I came across this oil when picking up Rotella T at a local independent distributor. I hadn't thought about URSA for years, as I last remember using it in my old 98.5 24V Cummins. It was the last CI-4+ oil I could find when everything switched to CJ-4. I was holding out until there was more real world experience with CJ-4 in pre-2007 engines, but at least now we know it was a moot point.
Anyway, I searched BITOG and found essentially nothing about URSA. Does anyone use it? It's specs, price, and marketing make it look like a lower add-pack slightly thinner conventional HDEO vs DELO LE. It's numbers are very close to Rotella T but with a lower TBN of 8.1. URSA is a holdover from Texaco, and AFAIR when I used it it was still labeled Texaco. It's only $7 cheaper per pail than DELO LE here, so not a big deal, I'm just curious.
