Shutting Down Threads Because of "Speculation"
by e55amgbenz007 - 02/18/20 10:10 AM
Toyota Sienna
by cb_13 - 02/18/20 10:05 AM
Larger fuel filter on Riding mower?
by dedonderosa - 02/18/20 10:03 AM
Castrol edge 0w40
by VQLT - 02/18/20 08:32 AM
Scrap value of this catalytic converter
by atikovi - 02/18/20 06:10 AM
How drunk do you have to be to do this?
by dishdude - 02/17/20 11:09 PM
At least they show you
by Jake777 - 02/17/20 10:04 PM
Ryan Newman update
by P10crew - 02/17/20 09:17 PM
Thoughts on 2015+ Kia Sedona?
by 92saturnsl2 - 02/17/20 09:16 PM
Quiet riding tire
by wolf_06 - 02/17/20 08:27 PM
Where did the Ryan Newman thread go??
by P10crew - 02/17/20 08:02 PM
2013 FX4 repair.
by marine65 - 02/17/20 07:36 PM
New gaming build shutting down on Metro 2033
by Cujet - 02/17/20 07:09 PM
Snapon
by P10crew - 02/17/20 06:51 PM
Conventional or Synthetic
by charmer37 - 02/17/20 06:49 PM
Jeep Wrangler 3.0L Diesel
by HighbrowHillbill - 02/17/20 06:36 PM
94 B4000 overheat Eureka
by HyundaiAbuser - 02/17/20 05:48 PM
PP Euro 5w40 SN Plus formulation VOA
by BurntMusic - 02/17/20 04:35 PM
tpap, ratt, jeffreytmann, boureesub, Bayrim
70737 Registered Users
102 registered members (aquariuscsm, ABerns, andreigbs, 28oz, allepunta, 11 invisible), 2,107 guests, and 22 spiders.
Topics301,604
Posts5,198,955
Members70,737
TGMO 0w20, 6.5k, 2014 Honda Odyssey, 41,385 #4062160 04/08/16 10:00 AM
SF0059 Offline OP
Winter months probably account for fuel dilution. Everything else looks good. This is with TGMO 0w20, FU, and Liqui-Moly. Replaced it with 3 quarts of TGMO and 2 quarts of M1 0w40. Caterham blend!
2014 Honda Odyssey EX-L/RES: 54K mi, M1 0w-40 & FU, VCMuzzler V2
2017 Mazda 6 Touring 6MT: 22k mi, M1 AFE 0w20, OEM Filter
Re: TGMO 0w20, 6.5k, 2014 Honda Odyssey, 41,385 [Re: SF0059] #4062355 04/08/16 01:33 PM
T
tig1 Offline
T
The two qts of 0-40 are for what purpose?
2007 Ford Fusion 253,000 miles
M1 5-20HM
2017 Ford Fusion 86K
M1 0-20EP
M1 ATF and M1 LV HP ATF
M1 10-30 in all OPE
MC filters
Re: TGMO 0w20, 6.5k, 2014 Honda Odyssey, 41,385 [Re: tig1] #4062414 04/08/16 02:30 PM
SF0059 Offline OP
Well, first and foremost because I have a ton of in my stash left over from my Audi.
Second, I wanted to give the Caterham Blend a try for myself. I found this explanation of the blend from back in the day.
Originally Posted By: A_Harman
The Caterham Blend is a blend of Mobil 1 0w40 and Toyota Genuine Motor Oil 0w20. It is prized for its high viscosity index, and somewhat enhanced additive package over Mobil 1 0w30 Advanced Fuel Economy. M1 0w30 to us spec-hounds on BITOG is somewhat disappointing because its viscosity index is actually lower than garden variety M1 5w30. Consequently, it has higher viscosity during startup down to freezing temperatures. By blending M1 0w40 with TGMO, you end up with a 0w30 with higher viscosity index than M1 0w30 AFE, and since TGMO is produced by Mobil, there is minimal concern of the additive packages between the two oils clashing.
Re: TGMO 0w20, 6.5k, 2014 Honda Odyssey, 41,385 [Re: SF0059] #4072662 04/18/16 05:10 PM
P
Patrick0525 Offline
P
What was time period of the oil change? How many months?
2014 Toyota Venza 2GR-FE 96K mi
2009 Lexus ES350 2GR-FE 49K mi
Fram Ultra filter XG9972
TGMO or Idemitsu Zepro 0w20 (winter)
PP 0w20 (spring/summer/fall)
Re: TGMO 0w20, 6.5k, 2014 Honda Odyssey, 41,385 [Re: Patrick0525] #4073189 04/19/16 08:24 AM
camryrolla Offline
If your intention is extend OCI, TGMO 0w20 showing a TBN of 2.7 after 6500 mi seems like a weak oil for this Honda engine. It looks like 8000 mi OCI is the limit for this TGMO oil. Try M1EP 0w20 and you can easily go 10K OCI with this Honda engine.
