Originally Posted By: RusskiBoSS
Don't use it. Their quality control sucks balls big time. Their bottles are always leaky before they even reach autozone to be put up on shelves. Recently STP SAE30 have been all terminated in my region of autozones because while the sticker said SAE30 - there was actually something else in the bottles. Again sucky quality control. And also I know a mechanic who got some ATF+4 fluid made by STP for his Dodge Caravan. Changed filter, poured the STP Trans fluid in, and after a mile transmission stopped shifting. He Drained it, refilled with Castrol ATF+4, and transmission came back to life. Hopefully it gives you an idea of how bad the STP Quality Control is. I see unhappy customers on daily basis at my autozone.
The STP ATF+4 is licensed ATF+4. Formal approval by Chrysler. And ATF+4 isn't just a spec; they go much further than that, only allowing a specific formula from a specific supplier.
The QC of all licensed ATF+4 is done by a shell company hired by Chrysler, called the Center for Quality Assurance.
Those Caravan transmissions suck no matter what you put in them. Redline C+ is supposed to be better, even though it isn't licensed by Chrysler. Redline C+ uses the same add pack approved on licensed ATF+4, but with a Group V base stock (Chrysler's ;licensing program only allows a specific group III base).
