Originally Posted By: dfarr67
Well, it's in already- if it doesn't like it....it'll be an expensive trans flush. Using Severe Gear 75-90 in everything else on the truck. On a side note- for manual hubs- what is the best grease to repack?
I strongly suspect come next winter you will want to change it out because:
1) It doesn't have any friction modifiers for the synchro's,
2) It is thicker than a dedicated MTF.
3) It is a differential lube, not an MT lube.