'11 Camry 2.5L 170K mi
'07 Corolla 1.8L 220K mi
Always Fram XG filter.
Re: TGMO 0w20, 6.5k, 2014 Honda Odyssey, 41,385 [Re: camryrolla] #4076116 04/21/16 11:06 PM
dmiko Offline
Does this engine have the VCM system? Wonder if issues that plagued it in terms of premature cam wear were worked out.
Re: TGMO 0w20, 6.5k, 2014 Honda Odyssey, 41,385 [Re: Patrick0525] #4100739 05/19/16 06:31 AM
SF0059 Offline OP
Sorry Pat, just saw this. The oil was in the van about 5 months.
Re: TGMO 0w20, 6.5k, 2014 Honda Odyssey, 41,385 [Re: dmiko] #4100758 05/19/16 06:57 AM
SF0059 Offline OP
To be honest, I don't trust the Honda VCM V6 enough to extend the OCI. The engine is well known for chewing up oil. I may play around with the brand, but I will most likely stick to the OLM for the foreseeable future, especially while it is still under warranty. My reasoning behind getting the UOA is to track wear in the engine because of the track record of the design. I refilled with a blend of TGMO and M1 0w40, so we'll see how it does with a light 0w30.
Some people say it has been ironed out, others say that it is still a problem. Either way, I'm going to baby it and keep a watchful eye on it through UOA samples.
Re: TGMO 0w20, 6.5k, 2014 Honda Odyssey, 41,385 [Re: SF0059] #4100931 05/19/16 10:47 AM
B
bulwnkl Offline
B
These numbers are very similar to what my Honda Ridgeline's J35 engine showed with both Lubrication Engineers' 5W20 and Pennz Plat 0W20. Currently I'm evaluating M1 AFE 0W20, and iron and aluminum numbers are both way down. So, if you like to see smaller numbers, maybe try M1 AFE 0W20.
FYI, the Ridgeline's J35 does _not_ employ VCM.
I don't recall whether I put the recent AFE UOA on here or not.
I use speech recognition frequently. Please excuse any consequent grammatical or typographical errors.
Re: TGMO 0w20, 6.5k, 2014 Honda Odyssey, 41,385 [Re: bulwnkl] #4103874 05/22/16 07:31 PM
SF0059 Offline OP
Thanks for the tip! I've been thinking about moving away from TGMO since it is pricey and it doesn't seem to be the magic elixir I hoped it would be for the VCM V6. I can't argue with the price of M1 AFE either!
Re: TGMO 0w20, 6.5k, 2014 Honda Odyssey, 41,385 [Re: SF0059] #4104104 05/23/16 06:01 AM
T
Trav Offline
T
VCM-2 are sometimes problem engines depending on the conditions they are operated under, they do much better on 0w40.
In fact this engine is spec for 0W-40 A3/B4 in other parts of the world, it is not exclusively a xw20 engine and seem to have more engine issues when run on that grade of oil.
Re: TGMO 0w20, 6.5k, 2014 Honda Odyssey, 41,385 [Re: Trav] #4104216 05/23/16 08:44 AM
P
Phishin Offline
P
I've seen these Honda V6's do very well on A3/B4 oils. If I had one, I wouldn't run anything thinner than straight M1 0w40.
2018 Chevy Silverado 3500HD 6.0L Gas: RLI 10w30
2010 Accord-LX K24: MaxLife 5w30 + Torco MPZ
2014 CR-V LX K24: M1 0w30
Re: TGMO 0w20, 6.5k, 2014 Honda Odyssey, 41,385 [Re: Phishin] #4104447 05/23/16 01:26 PM
T
Trav Offline
T
Yes, these and the Nissan VQ engines really seem to run smoother, quieter and have less oil consumption on 0w40.
Re: TGMO 0w20, 6.5k, 2014 Honda Odyssey, 41,385 [Re: SF0059] #4104735 05/23/16 08:08 PM
dan_erickson Online Content
Online Content
Silly question about the J35. Can I just run a quality 5w30 synthetic in this my Accord and have no bad effects. It would be easier to have both cars on the same oil and 5w30 is stocked better at stores.
15 Accord Coupe EX-L V6 Navi
Castrol Magnatec 0w20
Re: TGMO 0w20, 6.5k, 2014 Honda Odyssey, 41,385 [Re: SF0059] #4104753 05/23/16 08:38 PM
N
Nitronoise Offline
N
Been running 5w30 in my wifes freestylee for 5 years and it,s specd for 5w20 with no harmful effects on the DHOC 3.0L.I'm running 5w30 for the same you are asking.
I stock 5w30 for everything , but I have been trialing 2 rotellas for my Jeep it @ 22 years young and I want a little more zinc for an older flat tappet motor
07 Ford Freestyle 166K
06 Honda Acord EX 133K
02 Ford Tarus 123K
00 Buick Regal SC 144K
95 Goldwing 28K
