New addition to the stable is a 2009 VW Routan Minivan which is a rebadged Chrysler T&C with the 3.8L engine. History of the vehicle; 47k miles and run in an area with lots of salt on the roads up in the mountains so rust is an issue. Owned by a guy who passed away and I bought it from his daughter. She had lots of work done late last year on a driveablity issue where it was cutting out at 4100 RPM. I saw the report and they were troubleshooting the Camshaft Position and Crankshaft Position sensors but couldn't fix it so finally ended up replacing the PCM with apparent success. They also noted they had tested the alternator and saw some erratic behavior, but apparently didn't replace the alternator.
I bought it in January and the Van drives well but has thrown a DTC several times for evaporative emission system and even even had a "Loose fuel cap" message appear on the dashboard. I've replaced the fuel cap but still have that DTC pop up occasionally. Yesterday it threw P0340 and P0344 while on a freeway trip (Camshaft Position Sensor and Camshaft Position Sensor Intermittent). Hummm... those were diagnosed previously so now I'm suspicious.
The last piece of information is the van failed the charging system/battery test on my new scan tool. Basically the voltage hangs around mid 12 volts and the test wants it to go up when you rev the motor... but it stays low around 12 volts. However, the van seems to start and drive normally with no apparent signs of slow cranking or anything like that.
Do you guys think that these DTC's may be due to a failing alternator or perhaps old battery. I'm not sure how old the battery is in the van. Thoughts/advice?
