or the show tractor only get used once or twice each year, and I never know exactly how much fuel I'll use. I currently have about 10 gallons left from my fall fill last October (I didn't need to plow the drive much this winter). I keep a 30 gallon wheeled fuel tank on hand along with 3 tractors that take 9 gallons each, in addition to several other small engines.
I can go out and start any engine that I have without a single issue, and I have never had a fuel related issue in the 30+ years I've been using E10. And to be fair, I sometimes store fuel long enough that I would add StaBil even if I made the choice to use non-E10 fuel.
And I'll add to my information above that I've never had to go to the airport to get some sort of magic fuel, nor have I ever dumped water into my gasoline in some misguided attempt to create non-E10 fuel.
Re: What fuel additives do you use for ethanol? [Re: Islandvic] #4072540 04/18/16 01:59 PM
Dyusik Online Content
Online Content
I just use ethanol gas. If I'm going to store(bike) for longer than a month I just use up the gas and fill the tank with 100% gasoline. Never issues, never needed anything, no hard starts. Simple as that.
95 Cherokee 190K DELO XLE 10W30, XG8
04 YZF-R1 20K Frankenbrew 20w50ish, XG7317
14 RX450h 50k STP SYNHM 10w30, WIX 57047
18 RAM 3500 8k DELO SDE15w40, DBL7349
96 Cherokee
Re: What fuel additives do you use for ethanol? [Re: Islandvic] #4072563 04/18/16 02:38 PM
V
vitez Offline
V
The best product I ever used was PRI-G.
http://priproducts.com/retail-consumer/
It actually works at a 2000:1 ratio, yest two thousand to one. But I haven't found it in Canada for years.
I use Seafoam now. I pour 2oz per gallon into a jerry can the moment I fill it for 2 stroke equipment and 1oz per gallon for 4 stroke stuff, so all of my outdoor power products are using Seafoam treated gas all the time. I find Seafoam works better than Sta-bil.
I have CDO. It's like OCD except in alphabetical order like it should be.
Re: What fuel additives do you use for ethanol? [Re: vitez] #4072598 04/18/16 03:28 PM
Donald Offline
PRI-G claims it can bring back old gas to new. Nothing can short of re-refining it. Given that claim, I avoid PRI-G all together.
Re: What fuel additives do you use for ethanol? [Re: Islandvic] #4072626 04/18/16 04:17 PM
H
henni Offline
H
We use 1 gal of StaBil Marine, price comes to 15 for 32oz
http://www.amazon.com/gp/product/B002PZ1ISG/
Re: What fuel additives do you use for ethanol? [Re: Islandvic] #4072714 04/18/16 06:15 PM
M
Merkava_4 Offline
M
The Sta-Bil helps a little bit, but the flexible diaphragms get stiff after awhile from exposure to ethanol. You just gotta plan on replacing them once a year.
Re: What fuel additives do you use for ethanol? [Re: Islandvic] #4072872 04/18/16 08:49 PM
O
orcldba Offline
O
Used to use sta-bil red and 90/10 gas. Over a year ago I switched to non-alcohol gas (premium) for everything, and still use sta-bil as the gas may be in the can or the tank for 2-3 weeks while it's being used.
Have never had an issue, and it's worth the insurance cost t me.
Page 1 of 3 1 2 3
